  1. Apr 6, 2023 at 10:57 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Also it looks like my left high beam has a stronger hot spot than the passenger side. After firing the high beam solenoid several times, they even out. I believe the pass side shield was sticking a bit.
    Generally when you get these from Ghyna, you should bench test them and fire the solenoid a good 20-30 times to eliminate the chance that it sticks.
  2. Apr 7, 2023 at 8:48 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Changed my oil today in preparation for T2S. I may need to stop buying oil filters for a while.
  3. Apr 7, 2023 at 9:14 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’ll be doing my oil this weekend too
    OctothorpeT2S-prep
  4. Apr 7, 2023 at 9:32 AM
    Guilty. This is from my headlight swap pic last week. Not as bad as you, and I just hit 75k, so I'm due for my 500-mile-since-seafoam-in-crankcase oil change this weekend, so ... shit, that reminds me, I need to get a jug of oil... :D
    abcinv and FrenchToasty like this.
  5. Apr 7, 2023 at 11:39 AM
    artsr2002
    'Yonder
    My pops and I just finished installing the Skid Row plate and cat guards. Noice.
    We then went ahead and took care of the passenger side valve cover gasket. I noticed two of the 4 coils were missing the rubber gasket between the coil and head cover so I ordered a set of gaskets, boots, and springs to replace them all. Topped up the power steering fluid reservoir and she is ready to go.
  6. Apr 7, 2023 at 12:42 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I keep my filters in the basement. Read somewhere that it's best to keep them in a cool dry place so they'll last indefinitely. (Maybe you said you had a basement garage I don't recall)
    oscardog86 likes this.
  7. Apr 7, 2023 at 2:07 PM
    tacoguybill
    tacoguybill The Burrito Bandido
    Bill
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    43E4123F-2A61-4AC2-ABE1-1E87E6443500.jpg Helped one of the guys from work change the rear pads and rotors on his sequoia. “There’s a weird noise when I brake” :rofl:14C61597-C227-4477-8FE2-0A167A1F066A.jpg
    bmf4069, Rheywood456, txagg and 4 others like this.
  8. Apr 7, 2023 at 2:44 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    How bad were the rotors?
  9. Apr 7, 2023 at 3:02 PM
    Yup.
    Now I gotta see who's got the best deal on oil :D
  10. Apr 7, 2023 at 3:57 PM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    So im gonna probably be going on a long camping trip for atleast a week maybe two soon and was thinking ill do my oil change before i leave as its due pretty soon.
    Ive always used conventional, but thinking its about time to go with synthetic as it seems like its a better oil and conventional is getting harder for me to find in the stores.
    Ive heard of possible leaks after switching though, but was just wondering if you guys had any input on switching. It seems most of you guys are using synthetic though right?
    Thanks guys!
  11. Apr 7, 2023 at 4:12 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    Hang on, is your garage climate controlled?
    DJenerated likes this.
  12. Apr 7, 2023 at 6:34 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Pennzoil has a $20 rebate on 10 qts of their synthetic.
    txagg, shifty`[QUOTED] and artsr2002 like this.
  13. Apr 7, 2023 at 6:48 PM
    artsr2002
    'Yonder
  14. Apr 7, 2023 at 6:53 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    txagg and shifty` like this.
  15. Apr 7, 2023 at 7:07 PM
    artsr2002
    'Yonder
    Tru Tru, he a GoogleFu Master.
    NUDRAT likes this.
  16. Apr 7, 2023 at 7:24 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  17. Apr 7, 2023 at 7:24 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Round two.
    New gasket, not torn.
    Found the cause of my leak, I missed some of the old gasket on the bottom of the 3rd member.
    bmf4069, Rheywood456, NUDRAT and 8 others like this.
  18. Apr 7, 2023 at 8:06 PM
    It would seem my previous owner(s) used only dino. Only leaks I saw switching to full syn were at the valve cover, but that came from the corners which weren't cleaned/FIPG'd properly after previous person had valve covers off, potentially to fix the cam seals, I really dunno.
    If you're really worried about leaks, put in 6qt and a full bottle of AT-205 at the same time. It'll rejuvenate your gaskets. Then top off with oil as needed. You should only need to do that once. But I wouldn't be too worried about leaks. Obviously YMMV since you've surely got higher miles. Just stick with a high-mile synthetic. Mobil1's is excellent.
    I mean, kinda? My data closet is in the basement, and I'm venting climate controlled air out of the data closet (for heat reduction/air flow) into the garage. So, like, you remember when we had that 3-day bizarro cold snap where temps got down to 4, for 3 days having highs of 19-20? My garage was still in the 60s while it was below freezing outside.
    I don't have a ton of humidity control because garage doors, but overall, the temps are pretty well regulated. My basement is climate controlled, and I'm pumping basement air out to the darage in metered amounts. It's about as good as it'll get.
  19. Apr 7, 2023 at 8:28 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Forgot to mention I threw the front spidertrax spacers on too. No pics (yet).
    tacoguybill and oscardog86 like this.
  20. Apr 7, 2023 at 8:31 PM
    oscardog86
    Southern California
    FrenchToasty likes this.
  21. Apr 7, 2023 at 8:35 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Hey me too :)
    I switched from Valvoline conventional to Mobil1 Synthetic at around 150k, ~170k miles now and still no leaks. I switched on the recommendation of others on here and really have nothing else to add about the experience.
  22. Apr 7, 2023 at 8:46 PM
    oscardog86
    Southern California
    I guess having nothing else to add about the experience is a good thing. Sounds like the switch went smoothly and is going well! Thanks for that input, ill be giving it a go tomorrow.
  23. Apr 7, 2023 at 8:50 PM
    oscardog86
    Southern California
    @des2mtn oh yea forgot to ask, where ya heading? Im from so cal too and ill probably be heading up to northern california possibly oregon. Gonna check out the coast and the redwoods!
    DJenerated, des2mtn and daveeasa like this.
  24. Apr 7, 2023 at 8:53 PM
    daveeasa
    David
  25. Apr 7, 2023 at 8:55 PM
    oscardog86
    Southern California
    Oooh definitely open to suggestions. Ive never gone camping in northern california, at least not since i was a kid so i know nothing about where to go. I will definitely look into that campground. Also ill be doing the "Avenue of the Giants" which has been recommended to me by a few people.
    tacoguybill likes this.
  26. Apr 7, 2023 at 9:09 PM
    des2mtn
    SW
    Tonto cover
    Sounds fun! Haha, Northern AZ for a week for T2S, then possibly southern UT elsewhere in AZ for at least a week after that.
  27. Apr 7, 2023 at 9:24 PM
    oscardog86
    Southern California
    That sounds fun too! Gonna be good to get away from it all for a bit, thats for sure.
  28. Apr 7, 2023 at 10:46 PM
    Jdtuned
    Jdtuned New Member
    01 AC sr5 4.7 2wd
    No mods besides regular maintenance and up keep.
    I did the valve cover gaskets today no pics on a count of how much a pain in the ass it was! And I speak for myself and the little patience I have in my “old age” i used all Toyota gaskets and bolts. Shout out to @shifty` for helping others and in turn helping me. One thing I was uncertain of was the torque specs the Haynes manual says 53 in-lbs seems like it’s not much so I torqued beyond that I figure I’ll check them after the first drive tomorrow.
    shifty` likes this.
  29. Apr 7, 2023 at 11:53 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Any reason you're not goin to Tundras2Sedona? There's going to be close to 10 first gens that I know of. 5 from CA. 3 from TX. and I believe a couple resident AZ boys. Even one of us from TN making the haul.
  30. Apr 7, 2023 at 11:59 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Ordered a replacement case for the locker. $287 total. Free shipping. Won't know if I'll have time to get it installed until I get a tracking #. The case should be identical right? I'll still measure backlash and check contact pattern when I swap the gear and guts over, but I can expect it to be good or damn close right?
