  1. Mar 5, 2019 at 3:19 PM
    #4741
    Professional Hand Model
    Hand Protectors
    I sore Chris(nice hands)Fix vid work on his FordMazda? truck. He snugged some bolts up in there.
    Sore Timmah Toyota vid work on his 3rd Gen 4Runner with the 340F Transmission and he did a thorough job, but looked to be missing doing some snugging of bolts on that circuit board. Would like to know more about these solenoids and see some specs.
  2. Mar 5, 2019 at 3:57 PM
    #4742
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I saw this big old Beast driving up hwy 49 today. Your trucks looking good. I love the new ride height.
    Casper421[QUOTED] likes this.
  3. Mar 5, 2019 at 4:03 PM
    #4743
    Casper421
    In the woods
    06 DC
    Thanks! Yeah, left work a little early to visit my favorite place!
  4. Mar 5, 2019 at 4:12 PM
    #4744
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    N
    Not sure where you're located or if you already have a bed lined up but I saw this on CL and thought I'd let you know about it...
    https://gadsden.craigslist.org/pts/d/walnut-grove-2006-toyota-tundra-truck/6832586111.html
    It appears clean, no idea if it's a good deal or not...
  5. Mar 5, 2019 at 5:00 PM
    #4745
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Damn the droop!
  6. Mar 5, 2019 at 5:07 PM
    #4746
    Casper421
    In the woods
    06 DC
    :thumbsup:
  7. Mar 5, 2019 at 5:10 PM
    #4747
    Casper421
    In the woods
    06 DC
    Speaking of droop, @Sunnier , we need an update!!
    Darkness[QUOTED] and Sunnier like this.
  8. Mar 5, 2019 at 5:16 PM
    #4748
    Sunnier
    Sunny
    San Diego, CA
    Ha! I was thinking the same. Last I saw, mine looks like this:
    I'm trying to be stoic.
  9. Mar 5, 2019 at 5:22 PM
    #4749
    Casper421
    In the woods
    06 DC
    It’ll take Bruce no time to get everything back together. Are you going to run a secondary up front?
    Sunnier[QUOTED] likes this.
  10. Mar 5, 2019 at 5:22 PM
    #4750
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    :eek: Somebody stole your 4wd bits!
  11. Mar 5, 2019 at 5:23 PM
    #4751
    Casper421
    In the woods
    06 DC
    So that’s why you were in SD!!
    bmf4069 and Sunnier like this.
  12. Mar 5, 2019 at 5:24 PM
    #4752
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm converting mine next weekend :benchpress:
    Thanks Bruce!
  13. Mar 5, 2019 at 6:12 PM
    #4753
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
  14. Mar 5, 2019 at 7:12 PM
    #4754
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Alas. That is clean. But I’m up in Indiana. And I have an 8 foot bed. Thanks for the thought though!
    Pretty sure I’ve got one lined up in Wisconsin. Just need to figure a day to go get it
  15. Mar 5, 2019 at 7:12 PM
    #4755
    empty_lord
    05 rollover special
    Reg cab. But yea.
  16. Mar 5, 2019 at 8:55 PM
    #4756
    because_wumbo-truck
    Jon
    Houston, Texas
    Right but same frame at least. I don't think the DC has many common parts with the RC and AC. Just common styling. It's like gen 1.5 lol
    empty_lord[QUOTED] and Darkness like this.
  17. Mar 5, 2019 at 9:15 PM
    #4757
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Same radio :notsure: maybe
  18. Mar 5, 2019 at 9:58 PM
    #4758
    empty_lord
    05 rollover special
    It’s a sequoia with a bed is best I could put it. The body has more in common with a sequoia then a reg/acc cab
  19. Mar 5, 2019 at 10:44 PM
    #4759
    because_wumbo-truck
    Jon
    Houston, Texas
    I can't help but wonder the suspension differences between the RC/AC and DC. Would be cool if the DC suspension could be swapped to ours. I know the DCs always look lifted more than ours and that Bilstein 6112s are good for the full 3 inches on a DC but only recommend to go 1 inch on a RC/AC due to the front geometry. No idea why that is.
  20. Mar 5, 2019 at 10:44 PM
    #4760
    empty_lord
    05 rollover special
    in other news ive put about 100 miles on the truck so far. cleaned up the oil thats been leaking from the cam seals, once its back from the body shop i'll be doing the t-belt, w/p, cam seals (oh boy..) valve cover gaskets and a crank seal (why not.). May bypass the factory trans cooler and install a larger plate cooler with a russel 165 degree thermostat so i know the coolant cant get into the trans (since its a nice new used unit already)
    Also going to reset the trans memory, the thing seems to not want to shift all the time into 4th and 5th.. doesnt feel mechanical. feels like an electrical issue
  21. Mar 5, 2019 at 10:45 PM
    #4761
    empty_lord
    05 rollover special
    i dont see how the suspension setup is different. I'll have to take a closer look, the suspension should be damn near the same. its just a bigger version of the Tacoma setup
    maybe the double cabs are shorter than the rc and ac trucks. wouldnt surprise me, would also explain the max lift of each
  22. Mar 5, 2019 at 10:49 PM
    #4762
    empty_lord
    05 rollover special
    well the lower control arms, uppers, and spindles are all the same for the D/C and reg/AC trucks. so its likely just the double cabs sit lower than the RC and AC trucks
  23. Mar 5, 2019 at 10:53 PM
    #4763
    because_wumbo-truck
    Jon
    Houston, Texas
    they sit higher. My ac 4x4 was like a low rider before I lifted it 3 inches and it still just sits like the height of a stock DC or modern 1500 pickup
  24. Mar 5, 2019 at 11:00 PM
    #4764
    empty_lord
    05 rollover special
    huh. part of thats likely because of the taller roof. but the front suspension setup has all the same part numbers except for the shocks. maybe it has to do with the rear drive shafts and the length of the frame. hmmm.
    I'm looking at the OME lift from low range offroad. id love to do icon like on my tacoma. but i just cant afford to do that to this truck right now lol.. i still have to finish building my frame for my taco
  25. Mar 5, 2019 at 11:02 PM
    #4765
    because_wumbo-truck
    Jon
    Houston, Texas
    I love my Tundra but I wish I didn't trade in my Taco. Would be nice to have both
    NUDRAT likes this.
  26. Mar 5, 2019 at 11:07 PM
    #4766
    empty_lord
    05 rollover special
    this tundra fell into my lap. was going to use its engine for the other frame i have that im going to do a LT build on in the future. but when i got to see this truck i knew i could fix it, lol. so now it looks like im going to have a nice new work truck. As of right now i have my 01 tacoma in pieces. a spare tacoma frame with full running gear (pulled the engine and trans from the rolled 4runner i was given) and suspension, This 05 tundra. a 06 corolla with over 700k miles and my 06 avalon. Needless to say i have a problem.. and im truely addicted to toyotas.
    But after driving this tundra for a few days, i really like it. it drives like a taco, just bigger with gobs more power
  27. Mar 5, 2019 at 11:40 PM
    #4767
    because_wumbo-truck
    Jon
    Houston, Texas
    I agree 100% it does drive like a bigger more powerful taco. I could never go back to a taco as a daily unless it was SC'd now lol. Hell these trucks even have similar styling to the 01-04 tacos
  28. Mar 5, 2019 at 11:50 PM
    #4768
    empty_lord
    05 rollover special
    eh i could still daily a taco. only issue is once mines done i dont think i'll want to. lol way too much money invested into the taco to want to daily. it'll be my fun car. Tundras the new work truck. avalon still holds daily duties (power and MPG. gotta love that), The corolla is kinda just the backup car for now. lol (amazed the thing is still running like it does)
  29. Mar 6, 2019 at 12:02 AM
    #4769
    because_wumbo-truck
    Jon
    Houston, Texas
    Tundra is my daily for now. But I'd like it to be my fun truck and maybe a tow pig eventually. I'm looking at buying a taco, t4r, or t100 as a DD but eventually making that DD into a crawler. I really want to buy this truck if I can get the price down some.
    https://houston.craigslist.org/cto/d/pleasanton-1995-toyota-t100/6822052254.html
  30. Mar 6, 2019 at 3:50 AM
    #4770
    Hand Protectors
    Nice truck in that ad. I think you secretly want a 00-02 Tundra.
