  1. Mar 18, 2023 at 6:41 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Do you?
    NUDRAT[QUOTED] likes this.
  2. Mar 18, 2023 at 6:47 PM
    shifty` Inside his chest they found ten thousand pencils
    I don't either. No interest. IIRC, it's not anodized, and aluminum that's not anodized, near corrosive crap, has a penchant for chalking/caking.
    DJenerated likes this.
  3. Mar 18, 2023 at 6:51 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    i love mine! raw non-TRD. i think i have zero corrosion but AGM may help. now I have to check it...
    des2mtn and FrenchToasty like this.
  4. Mar 18, 2023 at 6:52 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    Thanx
  5. Mar 18, 2023 at 6:53 PM
    Guys on here I've seen using felt rings on the terminals don't seem to fight with white fluff.
    It's just not for me.
  6. Mar 18, 2023 at 6:57 PM
    alb1k
    Left Coast
    It's good
    that could be it, I never sprayed the terminals with anti-corrode, but I have felt and also run them 1/16" high on the posts
  7. Mar 18, 2023 at 6:57 PM
    FrenchToasty
    Mo
    Bone stock
    I have an AGM and no felt and I have no fluff.
    des2mtn likes this.
  8. Mar 18, 2023 at 6:59 PM
    alb1k
    Left Coast
    It's good
    i think when you buy the super expensive SDHQ covers they will do you solid and send felt, lol
  9. Mar 18, 2023 at 7:12 PM
    They may actually be ano'd. It's totally possible I'm wrong. Someone on here - I feel like it was FGV, but maybe it was Dan or something. Bought one, had some battery issues, and they fluffed out hard, which isn't what I'd expect to see from something anodized.
  10. Mar 18, 2023 at 7:15 PM
    alb1k
    Left Coast
    It's good
    No they aren’t ano, no way.
  11. Mar 18, 2023 at 7:25 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm cheap at times. They look nice though!
  12. Mar 18, 2023 at 8:11 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    So you got the coil cleaner in through the drain nipple there? Is that what you're saying? Seems like a great preventative maintenance idea honestly.
  13. Mar 18, 2023 at 8:13 PM
    tacoguybill
    tacoguybill The Burrito Bandido
    Bill
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    I think I pulled my battery tie down off last year, applied naval jelly, wire brushed and rattle canned it. Good nuff I suppose…and I’m a cheap ass…hence the backyard cam seal replacement.
    bmf4069, Jack McCarthy, txagg and 2 others like this.
  14. Mar 18, 2023 at 8:18 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That looks fantastic in comparison J-man! I need to do this after I replace the box that holds all that shit in crackie. I broke it. I planned on just mending with black flex tape, but haven't got to it uet.
    txagg and shifty`[QUOTED] like this.
  15. Mar 18, 2023 at 9:09 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    If the fan works on all speeds, the resistor itself is ok. Just the ceramic cover or coating has started breaking down/apart.
    Very common to find it cracked/flaking/etc across different makes/models.
    shifty`[QUOTED] and FirstGenVol like this.
  16. Mar 19, 2023 at 6:45 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I ran no hold down. Don't know when it went away. I didn't take it off, wasn't on my mechanic's work top. Poof vanished.
    When you're looking at replacing the entire exhaust including two cats - fancy battery hold-down was a hard nope.
    FGV's Tundra is mostly sorted & definitely feather-dusted under the hood. That's when you start adding truck jewelry.
  17. Mar 19, 2023 at 8:25 AM
    Turns out the part is only $20. I'm just gonna replace it. Hopefully it's good for another 15 years.
    Yep.
    From the inside, pop off glove box, pop off resistor and carefully slide out (it's a tight fit, there's just enough room, extract slowly). Take a peek inside to see if you have shit to vacuum out. Vacuum out as needed. Reinstall resistor. take your Toyota AC refresh kit, stick the barb end of the tube into that drain nipple on the firewall and pump away, shaking the can as you pump, then give if 15-20 mins to liquefy and drain out. Notes on that:
    • Toyota says empty half the can into there, let it drain out, then empty the other half in
    • BG says to empty the whole can in, set the HVAC to ON, non-recirc, full blast, then crank the engine so it pulls the foam thru the can - I'm not in love with this idea! (but I did empty half the can in, then turn on the vent for a few seconds to pull some through the coil.
    • I'd probably stick with Toyota's reco.
    I gave the part numbers up above for our region, the number that starts 000xx-xxxxx is something you should be able to give your local dealership parts counter and they can grab it. They should have it in stock.
    Here's the Toyota instructions for the kit. We're lucky; the drain tube is super easy to get to for us. :D
  18. Mar 19, 2023 at 9:37 AM
    tacoguybill
    Bill
    Saaaan Diaaago
    My truck has always smelled a bit like the pirates of the carribean ride at Disneyland and while I’m not one of those people who loses their shit over DL, the wife said “don’t do it! It reminds me of going to a waterpark” this is why we can’t have nice things :rofl: but I have thought about trying to see if there was anything I could do to freshen it up a bit, I appreciate the post @shifty` ….I wonder if using AC coil cleaner wouldn’t help the condenser or radiator after particularly adventurous driving :monocle:
    bmf4069 likes this.
  19. Mar 19, 2023 at 12:35 PM
    I mean, the stuff that's in here is basically just coil cleaner that HVAC guys use on compressors outside your house. It'd probably just be cheaper to buy the stuff HVAC guys use to clean your radiator, but I mean, a water hose may work just as well, as long as it's not so strong it'll bend your fins. People sell tools to straighten those fins out though, IIRC.
    A lot of times "that water park smell" is due to cabin leaks, and the must is from mildew or full-on mold. The stuff I used and linked above is primarily intended for use when those musty smells coincide with you turning on the air. In my wife's Highlander, the 1st time you turn on the A/C, it's almost like catching a little whiff of vinegar. But in my truck, it just smelled dusty/like fresh soil when you turn it on. That's gone after the treatment.
    YMMV. I won't recommend using this on your radiator. But I'm sure there's something out there that'll work!
  20. Mar 19, 2023 at 1:26 PM
    tacoguybill
    Bill
    Saaaan Diaaago
    Hahaha I meant it smells like waterpark when I turn the AC on, never peeked back there though I’ll have to check it out sometime soon.
    Here’s little progress pic for the day, yesterday I got the passenger side camshaft out, spent all morning today cleaning both cam covers and little circle seals along with cleaning the valve covers, new spark plug tube seals and a new PCV valve, the old one was a bitch to get off.
    Replaced the seal on the passenger side camshaft, going to reassemble and torque down now and clean the area surrounding the bucket before calling it a day, get to the next task hopefully tomorrow after work.
    Voss, oscardog86, bmf4069 and 4 others like this.
  21. Mar 19, 2023 at 9:05 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    LOL. Harbus Freightimus.
  22. Mar 20, 2023 at 1:09 AM
    artsr2002
    'Yonder
    Used mine to help a neighbor with transporting some lumber and paneling from the orange big box store to his crib. You know, truck stuff.
    bmf4069 likes this.
  23. Mar 20, 2023 at 2:42 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Dad commuted in the silver truck, and will be for a minute. Lil bro cut down a telephone pole with the ferd. Tried to climb up number 2 further down the runway. Meep Meeped too hard.
    He sent me this the following morning after his incident.
    bmf4069 likes this.
  24. Mar 20, 2023 at 2:45 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    We're reeeal guud at cheatin death.
    oscardog86, txagg, bmf4069 and 3 others like this.
  25. Mar 20, 2023 at 5:26 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Damn...you know you're going to have to pay for that phone pole
    NUDRAT likes this.
  26. Mar 20, 2023 at 6:08 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    He looks pissed, like that pole had the audacity to hop in front of him, while making eye contact.
    FOCUSed a little too hard.
    txagg, bmf4069, NUDRAT and 5 others like this.
  27. Mar 20, 2023 at 6:16 AM
    tacoguybill
    Bill
    Saaaan Diaaago
    Glad everyone is OK......I need to do this mod to my wife's odyssey :rofl:
    txagg, bmf4069, NUDRAT and 2 others like this.
  28. Mar 20, 2023 at 6:28 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Props to that windshield washer reservoir for not breaking. :hattip:
  29. Mar 20, 2023 at 6:46 AM
    Hopefully he's "A"-OK (hurr).
    Maybe if he'd just had a little more hair on his head and face like you, he'd have intimidated the telephone pole enough to get out the way.
    Big question is: Was he driving like a d-bag, trying to pass someone he shouldn't have passed, or will we just never know?
    bmf4069 likes this.
  30. Mar 20, 2023 at 6:47 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Interesting how the rest of that pole is still suspended by the lines.
