  1. Mar 1, 2019 at 7:05 AM
    #4621
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    My grill has no bars period though.
    Make me suspect my tail gate handle to be a knock off because it's flimsy and black instead of white. The lock broke the handle feels cheap. Plus my buddies white 01 has a white tail gate handle.
  2. Mar 1, 2019 at 7:09 AM
    #4622
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    The factory tailgate handles are pretty cheap feeling. Not 100% sure that they are painted on limited models.
    Limited models don't have the bars, just painted bumper.
    because_wumbo-truck likes this.
  3. Mar 1, 2019 at 8:27 AM
    #4623
    speedtre
    speedtre New Member
    Inland Northwest
    It's very simple really based on how ATs work. When you are in any given gear and trying to maintain a given speed and the vehicle detects a loss of speed it has two options (assuming you have not requested more power with your right foot). It can either shift down a gear or it can unlock the torque converter (or it can do a combination of both). Unlocking the torque converter will increase transmission fluid temps. Excessive trans fluid temps are the killers of transmissions.
    If you tow a substantial amount in O/D and you are not on completely flat ground with no headwind, your transmission is going to be constantly unlocking the torque converter (and increasing trans fluid temps) trying to maintain speed. Over time, this can be problematic. You can somewhat mitigate this with your right foot and to a larger extent by turning O/D off. Like I said, I will tow in O/D if the load is not too heavy and it's not hilly. I will nearly never tow in O/D and use cruise control unless I'm somewhere like FL or the midwest where it's completely flat. This does not apply to just Tundras.
    bmf4069 and FirstGenVol like this.
  4. Mar 1, 2019 at 8:53 AM
    #4624
    speedtre
    speedtre New Member
    Inland Northwest
    The transmissions in 1st Gen Tundra's are not what I would call particularly weak (like say late 90s Jeep ATs) or particularly robust (like the Aisin's they put in the late 90s Monteros or even A340Fs in 3rd Gen 4runners)...I personally
    know of two 1st Gen Tundras that had transmissions replaced before 100K miles...one was my previous 2005 DC before I bought it. If you know what you are doing and don't abuse them, there is no reason the AT can't last the life of the truck...but if you combine any of these...lots heavy towing, steep hills, high outside temps, leaving it in OD (while towing) and not following the recommendations for changing your transmission fluid more frequently, you are asking for trouble with any AT, not just 1st Gen Tundras.
    I would not hesitate to tow with a 1st Gen Tundra as an non-work vehicle and knowing what to do to mitigate the risks (like occasionally towing a camper/boat/utility trailer). I would not use a 1st Gen Tundra as a work vehicle if that entailed towing heavy loads very frequently...YMMV.
    bmf4069 likes this.
  5. Mar 1, 2019 at 10:56 AM
    #4625
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    2000-2004 Tundras have the A340F.
    speedtre[QUOTED] likes this.
  6. Mar 1, 2019 at 10:58 AM
    #4626
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Does the scan gauge 2 really give trnasmission temps for the early 1st gen tundras?
  7. Mar 1, 2019 at 11:10 AM
    #4627
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I was wondering the same thing.
    This other one I found has a sensor you have to attach to the transmission. How would the scangauge work without that?
    The scangauge seems like the better product if it can actually provide the trans temp.
    lsaami[QUOTED] likes this.
  8. Mar 1, 2019 at 11:14 AM
    #4628
    Professional Hand Model
    Hand Protectors
    I’d love to buy one of those $3k sensors that tells me everything... butt I digress. Tempting.
  9. Mar 1, 2019 at 11:30 AM
    #4629
    speedtre
    speedtre New Member
    Inland Northwest
    Yep, I should have been more specific...the A340F is "robust" with regard to what it's asked to do in
    a 3rd gen 4runner...it's handling less torque and in a vehicle that has a lower tow rating (and is not asked to
    tow like a 1/2 ton truck usually is). You rarely hear of people having AT issues with 3rd gen 4runners and 1st gen Tacomas. Lowis HP/TQ motors and nobody expects them to tow like they do with a 1/2 ton.
  10. Mar 1, 2019 at 11:32 AM
    #4630
    speedtre
    speedtre New Member
    Inland Northwest
    If you have a temp warning light, (Tundras do) then their must be a sensor reading tran. temps already. It would make sense that a ScanGauge could get that info then.
    NUDRAT and because_wumbo-truck like this.
  11. Mar 1, 2019 at 1:02 PM
    #4631
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @lsaami and @FirstGenVol the answers are "yes" and "I don't know, but it does", respectively.
    It either does not work for 05-06 or it does and the code is hard to find, but for 04 and older it works.
    I named it "AT?" Because way back when I programmed mine it was unclear if it was correct.
  12. Mar 1, 2019 at 1:22 PM
    #4632
    because_wumbo-truck
    Jon
    Houston, Texas
    my buddy's white 01 is a limited and his handle is white
  13. Mar 1, 2019 at 1:29 PM
    #4633
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
  14. Mar 1, 2019 at 2:03 PM
    #4634
    Hand Protectors
    Can you feel a difference in handling? Knowing you used the same tires, this is a good experiment.
    Jerry311SD[QUOTED] likes this.
  15. Mar 1, 2019 at 2:11 PM
    #4635
    because_wumbo-truck
    Jon
    Houston, Texas
    The scan gauge works by using an algorithm. Basically you go online and find the "xgauge" and program it into your scan gauge. It uses the engine and transmission sensors available to fill in variables on the algorithm to reach a conclusion as to what your ATF temp is.
  16. Mar 1, 2019 at 2:35 PM
    #4636
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Not that I can tell. It's only been 25miles so far.
    I removed my sway bar a while ago so I doned really drive to crazy in the truck.
    I save the fun driving for my Benz
  17. Mar 1, 2019 at 2:47 PM
    #4637
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    its plated, insured and home
    Sunnier, NUDRAT, Darkness and 2 others like this.
  18. Mar 1, 2019 at 5:49 PM
    #4638
    Deslock23
    Deslock23 New Member
    2003 Tundra SR5 AC 4wd
    5100’s at 5th notch, Add-a-leaf, diff drop.
    Still deciding between Methods & SCS, what backspacing did you get, and I missed it earlier but am I correct that the tires are 285's?
  19. Mar 1, 2019 at 6:45 PM
    #4639
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Put my skid plate back on, that heavy sonvabitch. Then I crawled under the rear and spun the proportion valve up about 3/4 inch, I still have about 3/4 inch of thread above it. I'll see how the brakes feel now and adjust later if needed.
    About to fill up the tank and take a drive to San Diego, excited to see what kind of mpg I get...
    and to park next to my cousins ranger on 31s. :boink:
  20. Mar 1, 2019 at 6:48 PM
    #4640
    Deslock23
    So, uh, like... Love your Tundra, but, ummm.. can we see pics of the Ranger too?
  21. Mar 1, 2019 at 6:50 PM
    #4641
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    It's a stock truck. I told him get a Taco but noooo he got a step side ranger.
  22. Mar 1, 2019 at 6:54 PM
    #4642
    Deslock23
    Hard choice there, 4x4 + step-side.... I'd be tempted as well. I've heard it's not TOO hard to drop a 302 in one, and, well, step-side.
  23. Mar 1, 2019 at 6:56 PM
    #4643
    Casper421
    In the woods
    06 DC
    A step side?! I bet you can haul more stuff in your element than in his bed.
    NUDRAT and Darkness[QUOTED] like this.
  24. Mar 1, 2019 at 7:16 PM
    #4644
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Not even 4x4 :( it's a 2wd automatic splash. I told him that's a chick truck.
    He got it for a thousand bucks and it belonged to his buddy, he described it as a project but its absolutely stock and leaks everywhere. @Professional Hand Model if you saw the seepage from the valve covers, the rear diff and the trans you'd go nuts.
    I want to take the "R" off the badges so it says Ford Anger :D
  25. Mar 1, 2019 at 7:25 PM
    #4645
    Deslock23
    Well that's disappointing, Hell, for 1k tell em to go buy the front diff out of a wrecked Explorer & do a v8 swap.
    Darkness[QUOTED] likes this.
  26. Mar 1, 2019 at 7:30 PM
    #4646
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I considered that. I think it's a 2005 and I laughed when I realized the suspension is identical to a 96 Exploder I had long ago. The biggest kick in the nuts is his previous truck was an F250 4x4 with the V10.
  27. Mar 1, 2019 at 7:36 PM
    #4647
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    brake dust creeping 1/2 way out the tire? You guys on water rationing or something? Yeech.:tumbleweed:
  28. Mar 1, 2019 at 8:00 PM
    #4648
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    No
    My tires are 275/70/17
    The wheels are these.
    Method Race Wheels NV Black Wheel with Machined Face (17x8.5"/6x5.5") 0 mm offset
    Deslock23[QUOTED] likes this.
  29. Mar 1, 2019 at 8:18 PM
    #4649
    WutsaZJ
    WutsaZJ New Member
    2006 Double Cab 4x4 trd offroad
    5100s, 285 wildpeaks, snugtop,rear bags, and a bunch of plastiderp
    Just finished these bad boys up.
  30. Mar 1, 2019 at 8:27 PM
    #4650
    Sunnier
    Sunny
    San Diego, CA
    Whatcha doing in San Diego? :spy:
    Want me to call the entire SoCal Shenanigans crew out?!! :thumbsup:
