  1. Feb 28, 2019 at 6:07 PM
    #4591
    Deslock23
    Deslock23 New Member
    2003 Tundra SR5 AC 4wd
    5100’s at 5th notch, Add-a-leaf, diff drop.
    Darkness likes this.
  2. Feb 28, 2019 at 6:20 PM
    #4592
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    I have carpel tunnel syndrome. As soon as you said hand gymnastics, or whatever you termed it, i was out.
  3. Feb 28, 2019 at 6:25 PM
    #4593
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Looks like it could take a decent amount of overbore. At least .030" over... :notsure:
  4. Feb 28, 2019 at 6:37 PM
    #4594
    Casper421
    In the woods
    06 DC
  5. Feb 28, 2019 at 7:38 PM
    #4595
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The heat exchanger in the radaitor
    Fails and coolant being under higher pressure finds its way into the trans cooler and contaminates the fluid. Really no signs until the trans starts acting up. Best to keep an eye on the fluid honestly, sucks for people with sealed transmissions though.
    I bypassed the cooler in my tacoma just because. Got a russel 165 degree thermostat and a derale stack plate cooler. No more worries of coolant in the trans fluid. Tundras getting the same likely
  6. Feb 28, 2019 at 7:41 PM
    #4596
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    On this topic. Can someone recommend a good transmission temperature gauge. Would prefer a digital one.
  7. Feb 28, 2019 at 8:29 PM
    #4597
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    My dad actually had pink milkshake happen couple years ago. We only caught it because when the trans is hot, it caused coolant to come out the overflow and we saw it in the garage.
    Sketchy stuff. Like I said above, the cool and actually started overflowing into the ground in my dad’s. Have you ever seen that?
  8. Feb 28, 2019 at 8:42 PM
    #4598
    Deslock23
    Now that I can walk upright again, I have 2 questions: 1, did the housing around the fogs come with them, or did you make/modify them? And 2 are they wired to the factory switch?
    TUNDRAIN520 and NUDRAT like this.
  9. Feb 28, 2019 at 8:49 PM
    #4599
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Leaving work tomorrow at lunch to do this.
  10. Feb 28, 2019 at 8:49 PM
    #4600
    Casper421
    In the woods
    06 DC
    NUDRAT and Darkness like this.
  11. Feb 28, 2019 at 9:05 PM
    #4601
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Scangauge2
  12. Feb 28, 2019 at 10:24 PM
    #4602
    empty_lord
    05 rollover special
    cant say i have. usually people bring the car in for shifting issues. if its flushed out and the radiators replaced they usually do fine.. but some people wait till the damn things slipping like no other and bucking. then its too late
    lsaami[QUOTED] likes this.
  13. Feb 28, 2019 at 10:51 PM
    #4603
    empty_lord
    05 rollover special
    I take it the double cab door panels will not fit regular cab doors? driver side panel is broken on mine and i'd like to upgrade to power stuff. thinking about yanking sequoia panels at the junkyard if they'll fit (same as a double cab), I know some brackets are different and the door handles in a different location... but wonder if the shells have all the same holes.
    NUDRAT likes this.
  14. Feb 28, 2019 at 11:02 PM
    #4604
    empty_lord
    05 rollover special
    Nope.. completely different doors. Damn
  15. Mar 1, 2019 at 12:49 AM
    #4605
    Sunnier
    Sunny
    San Diego, CA
    :thumbsup: :rofl:
  16. Mar 1, 2019 at 1:15 AM
    #4606
    Sunnier
    Sunny
    San Diego, CA
  17. Mar 1, 2019 at 1:21 AM
    #4607
    because_wumbo-truck
    Jon
    Houston, Texas
    For some reason my.linited didn't come with the chrome bars on the grill and bumper. I'm not sure if the previous owner removed em or what. I wish I had em just to break up the white a little.
    NUDRAT likes this.
  18. Mar 1, 2019 at 1:46 AM
    #4608
    Sunnier
    Sunny
    San Diego, CA
    Those look good! Whatcha gonna do with your take-offs?
    Jerry311SD[QUOTED] likes this.
  19. Mar 1, 2019 at 3:59 AM
    #4609
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Just make that lower grill match the tow hook. Little splash of red btwn upper & lower bumpers will be tasteful suggestion the truck has something going on.
    Not so good at photo edit, but just the grill:
  20. Mar 1, 2019 at 4:02 AM
    #4610
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    LOL - quoting myself. Seeing it big I don't like my suggestion.
    Do that grill, the hook & only the Toyota center emblem in an amber that matches the signals
    https://www.amazon.com/dp/B008BLFHS0
  21. Mar 1, 2019 at 4:38 AM
    #4611
    Professional Hand Model
    Hand Protectors
  22. Mar 1, 2019 at 4:39 AM
    #4612
    Hand Protectors
  23. Mar 1, 2019 at 4:53 AM
    #4613
    because_wumbo-truck
    Jon
    Houston, Texas
    That would look awesome with matching wheels
  24. Mar 1, 2019 at 4:53 AM
    #4614
    because_wumbo-truck
    Jon
    Houston, Texas
    This is actually exactly what I have in plan once I get some time off.
  25. Mar 1, 2019 at 4:53 AM
    #4615
    Hand Protectors
    Hand Yoga. Spent some time in the Himalaya Mountains practicing hand jujitsu with a famous sensai years ago.
    Your call as only you know what your hands can do.
  26. Mar 1, 2019 at 4:55 AM
    #4616
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'd put the tires on too. Might work better in the long run.
  27. Mar 1, 2019 at 4:57 AM
    #4617
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I think all the limiteds came like that. Like the sport option on murican trucks.
  28. Mar 1, 2019 at 5:58 AM
    #4618
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Limited models are fully color matched. The door mirrors, door trim, grille and bumpers are all painted.
    Interestingly the regular model single cabs came without the chrome on the grille and bumper, some were paint matched and some were painted dark gray regardless of the trucks color.
  29. Mar 1, 2019 at 6:06 AM
    #4619
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Gonna sell them, along with the old lug nuts.
    Sunnier[QUOTED] likes this.
  30. Mar 1, 2019 at 6:20 AM
    #4620
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    This looks good. I'm glad they don't make us run a front plate in TN.
