  1. Jan 17, 2023 at 6:06 PM
    Looks lower to me
  2. Jan 17, 2023 at 6:18 PM
    With those two pics to compare, looks higher in rear, lower in front to me.
  3. Jan 17, 2023 at 6:22 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    And that was the other tire I'm interested in. The Baja Boss.
    lsaami[QUOTED] likes this.
  4. Jan 17, 2023 at 6:59 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    the boss AT or boss MT?. My trail country's now rebranded Baja Legends are a hybrid AT/MT and are still fairly loud on the road. Not Patagonia loud, but still mildly annoying.
  5. Jan 17, 2023 at 7:04 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The AT. Lots of positive reviews on these too.
  6. Jan 17, 2023 at 8:15 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    You don't think the absence of your bedrack has anything to do with it? Regardless of your reasoning, "Nothing rides like a king."
    Casper421[QUOTED] and oscardog86 like this.
  7. Jan 17, 2023 at 8:16 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I'm running the exact same configuration as @KNABORES but I don't see much light from them. Bumper light bar works wonders for high beams though.
    Aftermarket housings huh. I hear so many mixed things about running aftermarket housing that I've stayed away from them but I'm wondering if my stock ones are causing my issues. I have sanded and clear coated them but they never did really clean up great. It got rid of the yellowing but still has a haze to it.
  8. Jan 17, 2023 at 8:50 PM
    Casper421
    In the woods
    06 DC
    It definitely has a lot to do with it. I lost 220lbs with the rack/tent. Still have the swing cases and “winter” box but not much weight compared to before, only 150lbs. A camper shell is gonna be put on soon so that will help some with the ass end.
    Plan is to crank the hell out of the Icons and see where Im at with lift and ride. If I can’t achieve the lift and ride I’m after, Kings it is. It’s been a regret since buying the icons 3 years ago.
    oscardog86 and RUSTYNUTS[QUOTED] like this.
  9. Jan 17, 2023 at 8:50 PM
    daveeasa
    David
    I swear I got boned on one side of Oem headlight. Leaks a bit and had that trouble with the ball joint. I might replace it while they are still available.
    surprised @empty_lord is using that thing. I’m running a cheap Chinese harness. Need to get my HS installed. Not enough time.
    shifty` likes this.
  10. Jan 17, 2023 at 9:10 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    NOTHING rides like a king.
    I just bought a pair of king long travel rears. :anonymous: next up, SUA, bedcage….
  11. Jan 18, 2023 at 11:57 AM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Ya still have mine sitting in the garage. A a hellwig
  12. Jan 18, 2023 at 1:17 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    Replied to your classified post and it seemed like you pulled it down altogether?
    Voss[QUOTED] and FrenchToasty like this.
  13. Jan 18, 2023 at 1:28 PM
    Voss
    2003 AC TRD 4x4
    Oh I remember. Mods took it down. Pm me, I still have it
    txagg[QUOTED] and FrenchToasty like this.
  14. Jan 18, 2023 at 4:45 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Found my slow coolant leak, pretty stoked it’s not something else.
    I did the dirty Darryl coolant bypass, a while back, the hose clamp isn’t the easiest to get to and can interfere with the coolant temp sensor plug. I think I got it right today, sprayed the area with water, and will check back in a few days to see what’s cooking 1EAE9DDC-F219-40F3-B20D-BE4BA7BA0C07.jpg
    I discovered this while waiting for paint to dry, I painted all my background sheet metal on the front of the truck………. Black!!!! I’m hoping this will make the bumper stand out better since I won’t have contrasting grhay colors behind it to distract. I’m not sure that made any sense, but I’d like to just trust my actions:) 4687A4D7-E1FF-4AAF-88F7-B22CF1D8D02A.jpg
    NUDRAT, robabeatle, 912 and 8 others like this.
  15. Jan 18, 2023 at 4:49 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    What is the reason for this Mo? I'm not familiar with dirty Darryl.
  16. Jan 18, 2023 at 4:53 PM
    FrenchToasty
    Mo
    Bone stock
    Hahaha super dirty!
    Hot coolant is passed thru the throttle body normally, supposedly to keep the butterfly free in movement. Also sending hotter air into the intake………
    Cooler intake temps, cooler air, burn, better combustion(this is if i was subbing for bill Nye……)
  17. Jan 18, 2023 at 5:01 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    don't plan any trips up north or you'll find out why the run coolant through the throttle body. ;)
  18. Jan 18, 2023 at 5:07 PM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Intrigued but have no idea what you mean, haha. Care to elaborate?
  19. Jan 18, 2023 at 5:08 PM
    oscardog86
    Southern California
    Also intrigued but have no idea what you mean, haha. Care to elaborate?
  20. Jan 18, 2023 at 5:11 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    cold + hot mixing = frost. frost in your throttle body = dead butterflies = stranded on the side of the road in -50F windchill.
    A lot of people in the warmer climates will bypass this since cooler air is denser, allowing for more HP theoretically. Frost isn't exactly an issue in Las Vegas or San Diego.
  21. Jan 18, 2023 at 5:12 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    <insert gif here of someone jamming screwdriver into throttle plate during snowstorm to get truck moving>
  22. Jan 18, 2023 at 5:15 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I’m gonna throw out a wild guess and say it’s because the air and fuel mix better when the throttle body isn’t frozen. We don’t freeze down here. Could be completely wrong
  23. Jan 18, 2023 at 5:21 PM
    FrenchToasty
    Mo
    Bone stock
    I literally live in the devils anus! It’s always shorts and flops weather.
    805Tundra, txagg, shifty` and 5 others like this.
  24. Jan 18, 2023 at 5:31 PM
    Jack McCarthy
    Bill
    North of Boston
    You can always move to Flagstaff to cool off somewhat during the summer. At 7000 ft, they should be cool enough.
  25. Jan 18, 2023 at 5:34 PM
    FrenchToasty
    Mo
    Bone stock
    It’s a beautiful place to visit, but I’d never live there. Also, that’s why we have T2S!
  26. Jan 18, 2023 at 5:41 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    *Theoretically
    There are plenty of vehicles without any heat to the throttle body and they don't have problems with freezing.
    Only thing I've ever had it happen to is a snowblower.
    des2mtn and FrenchToasty like this.
  27. Jan 18, 2023 at 6:11 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    I may have been exaggerating a bit for comedic effect. :thumbsup:
    NUDRAT, des2mtn, FrenchToasty and 2 others like this.
  28. Jan 18, 2023 at 6:29 PM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    Ouch.. I bought mine back in 2019 for $160 from Discount Tire. They still mostly look new, but I might've put maybe 15k miles on them.
  29. Jan 18, 2023 at 6:30 PM
    "Satanus"
  30. Jan 18, 2023 at 6:34 PM
    FrenchToasty
    Mo
    Bone stock
    The bleached beach house
    txagg and shifty`[QUOTED] like this.
