  1. Jan 13, 2023 at 7:10 PM
    Tripleconpanna
    2021 TRD PRO CM; 2011 SR5 SC'd DC; 2008 SR5 CM
    Do you have a sunroof? If so, your drain hole(s) are probably clogged up. When they clog, the water pools up and will run into the headliner resulting in it running through the roof area and exiting in the overhead center consoles and at the grab handles. To fix, there are 4 small holes in each of the sunroof's corners... If you open the sunroof up and look to the corners you should be able to find them. Take a long piece of weed trimmer cord and feed it through each of the openings and down into the fender areas (several feet of cord). The water drains just rear of the front tires and forward of the rear ones. Once you've cleared them (the holes out) w/the trimmer cord verify they are draining properly by pouring a small amount of water into the sunroof channel near the holes and you should see the water the running freely out of the body panels and onto the ground.
    If you don't have a sunroof, I have no idea... :thumbsup:
  2. Jan 13, 2023 at 7:14 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    See this... you've been cheating on us with Instagram? Naughty Naughty...
    40 lashings for you.
    :deadhorse:
    shifty`, bmf4069 and Jack McCarthy like this.
  3. Jan 13, 2023 at 7:34 PM
    Jack McCarthy
    Jack McCarthy I’ve got my eye on you.
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Nope. No sunroof.
  4. Jan 13, 2023 at 8:01 PM
    Tripleconpanna
  5. Jan 13, 2023 at 9:15 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I've had leaks. If it were dripping onto the back of your fusebox, that would be at the cowl/bottom corner of windshield. The spot above that which is likely your culprit, is the conjuncture where the roof rail seals 'T' into the windshield seal. Roof rail seals are the rubber strips embedded in the roof that run from the windshield to the back glass. The problem is that the ends of that seal, tuck under/into the windshield seal, and rely on some type of sealant applied in manufacturing, that will eventually fail. The bad news (especially in your case) is that the water intrusion you see, is rust-rotting out the body under the seal, which you can not see. In my case, the rust had caused swelling of the underlying steel, specifically the windshield flange, putting pressure against the edge of the glass, until ultimately it sent a crack down and across my windshield. Of course removing the windshield isn't practical, so pulling up the other seal would be the best way to put your eyes on it. I warn you, there are metal pieces in the ends and I don't think it's possible to remove the strips without destroying them, the ends anyways. I tried and failed. I still need to replace them and they're about $150 for the pair
  6. Jan 13, 2023 at 9:19 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    If you're desperate to stop the water from coming in, you could smear sealant around the area where the seals come together, but thats an unattractive and short term fix that won't address the rust issue
  7. Jan 13, 2023 at 10:25 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Cleared my TPMS light!
    TPMS - Over the last 6-7 years, I've actually bought 2 sets of Denso TPMS. America's Tire (Discount Tire to most of you) has been unable to get my 2006 Tundra to recognize them. America's Tire and a couple of other places have told me I need to go to Toyota. I recently went by my local Stealership and asked, they quoted 2 hours at $190.00/ea to program my TPMS. I purchased an Autel MaxiTPMS TS501 from Amazon for $199. It took about 20 min to register and update the tool, then took about 15 minutes to read my TPMS and program them to my OBDII. No more light! Worked great and very easy.
    NUDRAT, shifty`, txagg and 3 others like this.
  8. Jan 13, 2023 at 10:32 PM
    SoCalPaul
    Paul
    I remember some people have had the 3rd brake light leak. It gets into the headliner and whe braking, it comes out the A-piller, sun visor or roof console. Good Luck!
    NUDRAT and Jack McCarthy[QUOTED] like this.
  9. Jan 14, 2023 at 5:04 AM
    912
    912 @best_gen_tundra
    Western Slope, CO
    2005 DC 4x4
    Ha, I think it was partially as @RUSTYNUTS said, and also a throwback to the early days of another MC forum I was active on in the 2000s. It was an all-purpose salute in that community! :bikewheelie2:
    Honestly, IG is so much easier to keep up with. :rofl: I love this forum and [most of] you guys, but every time I log in I get overwhelmed with 500 pages of this thread, not to mention all the other threads! I can't even begin to crack into the Lunch Table Discussion :facepalm:
    RUSTYNUTS[QUOTED] and shifty` like this.
  10. Jan 14, 2023 at 6:09 AM
    bmf4069
    bmf4069 Scored 4 touchdowns vs Andrew Johnson High School
    Beau
    TX
    02 AC sr5 4wd v8
  11. Jan 14, 2023 at 7:09 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yep. I'll have another one soon when we do my lower control arms.
    @Tundra2 's manly hand
    RAV4 shocks
  12. Jan 14, 2023 at 9:38 AM
    shifty` Got patience on my neck like a cold, cold knife
    Amazing how the chain store couldn't make it happen. It's not f'ing rocket science as long as you have the hex IDs off the sensors and properly clear out the old sensors. If you don't have their IDs, I'm not sure how you handle it, though I've seen people mention "sniffers" you can buy to pick up on anything transmitting from your tire. That's a rabbithole I haven't gone down, though. May need to in the near future.
  13. Jan 14, 2023 at 9:58 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  14. Jan 14, 2023 at 11:18 AM
    Jack McCarthy
    Bill
    North of Boston
    Looks like we have the new Toyota call sign. I'll be sure to use it when I see a fellow Tundra owner passing me on the road. :rofl:
    bmf4069, oscardog86, 912 and 3 others like this.
  15. Jan 14, 2023 at 11:22 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    If i dont stumble across the lexus badges, i might turn my emblem hole into a light hole.
    Tundra2 likes this.
  16. Jan 14, 2023 at 4:10 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  17. Jan 14, 2023 at 8:36 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    FTFY
    bmf4069 likes this.
  18. Jan 14, 2023 at 8:50 PM
    whittkl4
    whittkl4 New Member
    Lee
    2002 sr5 V8 4x4
    Have a couple and before and during truck updates. Installed freedom off-road adjustable coilovers in the front and rear shocks. Truck sits almost perfectly level now after adjusting the coilovers a bit. They ride great.
    Grinded down all of the bad paint, rust, dents and scratches. Stripped off all of the bed liner from my shell. Pulled dents with sheet metal screws. Smoothed my lines and dents as best I could with bondo. And picked up a set of five new wheels and tires off of a 2022 Ford bronco big bend for 500 bucks. Bridgestone dueler a/t 255/75/17. I'm going to take off all of the badges and paint them black and finish sanding down the truck. Then I'm going to take it to maaco for the single stage urethane with integrated clear. Going to change the color to silver and get the shell to match. I'm pretty pumped to get it done! Not too concerned about the maaco paint job. I am pretty rough on the truck so I'm afraid to spend more than 1k on paint that I'm sure I will scratch up again in the near future
    Do you guys thing the wheels and tires will work.l? Slightly taller than my 265/7516s. Wheels are the same bolt pattern but not sure on the offset. Going to try them but figured if they didn't work I could resell them for more. Good deal.
    bmf4069, oscardog86, NUDRAT and 5 others like this.
  19. Jan 14, 2023 at 9:46 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Hub bore looks a little small.
    Ghostly.- likes this.
  20. Jan 14, 2023 at 11:20 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I second this. May have to run a adaptor spacer if you can find one. Also need to be sure lug hole size is for m12 not m14.
  21. Jan 14, 2023 at 11:35 PM
    daveeasa
    David
    PHM?
    Jack McCarthy likes this.
  22. Jan 15, 2023 at 5:20 AM
    whittkl4
    whittkl4 New Member
    Lee
    2002 sr5 V8 4x4
    What kind of adaptor spacer would I need?
  23. Jan 15, 2023 at 6:20 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Most toyotas use a 106mm hub bore, and i guess broncos use a 93mm hub bore.
    fun fact, bronco raptors use f150 hubs because ?83mm?
    oscardog86 likes this.
  24. Jan 15, 2023 at 9:46 AM
    whittkl4
    whittkl4 New Member
    Lee
    2002 sr5 V8 4x4
    Would a 1 inch will spacer with new lugs on it solve my issue?
  25. Jan 15, 2023 at 10:21 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    if you use bronco spacers, you'd have to hog out the back side to fit the toyota hub boss.
    Not sure i'd trust lug centric spacers.
    whittkl4[QUOTED] likes this.
  26. Jan 15, 2023 at 11:03 AM
    You’d have to use a Toyota adapter (spacer) that was hubcentric on the back side only, matching the Toyota bore size. Lug centric on the face to match the stud size and spacing of the Bronco rims. Someone here recently went through this with Gen 3 6 lug wheels and spent way more than they thought they would and weren’t 100% happy it sounded like.
    oscardog86, NickB_01TRD and whittkl4 like this.
  27. Jan 15, 2023 at 2:26 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I think there are companies that will custom make spacers but really at this point it would be worth finding better wheels
    whittkl4 and KNABORES like this.
  28. Jan 15, 2023 at 4:33 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    May I join in?
    s0oauikFwp1K0rXDiN7-TKvBpawOX9Tqgza-5YRU_b71202f7e88bd0f2017fa642a4c03a606bb8a8cd.jpg
    Got my electric fans put in. My truck is now actually capable of reaching operating temp in the winter. Thing sits pretty consistently at 169, give or take 2-3 degrees. But oh man, there is so much space to work on it now. Gone are the days of me destroying my hands to swap the serp belt.
    8kEkTNLc9ZCtKy6pbtSppsuBkZjoAEPaDnYuy6iz_c4981a1bcaee26b530f5f8c7f7d099908e30f5f8.jpg
    bmf4069, 912, NUDRAT and 8 others like this.
  29. Jan 15, 2023 at 7:36 PM
    NickB_01TRD
    Nick
    KY
    Yeah he spent around $500 for them.
    Thread Link
    whittkl4 likes this.
  30. Jan 15, 2023 at 11:49 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Swapped out my 3rd member. From open diff with 3.91’s to locker with 4.88’s. Quite a difference I notice immediately. Can’t wait to rip it up on dry pavement, and the locker on dirt.
    @assassin10000 i know this will probably sound silly but there’s no need to break in used gears correct? (YOUR gears as they were)
    bmf4069, txagg, Ghostly.- and 5 others like this.
