  1. Feb 27, 2019 at 3:17 PM
    #4531
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    The O/D was off while I was going up the hills from Escondido to Ramona.
    I usually have it on
  2. Feb 27, 2019 at 4:40 PM
    #4532
    sakana
    sakana New Member
    2002 Tundra AC Limited 4X4
    MT Classic II, Bilstein 5100, 4.88's, BAMuffler catback, 250cc 12-hole injectors, Powerstop Z36 brake kit, Hellwig helper spring and rear swaybar
    Which system is that? Just curious. I am working with Keith and his buddy at a local shop for install of gears, injectors, and cat-back exhaust. I am also going with the most mild/stock-sounding setup. Initially, I wanted to do headers also, but they don't have CARB approval, so I decided against it. So I don't think I'm going to see any significant gains HP gains from just a catback. Maybe just some torque. That would be fine. I need a new muffler anyway.
  3. Feb 27, 2019 at 4:57 PM
    #4533
    Professional Hand Model
    Hand Protectors
    Got the transfer case and transmission buffed.
    Tweaked the headlamp adjustments tonight and did a final securing of the top hold down fastener now that the fogs (9006) are in and confirmed performing beautifully. Highly recommend! So stoked on these new fogs performance that I’m eyeballing the 9003 for the new headlamps bulbs.
    Only thing holding me back is if they are too bright for city driving. The fogs I didn’t worry about as they are bumper mounted (lower than most cars sight vision) and by design diffused side to side only projecting forward slightly.
    Even with these 9003 headlamps having a sweet cut off line and no scatter, they still project forward and are mounted high (right a sight level) for compact vehicles. Twice the brightness might be too much.
    TX-TRD1stGEN, Jerry311SD and bmf4069 like this.
  4. Feb 27, 2019 at 5:02 PM
    #4534
    Hand Protectors
    Rheywood456 likes this.
  5. Feb 27, 2019 at 5:08 PM
    #4535
    sakana
    sakana New Member
    Yeah, I wish I could do headers. Supposedly these JBA's look remarkably like TRD headers which did have a CARB approval here in CA. I remember the real TRD units being pretty pricey when they were still being sold, and used ones are like unicorns nowadays.
  6. Feb 27, 2019 at 5:18 PM
    #4536
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Are we supposed to turn off o/d when towing?
    Filthyphil likes this.
  7. Feb 27, 2019 at 5:20 PM
    #4537
    Hand Protectors
    Yeah. These are out of my realm based on the investment vs. value of the truck. I’m tinkering with about $300-500 more spending on the 02’ before the $ gets shut off. My rational for everything so far is based on this trucks long life. She could fetch $8 maybe $10k (based on dumpy cregssliss mostly poorly maintained crap people are dumping out there). I’m just over $5k now in spending this year.
    You’ll be stoked on the injectors. Your truck will feel different in a good way. What gears you doing? I’m sure they’ll be a real nice partner with the new injectors.
    because_wumbo-truck likes this.
  8. Feb 27, 2019 at 5:26 PM
    #4538
    Hand Protectors
    I never have unless towing and it was windy (strong headwind) pushing hard against the trailer when doing highway speeds. Or, towing up hills. The truck usually lets me know it doesn’t like these conditions and thats when the O/D goes off.
    Never have turned it off in regular driving unless messing around.
    speedtre likes this.
  9. Feb 27, 2019 at 5:44 PM
    #4539
    sakana
    sakana New Member
    I'm right there with ya. Trying to make my '02 last for the long haul. I considered buying a new truck, but I just don't need a behemoth, or a $700/mo car payment. Investing some dollars in my still very nice '02 seemed like a better way to go. I'm liking the recent suspension and braking upgrades. It drives so smooth now, it feels like I'm driving a very tall comfy Camry.
    A little more grunt for towing is what I'm after now. I called Keith asking about headers, injectors, and exhaust. He said my best bang for the buck would be to re-gear, and he specifically recommended the 4.88's. I was a little apprehensive about the 4.88's since I have no plans to run big tires, but after doing some research, I think it will be fine. I'm not afraid of the higher RPM's. The rumor is that it lessens the load on the entire driveline, and can even result in less fuel consumption. I am not expecting a miracle there, but I'm wondering if I can try towing without turning off O/D after the re-gear. Without turning off O/D, the RPM's at my typical towing speed of 60mph should be very manageable even with 4.88's.
  10. Feb 27, 2019 at 6:39 PM
    #4540
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Really curious what your experience will be with 4.88 and stock tires. I run 4.56 and 33" tires and always thought of how quick my truck would be with stock tires.
  11. Feb 27, 2019 at 6:47 PM
    #4541
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I hear yes and no. Mainly because OD does some weird thing to something and then something goes boom. Sometimes. I pulled a 12,000lb trailer with my E-250 in OD and nothing happened. That was 5 years ago. We usually pull trailers between 2,000 and 7,000 once a week and I haven't had any problems.
  12. Feb 27, 2019 at 6:50 PM
    #4542
    Deslock23
    Deslock23 New Member
    2003 Tundra SR5 AC 4wd
    5100’s at 5th notch, Add-a-leaf, diff drop.
    I'm running a Spintech https://spintechmufflers.com/6000-pro-street/ myself, sounds great going down the highway or pulling into a parking lot. You will notice it more on long trips, but not so much as to get a headache from it.
    Darkness likes this.
  13. Feb 27, 2019 at 6:53 PM
    #4543
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Same muffler I run.
    Deslock23[QUOTED] likes this.
  14. Feb 27, 2019 at 7:00 PM
    #4544
    Deslock23
    I knew there was a reason I recognized you as a man of unbridled civility and taste.
  15. Feb 27, 2019 at 7:02 PM
    #4545
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Same here, a black Tundra practically wears a tuxedo.
    Filthyphil and Sunnier like this.
  16. Feb 27, 2019 at 7:23 PM
    #4546
    Casper421
    In the woods
    06 DC
  17. Feb 27, 2019 at 7:27 PM
    #4547
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    i'll be looking around. Gotta get the body work done first. hopefully it wont take long
    @Casper421 what grill do you have? mines damaged. thinking the mesh would be cool with the color change
  18. Feb 27, 2019 at 7:55 PM
    #4548
    Casper421
    In the woods
    06 DC
  19. Feb 28, 2019 at 1:10 AM
    #4549
    empty_lord
    05 rollover special
  20. Feb 28, 2019 at 4:06 AM
    #4550
    Hand Protectors
    Darkness and bmf4069 like this.
  21. Feb 28, 2019 at 4:08 AM
    #4551
    Hand Protectors
    Git ya some nu injecters main!
  22. Feb 28, 2019 at 5:17 AM
    #4552
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    I just wonder what a mechanic would charge to install them. That's not something I feel comfortable doing myself.
  23. Feb 28, 2019 at 8:52 AM
    #4553
    speedtre
    speedtre New Member
    Inland Northwest
    Page 397 in my 2006 owners manual....
    Personally, I will still use O/D if I'm towing a not too heavy load on completely flat ground with normal wind resistance. If it's a strong headwind, there are any hills, or it was heavy (I've never towed what I would call heavy which is 50%+ of the maximum recommended tow weight) O/D comes off. It's just easier on the transmission.
  24. Feb 28, 2019 at 9:38 AM
    #4554
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Tuxedo with braces and a mullet here. :rofl:
  25. Feb 28, 2019 at 10:38 AM
    #4555
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Just need some stick-on side vents to complete the look! :thumbsup:
  26. Feb 28, 2019 at 11:33 AM
    #4556
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Oh man :rofl:
    Mine has a fashion faux pau with the fog lights
  27. Feb 28, 2019 at 11:49 AM
    #4557
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    One step closer .....
  28. Feb 28, 2019 at 12:55 PM
    #4558
    Hand Protectors
    Figured out the Transmission Breather location today. I bought a new one a few months back (wrong part) thinking it was the two breathers next to the battery (front diff and ?). Anyways, this pic looks like the one I wrongly purchased so I’ll swap it in soon.
    FirstGenVol, bmf4069 and lsaami like this.
  29. Feb 28, 2019 at 12:58 PM
    #4559
    Hand Protectors
    Hauled about 1600 lbs. of stone today. The bump stop was only about and inch off the bump plate and never once bottomed out. Take that 3rd Gen’rs!
    Sunnier, NUDRAT, Outbound and 3 others like this.
  30. Feb 28, 2019 at 1:04 PM
    #4560
    Hand Protectors
    Scored on some sound damper padding that will be going behind the rear seats after they get removed. This should reduce any of the last of the locations noises possible as the whole cab has already been done except for the roof (ain’t happening).
    batsquatch and TUNDRAIN520 like this.
