  1. Feb 26, 2019 at 9:02 PM
    #4501
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
  2. Feb 26, 2019 at 9:47 PM
    #4502
    because_wumbo-truck
    Jon
    Houston, Texas
    Hmm maybe you can find out for me if there's a larger Toyota throttle body that can fit my 4.7vvti
  3. Feb 26, 2019 at 9:49 PM
    #4503
    because_wumbo-truck
    Jon
    Houston, Texas
    I have those same center caps. Unfortunately they're about 2mm too small to fit my KMC Enduros
  4. Feb 26, 2019 at 9:50 PM
    #4504
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    i have 2 throttle bodies at home right now... a 2gr-fe one (maybe? doubtful) and a 1zz throttle (way smaller)
    id just send a factory one to maxbore and have it bored out honestly
  5. Feb 26, 2019 at 10:39 PM
    #4505
    because_wumbo-truck
    Jon
    Houston, Texas
    I heard the 5.7 throttle body may work on the 4.7 and in combo with larger injectors could give more power.
  6. Feb 26, 2019 at 10:45 PM
    #4506
    empty_lord
    05 rollover special
    depends on if the hole in the plenum is big enough. but if i get a chance i'll dick around with it. But if the hole in the plenum is smaller than the hole on the 5.7 throttle you would be creating turbulence you dont want because of the step up the air would take
  7. Feb 27, 2019 at 4:04 AM
    #4507
    the red
    the red the threat is real
    New Brunswick, Canada
    Unless there's enough meat to shave out and do a port match. It would probably have to be fairly close for that though.
    because_wumbo-truck likes this.
  8. Feb 27, 2019 at 4:21 AM
    #4508
    Professional Hand Model
    Hand Protectors
    I’ll be buffing the top of my transmission and transfer case today. Next week, busy putting a coat of wax under the bedside.
  9. Feb 27, 2019 at 4:24 AM
    #4509
    Hand Protectors
    Get the injectors in first. Talk with Keith about the throttle body when on the phone discussing your injectors. He’ll talk your ear off about truck stuff and how to improve it. He knows his stuff. Call him.
  10. Feb 27, 2019 at 4:32 AM
    #4510
    Hand Protectors
    Go check out his site. The complete system (he has many) set up I’d like is a stock sounding one. Its over a grand in cost (parts) and gives 40 more HP due to the manifold design. Wait till you see TRD cost and compare the two.
  11. Feb 27, 2019 at 4:36 AM
    #4511
    Hand Protectors
    @FirstGenVol
    Are those your girl friends? They look like models.
  12. Feb 27, 2019 at 5:13 AM
    #4512
    because_wumbo-truck
    Jon
    Houston, Texas
    You need the long tube headers and the race exhaust for those kinda numbers.
  13. Feb 27, 2019 at 5:14 AM
    #4513
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yeah. Don't tell my wife though.
    bmf4069 and Darkness like this.
  14. Feb 27, 2019 at 5:22 AM
    #4514
    Hand Protectors
    I guess I’ll not worry too much about the oil weeps. Nothing online about stopping it except switching back to dino oil, but even then some say the weeps persist.
    The best explaination I saw was that the Synthetic molecules are enginneered with such perfection in uniform size that they line up and can squeeze out of the smallest gaps. Evidenced with my eye as my seep seems like a perfect line all the way around the seal (like its a perfect ring marching down the pan). Dino oil molecules are more random in size and can block a gap. The detergent nature of Synthetic is removing the sludge that would normally stop a weep so this, plus the uniform molecules, is where the weep happens.
    I like the Synthetic thats in there now, as the engines really purrs with it and the last oil change with 2,800 miles seemed dirty from the ‘cleaning action’. A trusted auto site says to make sure to change the oil filter more often after the first few changes with the Syn oil to filter out the sludge thats been cleaned off.
    I’ll keep on the same track for now, as many who have made the switch say after the second oil change that things may improve with the seals. Not sure switching to ‘High Mileage’ will work, as the reviews say otherwise and Mobil doesn’t state specifically that this will fix the problem.
    FirstGenVol likes this.
  15. Feb 27, 2019 at 5:22 AM
    #4515
    Hand Protectors
    Ok. Its our secret.
  16. Feb 27, 2019 at 5:27 AM
    #4516
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    After I did the purge last month I switched to Mobile 1 full syn as well. I've not seen any oil on the ground yet but I need to crawl under there and see if I have any minor leaks. Prior to this, I was running a synthetic blend and I have no idea what the original owner used for the first 14 years. I'll take your advice and change the oil and filter well before the normal 5,000 miles.
  17. Feb 27, 2019 at 5:34 AM
    #4517
    Hand Protectors
    Sounds good. Just to clarify, I’ve no oil on the ground. Its a VERY slow weep. A thin layer of oil on the pan (below gasket) in perfect harmony.
    I’ve put up this guys site before. He uses the W. Edwards Deming (Toyoda post WWII savior) philosophy.
    http://www.agcoauto.com/content/news/p2_articleid/122
  18. Feb 27, 2019 at 5:38 AM
    #4518
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I went to full synth in my.... think it was the Z3. Started hemorrhaging oil. Went to high mileage semi synth & things got better, but not as good as before. Gave it a couple oil changes & things were mostly acceptable, things that weren't got new gaskets.
  19. Feb 27, 2019 at 6:31 AM
    #4519
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Yeah they are going to be a bit to small. I'll make them fit.
  20. Feb 27, 2019 at 6:46 AM
    #4520
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I run the high mileage Mobil 1, no seepage here but my pan has never been removed or messed with.
  21. Feb 27, 2019 at 6:51 AM
    #4521
    Hand Protectors
    Neither has mine, to the best of my knowledge. I can see gray gasket (looks like fipg) squeezes around perimeter. Its tight up around this whole area. I wonder it the engine would need pulling to put on a new gasket?
  22. Feb 27, 2019 at 7:00 AM
    #4522
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I don't think it needs to be pulled but that strange thing you guys call a front diff might make it tricky.
    NUDRAT, TUNDRAIN520 and TX-TRD1stGEN like this.
  23. Feb 27, 2019 at 10:14 AM
    #4523
    empty_lord
    05 rollover special
    Trd exhaust is about 480 with my discount. But eh. That’s still to rich for my blood
  24. Feb 27, 2019 at 10:22 AM
    #4524
    because_wumbo-truck
    Jon
    Houston, Texas
    Keep is posted please .especially on the frobt.
    Jerry311SD[QUOTED] likes this.
  25. Feb 27, 2019 at 1:45 PM
    #4525
    empty_lord
    05 rollover special
    this is what the tundras colors will look like. And the wheels too.
  26. Feb 27, 2019 at 1:47 PM
    #4526
    Hand Protectors
    1D6?
  27. Feb 27, 2019 at 2:10 PM
    #4527
    empty_lord
    05 rollover special
    1h5
  28. Feb 27, 2019 at 2:18 PM
    #4528
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Today I went 185miles on a half tank of gas.
    Matty4wd and because_wumbo-truck like this.
  29. Feb 27, 2019 at 2:34 PM
    #4529
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Just curious, why drive with O/D off? I thought that just burned more gas?
    NUDRAT likes this.
  30. Feb 27, 2019 at 2:41 PM
    #4530
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Towing?
