  1. Dec 19, 2022 at 2:27 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I did the Hellwig rear sway bar on mine and it made some difference but not huge. New HD leaf springs, made a massive difference in body roll and driving manners.
  2. Dec 19, 2022 at 2:32 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    bmf4069 and RUSTYNUTS like this.
  3. Dec 19, 2022 at 2:41 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    So my repair place tells me they can most likely get a replacement fuel line to the fuel rail even if it's obsolete. Huh?!?
    He tells me some dealers they work with hold onto stock of obsolete parts that only shops can obtain...hey not fair! Sounds like BS to me.
    Guess I won't truly know unless I have to test that theory.
    oscardog86, bmf4069 and shifty` like this.
  4. Dec 19, 2022 at 2:55 PM
    rock climber
    On my east coast rotted out T100, the tank had a leak at the top line. The shop I took it to said he could make a custom braided line from the tank to the fuel rail. I ended up getting a junkyard tank and all of the lines so didn't need that, but from what I remember it wasn't crazy expensive.
    That was in Seattle and the shop hated that truck since they weren't used to dealing with rust and they couldn't use heat since it was fuel lines. He was happy when the frame cracked and I sold it
    NUDRAT and Jack McCarthy[QUOTED] like this.
  5. Dec 19, 2022 at 3:17 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Indianapolis. $125
  6. Dec 19, 2022 at 3:21 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    Man, those stupid springs are so expensive though! I have airbags and new shocks to throw on it, was hoping that would do the trick
  7. Dec 19, 2022 at 4:49 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    No magnet for the gas door?
    txagg and Tundra2 like this.
  8. Dec 19, 2022 at 4:52 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Naur! Fuck it! Let it fly!
    Mr.bee[QUOTED] and Jack McCarthy like this.
  9. Dec 19, 2022 at 5:07 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    TW Express it up to you. Geez.
    Midwest TW Express | Tacoma World
    Since you guys broke "my" lunch table, guess I'll start some new threads. :facepalm:
    bmf4069, txagg, Tundra2 and 3 others like this.
  10. Dec 19, 2022 at 5:09 PM
    shifty` Goons of Hazzard
    It's coming back, I believe.
    Tundra2 and NUDRAT[QUOTED] like this.
  11. Dec 19, 2022 at 5:33 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    RUSTYNUTS and Mr.bee like this.
  12. Dec 19, 2022 at 5:41 PM
    daveeasa
    David
    Picked up my FGT, shop re-clocked one of the shock hoses so I no longer hose rub while turning. Man I wish I had a shop. Need to get going on surveyors to make that happen.
    oscardog86, txagg and NUDRAT like this.
  13. Dec 19, 2022 at 5:41 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    "How come you've got you left cheek marked R?"
    @Tundra2 takes a selfie shot. "No, see - it's on the right cheek".
    (J/K @T2 - it's just you posted all those backwards selfie shots in the early days)
    shifty`[QUOTED] likes this.
  14. Dec 19, 2022 at 9:17 PM
    pock
    pock New Member
    USA
    2005 Access Cab 4.7L V8 4x4 SR5
    NUDRAT, oscardog86 and robabeatle like this.
  15. Dec 19, 2022 at 10:11 PM
    empty_lord
    05 rollover special
    Door on… cannot open. Fender to fubar. Damnit
    des2mtn likes this.
  16. Dec 20, 2022 at 4:13 AM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
  17. Dec 20, 2022 at 4:25 AM
    That sucks. On to the next steps.
  18. Dec 20, 2022 at 6:01 AM
    Approaching 9 years on my timing belt. Last changed in 2014. May do a thorough overhaul on the truck when it’s time. Front wheel bearing, maybe UCA, LCA and ball joints. New rear leafs would be nice too.
    NUDRAT, txagg, shifty` and 5 others like this.
  19. Dec 20, 2022 at 6:21 AM
    daveeasa
    David
    Don’t stop there :)
    Taking mine to the dealer today. Bracing for impact on the codes.
    NickB_01TRD, CodyP and des2mtn like this.
  20. Dec 20, 2022 at 6:34 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    What he said. Gears and lockers too.
    NUDRAT and oscardog86 like this.
  21. Dec 20, 2022 at 7:28 AM
    Jack McCarthy
    Bill
    North of Boston
    Stopped by the shop doing the fuel lines. Guy broke off some of the clips holding the fuel line to the frame rail and then tries to blame on someone who might’ve done work on it in the past.
    It’s original! Nobody has touched it but him. Own up. Sheesh. I don’t care too much but I wish they were more truthful.
  22. Dec 20, 2022 at 7:31 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Ironically, you can still buy the clips...
  23. Dec 20, 2022 at 7:40 AM
    Jack McCarthy
    Bill
    North of Boston
    I Know. I wasn’t too worried. I’ll bet when I check it out most of the clips will be broken and it’ll be zip tied to the other lines.
    Exactly like how they said they don’t do things.
  24. Dec 20, 2022 at 8:49 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Talked myself into a hydraulic press.
    the center (and leaf on the ground) are 2nd gen pieces, and a have flat spots, so i'll have to roll em out a bit, might kink the ends to follow the front & rear leafs radius (1st gen leafs). Leaf closest to the rad is just there for balance. Both will match, one set mounting to the top bolt bumper support bolts, the other mounting to the lower bumper support bolts. Plan to wear out a few holesaws before plating with 3/16.
    I'll try to fill the gap under the headlights with lights, and the gap under the grille with a winch.
    also realized my watertank saddlebags (for the motorcycle) could fit inside the bottom of the bed. Under the fuel fill hose. Can fit behind the axle, too. Outboard of the leafs. @ 1.32 gal each, all 4 is over 5 gallons. I know polo wouldnt complain.
    whats the smallest hose reel you've found? Couple smaller wheels and a retracing mechanism could fit in the bumper.
  25. Dec 20, 2022 at 9:09 AM
    rock climber
    txagg[QUOTED] and Jack McCarthy like this.
  26. Dec 20, 2022 at 9:46 AM
    Jack McCarthy
    Bill
    North of Boston
    Not the greatest of work for $413 but I didn’t have a lot of options… filter needs a zip tie.
    NUDRAT, shifty`, bmf4069 and 4 others like this.
  27. Dec 20, 2022 at 9:48 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  28. Dec 20, 2022 at 9:50 AM
    Jack McCarthy
    Bill
    North of Boston
    I give up. What’s it used for here?
  29. Dec 20, 2022 at 9:52 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    1/2" bender woulda been a better pic, but you get a roll of stainless tubing and fiddle with it until it fits.bonus points for ospho dipping all the hardware.
  30. Dec 20, 2022 at 10:15 AM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    That's not a bender. THIS is a bender:
