  1. Dec 17, 2022 at 10:56 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I leave for a few hours and all hell breaks loose. :notsure:
    NUDRAT, RUSTYNUTS, bmf4069 and 4 others like this.
  2. Dec 17, 2022 at 10:56 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    apparently so.
  3. Dec 18, 2022 at 8:43 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Gah!!
    fun fact: oem outer cv boots are fatter than aftermarket boots. I got the cv axle all put back, did a clearance check, and noticed the shock bolt was rubbing the boot when turning to the left. No problem, I’ll just turn the shock bolt around. My eibachs are only 3 years old at this point, it should be no big deal, right?
    wrong. Inner bushing sleeve is rusted to the bolt, so I ended up grinding the piss out of the nut/bolt to make it clear. Will address it when I need to replace shocks next. :censored::censored::censored:
    Man do I hate salt…
  4. Dec 18, 2022 at 8:44 AM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    Took the topper off. Took the plastic side rails off. Put down butyl tape everywhere. Put new seal on. Put topper back on. Took 2 Advil.
    NUDRAT, oscardog86, 805Tundra and 5 others like this.
  5. Dec 18, 2022 at 8:58 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Not something a torch and impact could have broken free?
  6. Dec 18, 2022 at 9:09 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    the impact broke the nut free, but the sleeve just spins inside the bushing. Only solution is to cut it out, which means replacing the bushing and bolt. I needed the truck for house supplies like a week ago.
  7. Dec 18, 2022 at 9:26 AM
    Jack McCarthy
    Bill
    North of Boston
    I’m with you on the rust hate. Been waiting a week to get my truck fuel line fixed after it rotted through last Sunday.
    lsaami[QUOTED] likes this.
  8. Dec 18, 2022 at 9:55 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Fuel lines are the only lines still original on my truck. I just pray and spray blaster surface shield every year.
    NUDRAT and Jack McCarthy[QUOTED] like this.
  9. Dec 18, 2022 at 12:05 PM
    Jack McCarthy
    Bill
    North of Boston
    Started the truck up today to make sure I haven’t lost enough pressure in the line I couldn’t get started.
    No immediate fuel line squirt so I should be good for having them starting it up when the tow truck gets there so it can be driven on the lift.
    Figure I’ll just ask them to cut the hard line at the fitting so they can zip it off with an impact if their flare wrench slips from grasping it.
    No luck myself with the flare wrench and rust penetrant but I don’t have the best tools for that.
  10. Dec 18, 2022 at 1:11 PM
    ryderboy
    ryderboy New Member
    06 tundra sr5 double cab
    So I spent the last 7 months dumping money into this truck. I got it just about where I wanted it and than this happened.
    robabeatle and Jack McCarthy like this.
  11. Dec 18, 2022 at 1:15 PM
    daveeasa
    David
    Ouch! You ok? I hope so.
  12. Dec 18, 2022 at 1:16 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Shit hope your ok!
    805Tundra likes this.
  13. Dec 18, 2022 at 1:18 PM
    Openbaffle
    Hope you are ok.
    805Tundra and FrenchToasty like this.
  14. Dec 18, 2022 at 1:19 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    Whoa, everyone ok?
    FrenchToasty likes this.
  15. Dec 18, 2022 at 1:19 PM
    shifty` Dead heads and frog legs. Mmm... cake mix!
    Noooooooo! WTF happened, black ice? Holy shit!
    Don't leave us hanging, any physical injuries? We all know the emotional trauma you must be going through. This is probably the single biggest fear any of us have.
  16. Dec 18, 2022 at 1:25 PM
    Openbaffle
  17. Dec 18, 2022 at 1:35 PM
    Jack McCarthy
    Bill
    North of Boston
    Damn. Hope your okay medically.
  18. Dec 18, 2022 at 1:47 PM
    ryderboy
    ryderboy New Member
    Thanks guy. I walked out of it without a scratch. Not even a bit sore. It was icy roads I corrected a few times and straight into the guard rail and it rolled
    NUDRAT, Openbaffle and Jack McCarthy like this.
  19. Dec 18, 2022 at 1:52 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm sorry. Can anything be salvaged?
  20. Dec 18, 2022 at 1:57 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    SOAB man! That sucks! Glad you are okay. Now for the insurance game. I would also like to mention how classy the first gen crew is getting. Been 45 minutes since you posted and nobody has asked about parts or buying it back from insurance.
    abcinv likes this.
  21. Dec 18, 2022 at 2:01 PM
    Jack McCarthy
    Bill
    North of Boston
    We’ve got a member here looking for an 05 master cylinder they discontinued and Toyota no longer sells the rebuild kits. If the 06 is identical, I’m sure he’d buy it from you.
    The buzzards are now circling…
  22. Dec 18, 2022 at 2:15 PM
    Jack McCarthy
    Bill
    North of Boston
    Think I might have to change my valve cover gaskets soon. Lost 1/2-3/4 quart of oil over the last 5-6 months
    txagg likes this.
  23. Dec 18, 2022 at 2:26 PM
    ryderboy
    ryderboy New Member
    tbh im not 100% certain on how all the insurance stuff works with getting the truck back. It had 90,000 so I thought about selling the motor and trans if things work out. It sounds like a pita
    oscardog86 likes this.
  24. Dec 18, 2022 at 2:31 PM
    Jack McCarthy
    Bill
    North of Boston
    They’ll offer you a buy back price after totaling out the vehicle and giving you your check for the blue book value and some upgrades you may have made if they’re recent and have receipts.
    I myself would be stripping off the new parts and putting back the old since they rarely give you full value. At least in my experience, YMMV.
  25. Dec 18, 2022 at 3:02 PM
    Openbaffle
    Will it help? I don't know. The cap looks good however. Also, I felt the need to get a torch today. Will be useful for many things. Including starting a camp fire in about 20 mins.
    NUDRAT, oscardog86 and Jack McCarthy like this.
  26. Dec 18, 2022 at 3:43 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    God damn you are lucky.
    I spent hours today frequency curve fitting with my dsp to produce this graph from my audio system:
    sportbike37, bmf4069 and Openbaffle like this.
  27. Dec 18, 2022 at 5:06 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    lost me at frequency. Nice graph, what's it do?
    NUDRAT, robabeatle[QUOTED] and CodyP like this.
  28. Dec 18, 2022 at 5:23 PM
    Did you check the torque on the bolts? If scared to check for fear of snapping, I'm telling you, AT-205 was really worthwhile for me.
    They'll come at you with blue book value. It will be low, unless you have a more-fair company for auto like USAA. They've done me very well in the past.
    Thing is, in most states, you're legally entitled to replacement value. Given it's low miles, that's in your favor to negotiate, you can use any of the similar-miled Bring A Trailer sales as comps to prove the value of your truck was much higher than blue book. Furthermore, if you have receipts for any of the upgrades recently, you can then factor that in, if it's damaged or they don't plan to let you keep it.
    You can always ask for the buy-back price too. Use it as a parts car for a new, higher-mile 1GT.
    If in doubt, get a lawyer, it'll be worth it. Insurance companies have a gaggle of them. Some employers offer free legal services as an employee benefit (mine does).
    But ... you never answered the big question: Leak status after double-bulb?
    ryderboy[QUOTED] likes this.
  29. Dec 18, 2022 at 5:49 PM
    robabeatle
    AZ
    The graph just tells me the expected quality of the sound. Missing the pound of a kick drum can be seen in a graph or trickier issues like out of phase drivers (one pushing while other pulling) can show up in the graph. It is one part of of using a digital signal processor, dsp, which can do other tricks like eq the tweets separate from the mids and delay the audio signal to each driver so the sound gets to you all at the same time to create a realistic soundstage. Its a rabbit hole that goes deep. My truck sounds fricken great right now and Im a noob at tuning.
  30. Dec 18, 2022 at 5:53 PM
    I was never capable of getting a solid grasp on this stuff. Always the installer, never the tuner.
