  1. Nov 29, 2022 at 6:08 PM
    That reeks of electrical issue.
  2. Nov 29, 2022 at 6:13 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Oh yea. It definitely is. Just trying to pinpoint it while it’s so intermittent is a nightmare
    oscardog86 likes this.
  3. Nov 29, 2022 at 6:14 PM
    Just for shits and giggles, did you unmount the fuse/relay box under the hood to check all the connections from the bottom?
    Maybe worth looking for signs of water damage/corrosion on the fuse/integration box in the cab?
  4. Nov 29, 2022 at 6:21 PM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    My double cab topper was made for a double cab and it leaks too!
    NUDRAT and Tundra2 like this.
  5. Nov 29, 2022 at 6:31 PM
    empty_lord
    05 rollover special
    I’ve had the intake manifold off to check for mice activity (there was, but nothing chewed) I’ve had the fuse block torn apart, I’ve swapped parts I had laying around from my truck… all the sudden it’s fine with all the shit it came in with.
    shifty`[QUOTED] likes this.
  6. Nov 29, 2022 at 6:31 PM
    empty_lord
    05 rollover special
    This trucks been at another shop for 3 months chasing this issue. They’re documentation showed they really dig into it as well.. it’s a weird issue
    shifty` likes this.
  7. Nov 29, 2022 at 7:22 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Agreed.
    I've always taken them off . . . for no particular reason other than 'fit', seems like the shell 'seats' better straight to the bed. . . but who knows.
    My last 2003 Tundra AC I had, I bought a shell and took them off before mounting the shell. Kept them, and gave them to the kid who I sold the truck to.
    The 2006 DC I have now which I bought from a neighbor has a Snug Top that was installed at the Snug Top Factory in Long beach CA . . . they removed the plastic plates as well . . but must have tossed them cause the guy didn't have them when I bought the truck.
    I don't like when you see the plastic plate peeking through between the cap & bed rail . . . but I'm a geek, so there's that.
  8. Nov 29, 2022 at 9:02 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I put some nice and bright and shiny Amber DRL bulbs in the little DRL spots in these new Chinesium quality headlights and I noticed they ain't lighting up! What the hell? Where the DRL relay or harness at? Thanks.
  9. Nov 29, 2022 at 9:18 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    I'm guessing you did the power wire corrosion check shake too? Might be worth adding a short 10ga power wire from batt to fuse box to check it (or use yours).
    Also did you swap ignition switches to see if a partially burnt contact inside?
  10. Nov 29, 2022 at 9:42 PM
    empty_lord
    05 rollover special
    ive done just about everything i can within the time thats been approved for diagnostic. including swapping the switch
    as of now its not acting up.. so keep test driving as i can.
    shifty` likes this.
  11. Nov 30, 2022 at 4:36 AM
    Openbaffle
    Thanks. Yea, the fit as-is is pretty clean and I don't see any of the plastic sticking through. It def leaks from the the corners, which I've addressed with the butyl rubber. I am going to to try sil-gylde as well on the rubber.
    Trailscape, bmf4069, NUDRAT and 4 others like this.
  12. Nov 30, 2022 at 6:09 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Go for it! Youll have memories that last a lifetime. Plus right now in California gas is $4.99 a Gallon! Yay, haha
    NUDRAT and Hi06silver[QUOTED] like this.
  13. Nov 30, 2022 at 6:22 AM
    Is it LED, and if so, is the socket keyed to prevent installing backwards?
    IIRC, the DRL harness terminates into a connection between the battery and fender, a few inches behind the driver side blinker. You should be able to see along the side of the battery IIRC. But it's been a minute.
    artsr2002[QUOTED] likes this.
  14. Nov 30, 2022 at 6:24 AM
    daveeasa
    David
    That’s where mine are. And also a tow power injection there too it seems. For the rear 9 pin to power a tow module.
    95AC1EA5-DB21-41D0-8A32-62A0D1C5929D.jpg 693B878B-E180-441A-B6EB-63188C241581.jpg FA410955-838A-4F1F-82BE-38F747F486A6.jpg
    shifty`, Tundra2 and artsr2002 like this.
  15. Nov 30, 2022 at 2:42 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    "Cannot Duplicate issue"
    bmf4069 likes this.
  16. Nov 30, 2022 at 2:50 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    I dunno, I've gone to new places only to discover I have been there before. But, I agree - GO FOR IT!
  17. Nov 30, 2022 at 3:07 PM
    Hot damn, my memory worked for a change. :rofl:
    (seriously though, I feel like I get it wrong or twisted way too often these days)
  18. Nov 30, 2022 at 4:32 PM
    Openbaffle
    Kimosabe, txagg, oscardog86 and 2 others like this.
  19. Nov 30, 2022 at 4:34 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Your gonna have to pin point the leak, the ol @shifty` way, mask/tarp off one side or the other and maybe separate it into quadrants and start lightly spraying the shell and see where it’s coming from. Your window drains could be clogged or even the seal around the windows to the shell could be kaput
  20. Nov 30, 2022 at 4:47 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
  21. Nov 30, 2022 at 7:12 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Day into night to tune my limits and bumps. The stubby, used to be adjustable clevis(s) got bent for being too long and crossing from outside of the frame to the inside on full leaf stuff. Might be good now.
    0DEAA85C-6AEC-402B-BF88-F5947FF46B48.jpg85274020-6DAB-497F-8061-A8E8C3F2CA47.jpg7B8ED208-91FA-43F0-B5FC-0648016C4354.jpg
  22. Dec 1, 2022 at 4:21 AM
    Openbaffle
    My buddy builds them. It's a pretty cool design, however, and requires almost no wood to cook with.
    oscardog86 and shifty` like this.
  23. Dec 1, 2022 at 3:39 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Went out to install my downstream O2 sensors at lunch and gave up after a crosswind hit my face bringing the temp from mid 40s down to what seemed like mid 20s.
    Don't need that sh*t today. Hopefully, there'll be a warm day this month. Out after the 16th on vacay until the end of the year. :woot:
  24. Dec 1, 2022 at 4:13 PM
    Openbaffle
    Really considering just pulling the trigger on the archive garage springs and waiting for them.
  25. Dec 1, 2022 at 5:31 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    The cost of leaf springs baffles me, crazy expensive.
  26. Dec 1, 2022 at 5:33 PM
    FrenchToasty
    Mo
    Bone stock
    What’s funny is I’m pretty sure they all come from the same place, a guy with deaver on my last run has the exact same sticker I have on mine just with different company names
  27. Dec 1, 2022 at 5:39 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Probably made by a Chinaman in Korea.
  28. Dec 1, 2022 at 6:01 PM
    FrenchToasty
    Mo
    Bone stock
    They say USA, maybe that means the sticker was made in USA
    bmf4069, txagg[QUOTED] and CodyP like this.
  29. Dec 1, 2022 at 7:21 PM
    "Made in USA from internationally sourced parts"
  30. Dec 1, 2022 at 7:26 PM
    (i.e. ain't shit made here, all the major work is done is Asia for pennies on the dollar, including putting the Made in USA sticker on it, then we bolt it together the way we like, and upcharge 800%)
