  1. Nov 28, 2022 at 3:39 PM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    Cleaned the crap out of the drawers. Super glued some of the cracks and got stainless hardware to button everything up. Excited to try it this weekend.
    Going to grab a rocket stove for cooking tomorrow.
  2. Nov 28, 2022 at 3:54 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    [​IMG] [​IMG]
  3. Nov 28, 2022 at 6:16 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Rutech came thru for me and sent me a replacement SAIS Bypass module. I sent my old one in after getting the error codes after having replaced my battery. They said their QC dept determined the unit had failed. They mailed me a replacement unit even though its been nearly 3 years since my original purchase date. Props to Rutech Solutions.
    HBTundra, oscardog86, bmf4069 and 6 others like this.
  4. Nov 29, 2022 at 11:49 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Ok kids. I need ideas here. Not my tundra, customers. 94k miles. Randomly starts bucking like crazy. Other shops put an ecu in, fuel pump, resistor, crank sensor, checked grounds… etc. when it acts up it’s acting like the ignition switch is being turned on and off really fast. I can’t find a reason as to why.
    06 vvti access cab
  5. Nov 29, 2022 at 11:58 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Do they give you guys a laptop computer with a usb oscilloscope & probes to check out the timing of everything?
  6. Nov 29, 2022 at 12:38 PM
    shifty` Inside his chest they found ten thousand pencils
    When you say "acting like the ignition switch is being turned on and off", do you mean full loss of power, like gauges and indicators go dark?
    If "yes", this is a power problem, and I'd be suspicious of the alternator and/or its connections, the ALT fuse being burned/arced to hell, or the batt/alt/pwr cables.
    NUDRAT likes this.
  7. Nov 29, 2022 at 12:43 PM
    This is one of my favorites, btw: https://www.tundras.com/threads/charging-alternator-problems.97131/#post-2469357
    I'd also be suspicious of park/neutral switch, and any of the myriad of harnesses on the trans/engine, but ... it all depends on whether all power is lost and all gauges dark, or lights are staying on but it's bucking
    HBTundra and NUDRAT like this.
  8. Nov 29, 2022 at 12:45 PM
    daveeasa
    David
    Got some truck stuff done today.
    1. Passed OR smog (not hard to do, just ODB plug)
    2. Got exhaust pipe re-routed and new hanger to allow fitting the 285's (tailpipe was touching the tire before)
    Also got a haircut
    Next up, DMV for the title & plates, yay! Then on to solving the airbag problem.
    bmf4069, txagg, NUDRAT and 3 others like this.
  9. Nov 29, 2022 at 1:54 PM
    artsr2002
    'Yonder
    Got my inspection and registration done. She's legal again boys! Lol.
    I installed the replacement SAIS module Rutech sent me. Also gave the MAF a quick blast with MAF cleaner spray and took it for a spin. No issues.
    Installed Aukee LED bulbs in my headlights once I got home. I've been really happy with the output of the Aukee 9005 high beam bulbs in my F150. No issues there. Gonna drive it to work later tonight and I'll check out the output.
    bmf4069, txagg, HBTundra and 4 others like this.
  10. Nov 29, 2022 at 2:33 PM
    Openbaffle
    Picked up my rocket stove today. Pricing out springs:
    For my 2006 DC 2WD, I'm looking at buying the 90-287HD springs from ATS:
    https://www.autoandtrucksprings.com...ty-rear-leaf-spring-fits-both-sides-90-287hd/ -- $480
    Leaf spring shackle kits:
    https://www.autoandtrucksprings.com...-shackle-kit-oem-044830c030-480420c011-bt-t9/ -- $130
    And the from AG, U-bolt flips, yellow speed bumps w/ring
    https://archivegarage.com/explore-archive/ols/products/stealth-toyota-u-bolt-flip/v/UBF-001-3. -- $270 with discount right now.
    Is there anything else I need or am missing for my rear leaf springs?
    oscardog86 likes this.
  11. Nov 29, 2022 at 3:02 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Sweet view! Seeing this kinda stuff (the view) and the truck make me wanna dump money in and drive cross country to camp for a week or 2.
  12. Nov 29, 2022 at 4:17 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    In my never ending effort to increase travel and increase tire clearance, I present you the world’s first 3/8” cab only body lift.
  13. Nov 29, 2022 at 4:19 PM
    Openbaffle
    This is such a good looking truck.
  14. Nov 29, 2022 at 4:19 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Flying with Eagles now!
    alb1k[QUOTED] likes this.
  15. Nov 29, 2022 at 4:20 PM
    Jack McCarthy
    Bill
    North of Boston
    So you bought taller body mounts? o_O
  16. Nov 29, 2022 at 4:26 PM
    alb1k
    Left Coast
    It's good
    I bought taller thicker grade 8 bolts, and fabbed some spacers…
  17. Nov 29, 2022 at 4:32 PM
    Openbaffle
    Do y'all with a topper take these plastic plates off the bed for better water resistance? I still have mine on with my topper. I don't think it's the seal that fails, I think it's the gap created with the plastic pieces. Thoughts?
  18. Nov 29, 2022 at 4:34 PM
    FrenchToasty
    Mo
    Bone stock
    Leave them on. It’s either the seal, which is cheap, or supposedly it’s up at the front corners where it gets in.
    Most model specific caps have a over hang that clears even the plastic
    I bet @des2mtn has some good tips
    oscardog86, FirstGenVol and des2mtn like this.
  19. Nov 29, 2022 at 4:39 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Both shells I had on the V6, I left the caps on, but crackie has no caps so I obviously didn't use em there..
    FrenchToasty likes this.
  20. Nov 29, 2022 at 4:40 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I'd leave them on too. Can honestly say I've never had a problem with water intrusion. A little bit of Sil-Glyde could act as a moisture barrier if you really wanted to add that in between.
  21. Nov 29, 2022 at 4:45 PM
    FrenchToasty
    Mo
    Bone stock
    I knew my bed hand once previously homed a cap, wiring by the tail light and run marks from the over hang near the tail lights. Also when I went to clean and prep my bed for liner, I found a bunch of strange goop near the front bed corners, I assume that was there for water intrusion, that’s usually where I see it wet if we ever get rain
  22. Nov 29, 2022 at 5:06 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You live in the desert!! :D
    @Openbaffle , I agree with the rest. Leave those on.
    Mine leaks too but my topper was made for a double cab.
    Jack McCarthy and FrenchToasty like this.
  23. Nov 29, 2022 at 5:07 PM
    WARSH THEM TARS!
    artsr2002 and FrenchToasty like this.
  24. Nov 29, 2022 at 5:10 PM
    FrenchToasty
    Mo
    Bone stock
    Hahaha
    He will just get them dirty again!
  25. Nov 29, 2022 at 5:13 PM
    stir
    stir New Member
    Stirling
    2004 Silver Tundra
    What fender flares are those
  26. Nov 29, 2022 at 5:15 PM
    FrenchToasty
    Mo
    Bone stock
    Woa!!!!
    I think they are oem, super shiny edition
    Filthyphil likes this.
  27. Nov 29, 2022 at 5:16 PM
    alb1k
    Left Coast
    It's good
    That's after the first pressure wash, gonna need some more love, but I'm trying to get my act together to see Brent this weekend. Maybe I should have held off on pulling a fender flare...
    shifty`[QUOTED] and FrenchToasty like this.
  28. Nov 29, 2022 at 5:18 PM
    alb1k
    Left Coast
    It's good
    That's what you see when you pull a flare. Research. I should’ve said that was my research lol.
    @stir
  29. Nov 29, 2022 at 5:18 PM
    Dang 'ol 1st post!
    Filthyphil and oscardog86 like this.
  30. Nov 29, 2022 at 6:06 PM
    empty_lord
    05 rollover special
    Gauges shut off to the accessory position for a split second.. it’s weird. Cleaning grounds it seems to be gone. It’s a weird issue. Nothing funky on the scope or codes in any computer.
