  1. Oct 23, 2022 at 11:54 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    @w666 Were you able to unscrew the hose clamp at the tank or did you cut it somehow? The screws on mine are completely deteriorated.
  2. Oct 23, 2022 at 11:54 AM
    Yeah, same. Part of me feels bad about it too. The reality is, timewise, it probably takes me longer to drive to the auto parts store to recycle the old than to change it. I tell myself I'd do it more often if I had a lift, but I don't even know that's actually true :rofl:
    I give mine a good wipe-down with an oily/greasy rage at every change. Frame is still looking new now, wish I took pics after wipe-down, all I have is from before.
    abcinv likes this.
  3. Oct 23, 2022 at 12:10 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Sorry, that's sadly not gonna be for a bit. Electric fans and rear sway are first in line, probably a bigger meth nozzle too while I'm at it. If I get to them before you do I'll make a build thread.
  4. Oct 23, 2022 at 12:11 PM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    My friend has a lift, that makes most maintenance or repairs, almost fun. I did a rear main seal on a Chevy 350 motor on his lift. Piece of cake, but if i were doing it lying on my back, not so much.
    I let the selling dealer do two changes on my Tundra new, they offered complimentary maintenance for new purchases. Both times they grossly overfilled the engine oil. By more than a quart. That's when I figured they don't put their top guys on oil changes. I've always done my own since then. If you have a good mechanic then it's a good deal if you don't want to do it, but they seem to be a rare species anymore. I might let Toyota do my next timing belt, being hunched over the truck for 2 days hurts just to think about it.
  5. Oct 23, 2022 at 12:59 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
  6. Oct 23, 2022 at 1:36 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    @Archive
    Heeew! What a day! Didn’t go as easy as planned but wasn’t that bad. No more zonie squat, now I’ve got the zonie stank bug action!
    First spin around the block felt great, kinda worried it was going to feel like a semi but it wasn’t the case!
    I went from 21.5” to 25.5” hub center to fender!!!!! Last thing I need to do is chop the excess Ubolt threads. 34A95003-F847-4109-A1BF-664037898D5B.jpg508C9404-9C22-4E63-94C1-36428FCD6607.jpg9D351FEA-B0E1-4EE3-A071-4718AB193478.jpg
    @Cruzer those 10t stands are the shit!!!
  7. Oct 23, 2022 at 2:21 PM
    snoope
    snoope The Old Man
    Drove it like I Stole it..:burnrubber:
    Small get away planned before IAN the a$$hole showed up.... business & pleasure :hattip:
    Proudly got 15.5 mpg running up the Florida west coast :thumbsup:
    Con just looked at me after I did the math and shook her head :rolleyes: and reminded me her Corolla got us 43-50 mpg's ;)
    Filthyphil and FrenchToasty like this.
  8. Oct 23, 2022 at 4:09 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I was able to unscrew the hose clamp. It's just an ordinary hose clamp, however, so cut it if you need to and replace with another. The smaller vent line uses a fuel line connector at the tank side, so you'll need a special tool...
    https://www.amazon.com/Patonu-Line-...jQuNTMifQ==&sprefix=fuel+line,aps,102&sr=8-38
    There are a hundred variations on this theme, so you can just grab what you need at your local parts store.
  9. Oct 23, 2022 at 5:33 PM
    Cajunman007
    Cajunman007 New Member
    Shane
    Lafayette, LA
    02 Tundra Access Cab 4x4 4.7
    How are they working out? I just bought a set. I am set to install them this week, so I just wanted to see if you have any issues with them.
  10. Oct 23, 2022 at 8:08 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    @NickB_01TRD had good luck with his, mine leak on both sides. Could be we didn't get the seals right, but I doubt it.
    Cajunman007[QUOTED] likes this.
  11. Oct 23, 2022 at 8:12 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Mine are good still. Passenger side leaked initially due to bad seal install. Reinstalled new seal to the right depth and no issues since.
    @Cajunman007 if you're doing axles it might not be a bad time to upgrade to the ECGS axle bushing on the driver side and replacing the seal as well. I'd say leave the passenger side seal alone as long as it isn't leaking. It sucks.
    FirstGenVol likes this.
  12. Oct 23, 2022 at 10:07 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    you ever manage to get some fuel trim numbers?
  13. Oct 24, 2022 at 2:26 AM
    FrenchToasty
    Mo
    Bone stock
    Not yet, do you have something on the drawing board for a tune?
  14. Oct 24, 2022 at 6:43 AM
    empty_lord
    05 rollover special
    Today. Spent 220 bucks for the maps
  15. Oct 24, 2022 at 9:21 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Got the truck out for the first time since regearing and going to 33s. Feels like a whole new truck, so much slow crawl control while keeping the RPMs up enough to keep from stalling in 4HI. 4LO really crawls now! Has much more power on and off the highway now too. Really glad i went with 4:88 ratio. Heres some camping photos from the last weekend in Joshua Tree BLM area. IMG_20221021_150414841_HDR.jpg IMG_20221021_171305912_HDR.jpg IMG_20221021_175824146_HDR.jpg IMG_20221021_190243557_HDR.jpg IMG_20221022_081314492_HDR.jpg IMG_20221022_082418405_HDR.jpg
  16. Oct 24, 2022 at 9:27 AM
    FrenchToasty
    Mo
    Bone stock
    How did your swing out work?
    oscardog86[QUOTED] likes this.
  17. Oct 24, 2022 at 9:28 AM
    oscardog86
    Southern California
    Dude, it held up just fine through everything. I wasnt bouncing around that much, but i checked it from time to time and it was solid and latched in place. I didnt have the fuel rotopak filled up though, only the water one.
    And the table definitely worked for that salmon i cooked up!
  18. Oct 24, 2022 at 10:24 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I have some good news!
    As it turns out, I was right about my calipers. I wish I had just removed the GX calipers long ago. My brake pedal feels great and I'm no longer having to double pump them each time I stop. Something must have gone wrong at the machine shop when I had these modified. My gut says they didn't take enough material off. That would explain why they rattled against the spindle and why I had to double pump to get the pistons to actually engage the pads.
    Final thoughts on the 14WA calipers. If you have a machine shop you trust and you can get them modified correctly, you should see increased braking performance with the bigger calipers. It may come at the expense of pedal feel and travel. Reports are mixed on this. I do not believe you necessarily need to do the T100 booster/MC swap just because you move up to bigger calipers. Plenty of people have had success without swapping those parts.
    Looking back, I can't believe all the things I tried to make these work. It wasn't air in the lines/ABS. Reverse brake bleeding didn't help. Replacing my master didn't help. It wasn't my booster. Rebuilding my rear brakes and adjusting them didn't help. Messing with the LSPV did nothing. The answer was so obvious. I lost around $800-1000 on this project.
    Hopefully my misadventures help someone else.
    jpink, KNABORES, bmf4069 and 10 others like this.
  19. Oct 24, 2022 at 10:31 AM
    Congrats on your new brakes. Sucks about your loss, though. I can think of about a dozen other things I'm sure you'd rather've dropped that dough on.
    Remind me again, did you roll back to the WLs, so still getting an upgrade, or right back to stock again?
  20. Oct 24, 2022 at 10:42 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I went to 13WL so still an improvement from the 13WE's that came with the truck. This is honestly the best they have ever felt. These pads don't have the same bite that the bigger ones had which is why I believe the GX upgrade could be worth it if done correctly.
    I also bought the cheapest pads Rock Auto sold. I wanted to make sure this actually helped before investing in expensive pads. Now that I know it did, I may buy some better pads if anyone has suggestions. I've heard OEM pads are hard to beat.
    shifty`[QUOTED] and oscardog86 like this.
  21. Oct 24, 2022 at 10:57 AM
    Ok, so you're basically on my calipers. Honestly, I'm happy with my stock 13WL. I've heard a couple of others complain about them sucking, but I guess they've never driven any of my previous 2-3 dozen vehicles :rofl:
    You may as well burn through the ones you got, unless they're throwing lots of shit everywhere or you're worried about them dicking up something else. I'm an OEM guy. At least I know what to expect, because that's what was already on the vehicle. With brakes, I get pissed when they create excess dust and whatnot.
  22. Oct 24, 2022 at 11:23 AM
    msage002
    msage002 New Member
    2001 White Tundra V8 AWD
    ARE DCU Shell 06 tail lights led light everywhere
    Before: oLcCCj54pL_mBG8s7NlS56iK7qHM6DbqsfWC5sk7_256b0587a227db4f07b9932bb6a6a3d4faf7687f.jpg
    After with 06 taillights:7TQh3qyBLl7yuYkBIaxfzs4miBb6iWsjdc8FEPkb_d18486f0641cef45806f3fcd3d6e8a28f145fcfd.jpg
    HBTundra, 5N0W808, abcinv and 4 others like this.
  23. Oct 24, 2022 at 11:24 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    i like my powerstop z23 pads. But, like ive said before, im pretty gentle with the brake pedal. The dust is more of a tan color than black.
    I'm trying to figure out what sort of neat shenanigans could be done with those WA calipers. No rotors?... just cracked open my first beer, if i come up with something decent i'll let you know. Only thing that stands out would be rear disc conversion, but i dont have/want 17's.
    KingSequioa007 likes this.
  24. Oct 24, 2022 at 11:47 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Replaced the trailer wiring today. Hopkins brand fit just fine only thing I forgot is I tapped the reverse circuit there for my backup cam. My meter is MIA at the moment so that will have to wait.
  25. Oct 24, 2022 at 11:50 AM
    Check his for sale post. He's willing to give up the rotors too, unless I read wrong. https://www.tundras.com/threads/free-14wa-brake-calipers.114907/#post-2956869
    Nice! What'd you need to do to adapt the wiring? The housings are a direct-install, right, just the wiring has to be addressed?
    (great 1st post, welcome to the forum!)
    oscardog86 and msage002[QUOTED] like this.
  26. Oct 24, 2022 at 12:03 PM
    msage002
    msage002 New Member
    you need the wiring harnesses from the later year as well to do it right!
  27. Oct 24, 2022 at 12:45 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    After every trip in the dust I get home with some squeaking, which is pretty common with aftermarket suspension. I've been greasing and chasing squeaks since the Dude Ranch trip. I got to the point of just ruling one thing out at a time because it's hard to pinpoint the noise source. I already did all of my bushings. Decided to full droop the leaf packs and grease the leaf ends at the pads. Noise gone.
    bmf4069, NUDRAT, des2mtn and 5 others like this.
  28. Oct 24, 2022 at 12:48 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    i'm not ready to blow up his post with false hope, yet.
    4 beer in, and maybe the one of the brakes could be a holding brake for a gantry hoist. And the other could be a brake for my mower deck for the tractor. Actuated by motorcycle MC's?
    lets see what the next beer comes up with.
    bmf4069 and shifty`[QUOTED] like this.
  29. Oct 24, 2022 at 1:04 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Who's writing the maps? Are these going onto a stock ECM?
    FrenchToasty likes this.
  30. Oct 24, 2022 at 1:25 PM
    Jack McCarthy
    Bill
    North of Boston
    Do you sleep back there?
