  1. Oct 22, 2022 at 3:37 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Is the rest of that mount basically the same as original? What's this poly talk about?
  2. Oct 22, 2022 at 3:58 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Yup an OE mount with polyurethane filling. All new OE hardware as well.
  3. Oct 22, 2022 at 4:01 PM
    alb1k
    Left Coast
    It's good
    Ahh..I thought someone had done that. It was you. Have a source or did you fill that?
  4. Oct 22, 2022 at 4:22 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Yea that was me. I filled it myself. I was trying to see if Solid Off Road would send me measurements on 3rd gen Taco since it looks very close in size (the actual mount to trans) but I figured I give this a go 1st.
    RUSTYNUTS and alb1k[QUOTED] like this.
  5. Oct 22, 2022 at 4:54 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Having just done this, disconnect both hoses at the tank.
  6. Oct 22, 2022 at 5:02 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I didn’t know that was possible, I’ll take a look. Thanks!
  7. Oct 22, 2022 at 5:20 PM
    shifty` Inside his chest they found ten thousand pencils
    Holy hell, I actually did something today!
    Oil change & spark plugs finished.
    Finally got about 200-300 miles in after adding Seafoam "high mile" into the crankcase. Switched up oil this time, Mobil 1 Extended Performance "High Mile" full syn, hoping it'll help with more crankcase cleanup (de-varnish). The passenger head is definitely less caramelized now than when I did the VC gaskets. Happy about that.
    Swapped out plugs. I assume these are the original plugs. They appear to have at least a good 30k-40k miles on them to me.
    Dammit if the driver's side plugs don't take 2x as long due to brake and fuel lines. Finally had an excuse to use that 18" extension I bought a couple years ago, but I could only use it on the passenger side! Cylinder 8's plug was the worst.
    Truck definitely idles smoother. When I had to jump on it during 25min test drive after the work, it had no qualms with zipping up to 5k rpm. I don't think it's placebo, but there's not any marked difference. I was really hoping to find someone had the wrong plugs in it or something, and I'd be seeing a bigger response.
    Anyway, pics just because I was in there and why the hell not?
  8. Oct 22, 2022 at 5:32 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    did you do the t100 MC also? Curious how the bigger piston feels with stock brakes.
  9. Oct 22, 2022 at 6:23 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    No that was the one thing I never tried. I replaced the master cylinder but stuck with a Tundra MC.
  10. Oct 22, 2022 at 7:55 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    I think it probably helps with vibration too to have it secured...which is why I believe I had a leaky hardline at the caliper after doing larger spindles...damn bracket didn't line up to new spindle mount points because they are much thicker. Which is also why I wanted to find a way to ditch the hard line all together.
    RUSTYNUTS and des2mtn[QUOTED] like this.
  11. Oct 22, 2022 at 8:03 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    I believe you just have to loosen one. the other mounts the bracket to the stud coming from the truck but also acts as the other side of the clamp. One is a nut and one is a bolt to loosen if that makes sense.
  12. Oct 22, 2022 at 8:07 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Yeah, I think the main thing you're going to want to do if you cut out the hard line and go to a one piece stainless line to the caliper, is run guides along the spindle so stainless line can't get caught up in the suspension.
  13. Oct 22, 2022 at 8:09 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I hate working with these hard lines. Passenger side went fine but the driver side doesn't want to thread into the caliper evenly. I'm afraid the threads are gonna strip. I'll be attempting again in the morning.
  14. Oct 22, 2022 at 8:12 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Dude I got a new reman caliper from Toyota and had to re-tap the caliper because it felt so rough kinda like it was gonna cross thread.
  15. Oct 22, 2022 at 8:14 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    You mean "guides" like those magical plastic straps called zip ties, right?
  16. Oct 22, 2022 at 8:18 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Edit: I was wrong...I think. Mine, the bolts came from top but I believe also the 5 screws in cap area were enough to let it float. Weird like the cap pulls it all together once ya get the fill up flush with back of the area ya see when you open the lid
  17. Oct 22, 2022 at 9:50 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    [​IMG] 1st gen still best
    need to get yourself a set of TRD brakes. oh my. theyre amazing.
    oscardog86, txagg, bmf4069 and 4 others like this.
  18. Oct 22, 2022 at 9:53 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    KingSequioa007 and des2mtn like this.
  19. Oct 22, 2022 at 9:55 PM
    empty_lord
    05 rollover special
  20. Oct 22, 2022 at 10:04 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Ah, I'd have to get different wheels to clear those. Im on 16s
    oscardog86 and empty_lord like this.
  21. Oct 22, 2022 at 10:39 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Two piece and a biscuit
  22. Oct 23, 2022 at 12:59 AM
    viducce
    viducce New Member
    5N0W808, oscardog86, txagg and 3 others like this.
  23. Oct 23, 2022 at 7:02 AM
    des2mtn
    SW
    Tonto cover
    Please buy them for science :) I'm on 16's too and have been eying them for awhile.
    Realistically if I upgrade my brakes anymore I'm going to retrofit a hydroboost master cylinder.
    oscardog86 likes this.
  24. Oct 23, 2022 at 8:02 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Looks like it's time to bleed. My favorite.
    Also used this opportunity to Fluid Film all my holes.
  25. Oct 23, 2022 at 8:14 AM
    Jack McCarthy
    Bill
    North of Boston
    Did you get your frame replaced? It looks almost new.
    jpink likes this.
  26. Oct 23, 2022 at 8:18 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Nope. Just a southern trucks between NC and TN. The only place it had some rust is where the dreaded frame stiffeners are. I also try to pressure wash it a few times a year. I've found that by treating it with Fluid Film, dirt seems to wash off easier. The only thing that sticks is sand.
  27. Oct 23, 2022 at 9:42 AM
    The height of the side body panels on all the new trucks is so clownish to me. I think the bedsides on that '22 are probably shoulder level with me and my height starts with the number "6". Ludicrous.
  28. Oct 23, 2022 at 11:12 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Oil and filter, 5700 miles on this change interval, 2 years and 2 months. I didn't realize it was that many miles and 26 months since I did it last. Zero oil consumption since done last. I used, and did again, Mobil 1 5w-30 full synthetic and they claim 10,000 mile change intervals, so I guess I'm okay. I don't do any short runs with it, just longer trips when I need the truck. I log most of my miles on the motorcycles, 50 MPG beats the piss out of 16 MPG and lots more fun on two wheels. Just over 6.5 quarts to fill to the top dimple on the dip stick. I think you're up to date now. Oh yeah, a Toyota filter and a new Toyota sealing washer on the drain plug as always. Cheers.
    oscardog86, bmf4069 and shifty` like this.
  29. Oct 23, 2022 at 11:21 AM
    I also use M1 full syn. I've always heard to change your oil at least once every 12-16 mos regardless whether you hit your mileage numbers, regardless of what oil type you use. (not sure I buy it)
    The reasoning I was given for this is "If you can't hit the mileage within 12 months, it means you're doing lots of short-trips with heat-up/cool-down cycles, which degrades oil much faster than lots of miles at temp", but if you're not running short trips, I'm not sure I'd worry bout it either. I'm not so fortunate in my case and probably should switch back to dino on the next cycle; I just happened to have 2.5Qt of full syn leftover from previous changes, so stuck with full syn for one more cycle with a new jug.
    I'm sure someone has done some studies on this heat/cool cycles and its effect on full synthetics, I'd be curious to read them.
  30. Oct 23, 2022 at 11:46 AM
    chunk
    chunk New Member
    I grew up with the same understanding about time intervals as well, and like you think as long as the oil gets good and hot to evaporate any moisture I'm good to go. I don't mind doing the oil changes on the Tundra, but it is a bit of work (lying on my back with the truck flat on the ground, I just shimmy underneath) so I like to put it off as long as I can between changes. It looked beautiful on the bottom side with no rust anywhere and still very free of grunge, after 21 years now.
