  1. Oct 21, 2022 at 6:31 PM
    Azblue
    The Dirty T ( ^_^)_且
    Na, I took it back to storage yesterday, but you can always pitch a tent on the grass in the back yard.
  2. Oct 21, 2022 at 6:34 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Turtle party!
  3. Oct 21, 2022 at 6:42 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Oh no, I didn't miss the joke. I just knew what @Mr.bee was talking about.
    FrenchToasty likes this.
  4. Oct 21, 2022 at 6:52 PM
    Casper421
    In the woods
    06 DC
    Doing hammer hangers?
  5. Oct 21, 2022 at 6:55 PM
    FrenchToasty
    Mo
    Bone stock
    Yerp! And HD leafs, leaves?
  6. Oct 21, 2022 at 6:58 PM
    viducce
    viducce New Member
    Did anybody put this on his truck?
  7. Oct 21, 2022 at 7:08 PM
    shifty` Inside his chest they found ten thousand pencils
    @Mr.beer said something?
    Mr.bee and FrenchToasty like this.
  8. Oct 21, 2022 at 7:11 PM
    FrenchToasty
    Mo
    Bone stock
    That’s @Mr.Bock
    bmf4069 and Mr.bee like this.
  9. Oct 21, 2022 at 7:15 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Installed the 4 new Denso coils I bought couple days ago to replace the 22 year old ones I had. Misfires fixed!
    oscardog86, bmf4069, alb1k and 6 others like this.
  10. Oct 22, 2022 at 10:47 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    F this rear spring spacer. I don't have jack stands I trust that go high enough enough with my lift. I'm doing this at the shop on a lift. I do like how drive side looks with the jack tilting it to one side.
    5N0W808 likes this.
  11. Oct 22, 2022 at 11:00 AM
    FrenchToasty
    Mo
    Bone stock
    I never had to use a compressor to close the springs to put a spacer in.
    Sway bar and track bar loose? I ended up using the scissor jack to open it enough to slide the driver spacer in.
    You can also jack the opposite front corner to open up that rear more
  12. Oct 22, 2022 at 11:41 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Yea these OMEs are 2.5 inch taller than stock. I was able to get them in last year and OE spring came out without compressor. But new springs need compressing. But that was outside the Truck. Different when they're already on.
  13. Oct 22, 2022 at 11:49 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Yes.
  14. Oct 22, 2022 at 12:06 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Decided to take my bedliner off and try the Impact on those bed bolts.
    Good luck! They all came out 1/2 way so I know I can get them all out when needed. Probably the only good thing about the Toyota rust treatment was me giving them anti-seize to put on the replaced bed bolts.
    Downside is I know the last two near the front fought the impact the whole way, so I know those have to be replaced.
  15. Oct 22, 2022 at 12:47 PM
    Jack McCarthy
    Bill
    North of Boston
    My next question is what’s the best way to get the neck off so I can lift the bed 3-4” to get at the rear shock nuts?
    Should I take a hack saw to the nuts that have all but disintegrated to get the top of the bracket off circling the hose?
    oscardog86 and w666 like this.
  16. Oct 22, 2022 at 12:54 PM
    alb1k
    Left Coast
    It's good
    Yours may be different, but on mine the 4 bolts on the gas cap side took care of it. I didn't have to mess with that part.
  17. Oct 22, 2022 at 1:06 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Goodbye GX calipers.
  18. Oct 22, 2022 at 1:10 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Anyone remember the brake caliper to spindle torque spec? If not, I'll go look it up later.
  19. Oct 22, 2022 at 1:19 PM
    Jack McCarthy
    Bill
    North of Boston
    Huh, interesting. Yeah it’s a clamp that secures it to the underside of the bed. I’m thinking of taking a hack saw blade and just cutting the nut metal by hand like a file and use a hammer to pound the bolts up and free.
  20. Oct 22, 2022 at 1:44 PM
    alb1k
    Left Coast
    It's good
    90 ft lbs on 05/6 DC
  21. Oct 22, 2022 at 1:52 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    So the only way I could get the hard line to line up with the caliper was to remove the fork holding the hard line in place to the spindle. I hate that fork.
    Of course now it doesn't want to line up there. wonder how critical it is. I'm guessing it's pretty important that the line stays secure.
    :Cracks knuckles: Mangle time
  22. Oct 22, 2022 at 2:03 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Can't remember, were you using GX rotors as well?
  23. Oct 22, 2022 at 2:04 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Just bend the hard line by hand where it'll fit in the caliper again. Obviously not in a way that pinches the line. And yes, when you're all done that hard line definitely needs to be secured to the spindle. If not, you can rip the brake line out of the caliper like @Casper421 did and you'll really have Fred Flintstone brakes.
  24. Oct 22, 2022 at 2:21 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I have the line screwed into the caliper. Now I'm fighting hard line where it meets the SS lines it appears to be rusted together. Rather that unscrew where it connects to the stainless steel line it's just turning. I'll get it eventually I'm sure.
    Edit- got it!
    NUDRAT and des2mtn[QUOTED] like this.
  25. Oct 22, 2022 at 2:22 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yes. I think it would be impossible to run smaller rotors but could be wrong.
  26. Oct 22, 2022 at 2:33 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    So I realized I didn't buy the shims this time but it looks like the new pads have them already attached to the back of the pad unlike the last set. Any concerns here?
    Old GX pads on the bottom.
    Filthyphil and KingSequioa007 like this.
  27. Oct 22, 2022 at 2:37 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    I've used pads with no shims before. No issues on braking really. I could see potential noise or slight vibrations without shims.
    oscardog86 likes this.
  28. Oct 22, 2022 at 2:40 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Finally got this new custom poly/OE mount on. Stupid Toyota dealer tech stripped the holding mount piece many years ago. Never trust that dealer again. Anyone happen to know the Torque spec for the long bolt through the mount?
    oscardog86, bmf4069 and des2mtn like this.
  29. Oct 22, 2022 at 3:13 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    German spec gudentite
  30. Oct 22, 2022 at 3:31 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Lol
