  1. Sep 6, 2022 at 6:33 AM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    I was leaning towards paint then everyone on the First Gen Tundras Facebook group said paint isn't the way to go; That it would just cause more problems later.
    Tundra2 likes this.
  2. Sep 6, 2022 at 6:41 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Why is that? You don’t live in the rust belt. You just need a rust converter treatment prior to paint.
    In my case, I wire wheeled mine and coated it in two coats of semi-black POR-15 after pre-treating it. It’s held up well since 2012.
  3. Sep 6, 2022 at 8:21 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I 2nd the POR-15 suggestion. Great product but expensive.
  4. Sep 6, 2022 at 8:22 AM
    shifty` Inside his chest they found ten thousand pencils
    I'm a little weird about spraying topicals onto anything made of cloth/fabric. Just lifting my seat belt out of the way and spraying the plastic it rides across a couple of times with drying in between pretty much resolved my light retraction woes.
  5. Sep 6, 2022 at 8:44 AM
    Jack McCarthy
    Bill
    North of Boston
    That’s still indirectly applying it to the seat belt fabric since it rolls over it and picks it up even when dry.
  6. Sep 6, 2022 at 8:46 AM
    Topical transfer vs. full-on soak. Achieves the same effect with topical onto the plastic surface the belt glides across. Same concept you find with treadmill maintenance - you spray the platorm your running belt slides across, not the belt.
    I'd be worried about what nasty shit you're sealing into your seatbelt by spraying directly w/silicone, it'd be difficult to get dirt, dead skin, mold spores, etc. out again after saturating with silicone.
  7. Sep 6, 2022 at 9:33 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    On both sides I was able to get the old bolts out, and the front bolt was longer than the rear bolts. Really weird.
  8. Sep 6, 2022 at 9:40 AM
    Casper421
    In the woods
    06 DC
    That diff breather looks a little crusty. I would recommend testing it and extending the breather up to the tail light or inside the gas filler door.
    snoope, bmf4069 and oscardog86 like this.
  9. Sep 6, 2022 at 10:09 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Good advice, and good catch! I didnt even notice that. Luckily ive already done this mod on my baby.
    NUDRAT and Casper421[QUOTED] like this.
  10. Sep 6, 2022 at 10:11 AM
    oscardog86
    Southern California
    Even though it was a million degrees in my garage this holiday weekend, I tried my hand at a swing out on my bumper for a water container, gas can and a fold down table. Its coming along alright so far though.
    5N0W808, NUDRAT, Casper421 and 5 others like this.
  11. Sep 6, 2022 at 10:18 AM
    danmurphymn
    danmurphymn New Member
    Minneapolis, MN
    Black 2004 DC TRD
    You got pictures of inside the truck bed setup anywhere???
    oscardog86[QUOTED] likes this.
  12. Sep 6, 2022 at 11:32 AM
    oscardog86
    Southern California
    Ill take a good picture of the current set up for ya today when i get home.
    danmurphymn[QUOTED] likes this.
  13. Sep 6, 2022 at 3:35 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I wire wheeled the rust off of mine. Sprayed a coat of primer and then painted. POR-15 probably would have been better though honestly.
    It made mine slide really nice but as far as long term effects I have no idea.
  14. Sep 7, 2022 at 5:59 AM
    oscardog86
    Southern California
    Here ya go man, not the
    prettiest but gets the job done!
    NUDRAT, 5N0W808, Kimosabe and 2 others like this.
  15. Sep 7, 2022 at 6:51 AM
    danmurphymn
    Minneapolis, MN
    Black 2004 DC TRD
    I love it! Thanks for sharing. I did a quick built with scraps from my shop. It works, but I keep dreaming of when I can find the time & money to build the back how I want it... It's good to see others for ideas.
  16. Sep 7, 2022 at 7:33 AM
    oscardog86
    Southern California
    Absolutely, I love seeing other peoples designs. Ive had several iterations of setups back there and this is the latest one that works the best for me. Its fun building it up to really make it your own and learn over the camping trips what you need and what you dont.
  17. Sep 7, 2022 at 12:42 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Looks good @oscardog86
    I whipped one up one day after we sold our van. It's really basic, but works well enough for the short time I'll be using it.
    oscardog86 likes this.
  18. Sep 7, 2022 at 1:33 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    I need me a 175-200 Amp I thinks. Would love to do a pulley upgrade to a new 150 Amp denso unit but haven't researched enough into belt sizes, pros and cons, etc.
    shifty`[QUOTED] likes this.
  19. Sep 7, 2022 at 4:01 PM
    Jack McCarthy
    Bill
    North of Boston
    Looks like I’ve got to get the 2003 brake caliper pins and not 2002…time to exchange. More delays. Sigh.
  20. Sep 7, 2022 at 4:08 PM
    Jack McCarthy
    Bill
    North of Boston
    I’m not sure if I’ll get a good enough grip with a crescent wrench to help break free the 18 mm nut from spinning on either side (drivers or passengers) of the Moog stabilizer links where it contacts the LCA. Hoping I don’t have to buy new there as well. Mo’ problems.
    I’m really hating the rust here.
    NUDRAT and oscardog86 like this.
  21. Sep 7, 2022 at 4:16 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I've never removed one with any rust without breaking them.
    oscardog86 and FrenchToasty like this.
  22. Sep 7, 2022 at 4:18 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Hahah great words of encouragement. That’s why I left mine off
  23. Sep 7, 2022 at 4:26 PM
    Jack McCarthy
    Bill
    North of Boston
    You’re so inspiring. haha
    FrenchToasty likes this.
  24. Sep 7, 2022 at 4:29 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
  25. Sep 7, 2022 at 4:47 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    NUDRAT, 5N0W808, oscardog86 and 4 others like this.
  26. Sep 7, 2022 at 4:58 PM
    Festerw
    Festerw New Member
    04 Tundra DC
  27. Sep 7, 2022 at 6:14 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    They may work fine, just stick out a tad. Just check spoke clearance on the wheels.
  28. Sep 7, 2022 at 6:26 PM
    Jack McCarthy
    Bill
    North of Boston
    They told me to go ahead and exchange it. The 2003 calipers are 1/2” shorter from what I’m told.
    They already know there was a changeover in break pad sizes during that year due to a change in caliper size.
  29. Sep 7, 2022 at 7:48 PM
    NickB_01TRD
    Nick
    KY
    I've done brakes on 3 tundras. They never come with those pins and I had to cut them out/destroy them on 2 trucks. So when I did the brakes on my truck I went ahead and ordered new ones with the brakes. Low and behold the pads came with new pins. So then I had two sets of pins. Guess I'll hold on to the extra for next time.
  30. Sep 7, 2022 at 9:41 PM
    wandering_boy
    wandering_boy Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    Im guessing there is frame drilling and or some welding involved?
    Jack McCarthy likes this.
