  1. Aug 18, 2022 at 12:41 PM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Id probably just get rid of the flimsy skid plate if its getting in the way. I have the recovery points as well and they work great.
    RUSTYNUTS, Siebler, 5N0W808 and 3 others like this.
  2. Aug 18, 2022 at 12:59 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I just realized I got shipped a passenger side LCA when it was supposed to be a driver's side LCA. Bag indicates passenger side (RK630435) while re-boxed sticker and delivery email indicates driver's side (RK630434).
    I'll wait till I get tomorrow's shipment. Let's hope they shipped the driver's side instead of the passenger side so that two wrongs will make a right. :rofl:
    NUDRAT and oscardog86 like this.
  3. Aug 18, 2022 at 2:08 PM
    If not, the good part is, at least you have one in authentic packaging, and you can send it back to be replaced left and right!
  4. Aug 18, 2022 at 2:23 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    Maybe take a hammer to part of the skid to make it work?
  5. Aug 18, 2022 at 3:17 PM
    Jack McCarthy
    Bill
    North of Boston
    And then they conveniently discard my note on the account that I made them aware of the fact I never received the retail box….”no refund for you!”
  6. Aug 18, 2022 at 3:29 PM
    I've never had Summit Racing screw me over and I've bought (not exaggerating) tens of thousands of dollars in parts from them over the last 20+ years. I'm actually really surprised to hear you got non-OEM packaging. But I assure you, if you called them - as you probably should just to notify them - they'll make it right.
    Just be up front with them: "Look, I'm a little concerned. First, this was the wrong part, the for the wrong side of the truck. Second, this didn't come in OEM packaging and that has me feeling uneasy."
    If you already did that and had some weird experience, I'd like to hear about it. Maybe they changed, but that's totally out of character from the 'norm'.
  7. Aug 18, 2022 at 7:35 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I was worried about that but mine came right out. Though they may have been unplugged when the frame was replaced so they were already loosened up.
    oscardog86[QUOTED] likes this.
  8. Aug 19, 2022 at 5:47 AM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    I looked at mine yesterday evening and one of the brackets that busted is gone... I suppose I need to add a new grill to the to do list.
  9. Aug 19, 2022 at 2:45 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Took the truck to get smogged. Three tests and a little over four years and the Magnaflow cat is still doing its job.
    5N0W808, oscardog86, bmf4069 and 4 others like this.
  10. Aug 19, 2022 at 7:09 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Evacd and recharged freon to specs. Still not cold enough at idle. ECT seems to be steady at 88-90 C. I'm guessing compressor is going out or condenser is semi plugged.
    des2mtn likes this.
  11. Aug 20, 2022 at 5:11 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    looked to be sure fins are good & no blockages - getting good air flow out front?
  12. Aug 20, 2022 at 7:11 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Fins are good, no blockage. Fans are good and operating normal. No bubbles in sight glass. Pressures are normal low and high side per FSM. Only thing that my buddy noted was condenser felt hotter than normal. Lowest temp inside cabin was measured at 50 F. While driving still reaches 40-42 F. Warmer than normal ECT is now normal based on my buddy (32 year Master Tech.) Plus my 18 years of experience as a tech. I'm starting to get frustrated with this AC system.
  13. Aug 20, 2022 at 7:19 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Did you guys actually weigh the charge in or go by pressures? With these small systems I hate guessing, I will always weight it in. Last weekend I did 19oz out of the max 20oz I think, she’s nice and frosty, but I haven’t measured vent temps with a proper bead probe yet.
  14. Aug 20, 2022 at 7:27 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Weights by FSM, Dual AC Sequoia states 32 Ounces +/- 1.4.
  15. Aug 20, 2022 at 7:29 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Weight that was evacd was a tad over 30 ounces.
  16. Aug 20, 2022 at 1:21 PM
    I'll ask just for shits n giggles, wouldn't be something stupid like blend door failure, actuator fail, or control fail?
    I'm not as familiar with the Sequoia, I know the dash control is different, I've never driven one before and don't know how it all works. I'd assume the stuff up in the dash is relatively similar though.
  17. Aug 20, 2022 at 2:59 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    No, because blend door works fine, no codes un AC system either. I mean it's possible without codes. Even a slightly open blend door but the thing is once above 15 MPH its ice cold and works perfect.
    NUDRAT and FrenchToasty like this.
  18. Aug 20, 2022 at 3:02 PM
    FrenchToasty
    Mo
    Bone stock
    Do they have a filter drier? Our DC don’t have a replaceable drier(that I can find)
  19. Aug 20, 2022 at 3:23 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    I thought the 1st gens all shared the same AC layout minus the Sequoias rear AC unit. The Sequoias dryer is up front passenger side.
  20. Aug 20, 2022 at 3:54 PM
    Jack McCarthy
    Bill
    North of Boston
    Got my 2nd control arm in from Summit Racing. Now I have 2 passenger side control arms.
    Shipping box has large hole in it along with retail box. Some minor damage to the control arm as well. Why is it nobody does a good job protecting the tabs on the control arm in shipment? Had this same issue with my first pair shipped to me from Rockauto.
    I’ll have to call Monday to hopefully resolve this matter.
    1098B799-D831-40EF-8BD3-86F86BCDCEAB.jpg 5C27857B-DE7B-42B3-B6BB-92DF3F6B9162.jpg
    des2mtn likes this.
  21. Aug 20, 2022 at 4:02 PM
    des2mtn
    Shady Grove
    Tonto cover
    Maybe two passenger control arms will fix your alignment :)
  22. Aug 20, 2022 at 4:18 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Tundras with a center console connecting to the dash, have air to back seats. The ducts run thru there.
  23. Aug 20, 2022 at 4:24 PM
    FrenchToasty
    Mo
    Bone stock
    Up front near the firewall or up front after the condenser? Yeah mine doesn’t have one:(
    To test the filter drier take a inlet and outlet temp, it should be within a few degrees of each other, clamp style or bead probe taped on will get you the best reading.
  24. Aug 20, 2022 at 4:56 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Correct. But the general layout, AC compressor, condenser, dryer, lines, pressure switch, etc. Are all pretty much the same
    FrenchToasty likes this.
  25. Aug 20, 2022 at 5:56 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    @Jack McCarthy - BITD I was a big fan of Moog but it seems their quality has slipped in last few years.
    Jack McCarthy likes this.
  26. Aug 20, 2022 at 6:22 PM
    Jack McCarthy
    Bill
    North of Boston
    Spent an hour with Summit Racing texting my experience. Looks like they’ll send me the driver’s side LCA and are also sending me a return label for the damaged one. The saga continues…
    oscardog86 likes this.
  27. Aug 20, 2022 at 6:25 PM
    I was going to say, hit their website and open a chat session. But I guess texting works too.
    I guess everyone is having warehouse issues right now? What the hell?
    Ditto on this. I don't know if it started to slowly happen after TRW Federal-Mogul bought them out (via Cooper acquisition) or what, but quality has degraded over the last decade or so.
  28. Aug 20, 2022 at 10:24 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Best In The Desert? Is BITD an acronym for something other than?
    Siebler likes this.
  29. Aug 20, 2022 at 10:41 PM
    Jack McCarthy
    Bill
    North of Boston
    Back in the day…
    bfunke and RUSTYNUTS[QUOTED] like this.
  30. Aug 20, 2022 at 11:41 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Infrared temp gun on the condenser and radiator? At idle and hopping out after driving it?
    My radiator fins had some blockage I couldn't see until I pulled it (middle of radiator). I had higher than normal temps and A/C that was getting warm at idle. Had yours out recently?
