  1. Aug 6, 2022 at 7:35 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    This for helping the a/c I assume and not engine temps right?
  2. Aug 6, 2022 at 7:37 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Yeah mainly AC. Haha are 1st genys known for shitty AC?
    That’s why I asked a while back about a filter drier, I don’t have one :(
    I’ve weighed in the charge to the ounce, and I trip on head pressure at stop lights:(
  3. Aug 6, 2022 at 7:46 PM
    empty_lord
    05 rollover special
    mines always been fine. the sequoias had a second condenser fan like that though. double cab guys should be able to bolt that on and just wire it. one day i'll toss one on mine to see if it helps at all.. but it doesnt seem like i really need any help with my system
  4. Aug 6, 2022 at 7:59 PM
    FrenchToasty
    Mo
    Bone stock
    Do they have a bigger/rear cooling system that requires the fan?
  5. Aug 6, 2022 at 8:32 PM
    empty_lord
    05 rollover special
    double the capacity
  6. Aug 6, 2022 at 9:20 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I replaced the inside window belt molding on both doors today. 95% solved my window rattle. I say 95% because when my window is all the way down there is a slight rattle. Should be an easy fix with a little foam or tape. Will play around with it a bit more.
    @shifty` I thought you’d be interested in this. After the last posts I was pleased with this fix. Hopefully the results last.
  7. Aug 7, 2022 at 7:18 AM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    DesertRoads, Voss, oscardog86 and 2 others like this.
  8. Aug 7, 2022 at 8:38 AM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    Been slowly working on these for the past week. As usual things come up during a "simple" install. OTR wouldn't come out with a sledge so I had to get a OTR puller but needed to rent a few different ones so that it would fit over where it mounts to the LBJ. Also then discovered that I had to loosed up the steering rack to remove the LCA cam bolts through the rear. Both cams on my passenger side were seized so they needed to be sawzall them out. Finally got them in and will be working on torqueing down all the bolts.
    If you're asking why I'm running them on stock shocks that's probably a good question. I'm dropping the truck off with Geoffrey Beers at Agility Customs to do some work on the truck and was just going to have them do some of the installs but wanted to change my LBJ's immediately for preventative maintenance. My LCA bushings were cracked anyways so if I wanted to change the LBJ figured I'd upgrade to the Solo's. In retrospect I could have done a lot of the suspension work with the front end taken down lol.
    PXL_20220726_185751217.jpg PXL_20220726_185805361.PORTRAIT.jpg PXL_20220807_003834615.jpg
    DesertRoads, Voss, 5N0W808 and 7 others like this.
  9. Aug 7, 2022 at 9:27 AM
    Feno
    Feno New Member
    James
    Berkshires, NY
    03 AC SR5
    Just managed to squeeze this in the back yesterday, almost had to let the tires down to shut the tailgate.
    Talking of squeezing, as anyone had success at getting the drivers seat to move back about another inch or two? I'm 6' 3" and legs a re getting a little cramped. I read a few posts and there didn't seem to be a quick fix?
    Voss, oscardog86, jerryallday and 2 others like this.
  10. Aug 7, 2022 at 9:29 AM
    Thanks for the tag - this was the inner seal that starts near the front corner of the window, then goes up, around, and down into the door along the latch side?
    How hard was install?
  11. Aug 7, 2022 at 10:16 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I know a bunch of guys have put risers under the front legs of the seat. might help you out a little if it doesn't put your legs into the wheel.
  12. Aug 7, 2022 at 10:24 AM
    Feno
    Feno New Member
    James
    Berkshires, NY
    03 AC SR5
    yeah thanks I think ( as you say) that's going to make it worse, I might rip the seat out and have a look
  13. Aug 7, 2022 at 10:48 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Mounting is finished and it clears the release. Held up to the push test. I unplugged the horn but I'll probably end up extending the wires and relocating it.
    Saw this little guy in the yard earlier.
    Casper421, 805Tundra, NUDRAT and 2 others like this.
  14. Aug 7, 2022 at 10:49 AM
    FrenchToasty
    Mo
    Bone stock
    Shibby!
    shifty` and des2mtn[QUOTED] like this.
  15. Aug 7, 2022 at 10:57 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    @des2mtn is it an altitude issue causing the pop-off or maybe not enough vacuum?
  16. Aug 7, 2022 at 11:28 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    and suddenly I miss the desert less. :fenforcer::infantry:
    des2mtn[QUOTED] likes this.
  17. Aug 7, 2022 at 12:42 PM
    I never saw any of these when I was in socal. Seeing this makes me miss Texas though. Two dumpster fires I'm glad I got out of, but I do miss the nature, some of the people, and parks.
  18. Aug 7, 2022 at 12:43 PM
    empty_lord
    05 rollover special
    And that’s why I want a flame thrower
    NUDRAT and des2mtn[QUOTED] like this.
  19. Aug 7, 2022 at 12:44 PM
    des2mtn
    Shady Grove
    Tonto cover
  20. Aug 7, 2022 at 5:13 PM
    FrenchToasty
    Mo
    Bone stock
    She’s a screamer! And I still had to do some custom oem modifications 5F99EE13-CEA6-42D3-9163-631E850453D8.jpg42E033D9-2031-4036-B4DC-E8FEA4CA994B.jpg
    des2mtn and alb1k like this.
  21. Aug 7, 2022 at 6:03 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    I want a flame thrower to clear snow off the driveway.
    Apparently, that's not allowed in the city limits - especially when you have a natural gas line running under the driveway. Sheesh.
  22. Aug 7, 2022 at 6:47 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    hauled a fun 6400lb load about 150 miles to my folks' place. took 'er like a champ. it's amazing the power the truck gained from 3000-4000RPM with the headers.
    MS22, Voss, daveeasa and 5 others like this.
  23. Aug 7, 2022 at 7:24 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I'd like to do this too. I'm only 6' but I usually like to sit way back. The tundra won't let you do it. Never looked much into a way to change it.
  24. Aug 7, 2022 at 7:30 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    i should think you could weld an oversized rectangle that bolts into the original mounting points, but extends further back. You'd mount the rear seat bolts to the back of the frame & the fronts to an added cross bar placed as required. Bar stock would cost you head room, but stronger than flat stock & likely you are longer in the legs than torso if you need the seat further back than all the way back.
    NickB_01TRD[QUOTED] likes this.
  25. Aug 7, 2022 at 7:40 PM
    empty_lord
    05 rollover special
    Messed with the trucks weird issue with radio controls… it’s not the radio. Something else is funky in the truck. So I didn’t damage anything. In the mean time I’ve disabled the illumination for the steering wheel controls. Everything functions fine now. Just really confused what it’s issue is
    Also played with swapping radios in the corolla. No radio I plug in has a functional volume control and no sound comes out. Zero clue why… the cars wired identical to the truck. I need to dig more apparently
    NUDRAT and shifty` like this.
  26. Aug 7, 2022 at 7:45 PM
    Haaaaaaaaaayyyy! :rofl:
    Huh, that is weird. Is it all OEM radios you're plugging into the Corolla? Does the Corolla have a factory amp and/or the donor radios come from vehicles that had one?
    It'd be curious to see the color/pinout map on a Metra harness compared to the same for the donor vehicle's radio if it's the case.
    lsaami[QUOTED] likes this.
  27. Aug 7, 2022 at 7:46 PM
    empty_lord
    05 rollover special
    Harnesses on donor vehicles all have same pin outs. No amp in any of them. All 3 radios function fine in the tundra and I tested the taco for hood measure.
  28. Aug 7, 2022 at 7:50 PM
    empty_lord
    05 rollover special
    the tundra thing is weird. i dont know WTF is its problem. but lights on, steering controls only work for seek up and seek down turns the volume down. nothing else works and the lights turn on only when pressing a button. turn lights off.. it all works fine.. all wiring checks out fine. all i can think of at this point is a have a messed up integration relay.
    all the radios have this issue. tried a different set of switches, and a different spiral cable... nothing changes. im like really confused
  29. Aug 7, 2022 at 8:44 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Do the later year seats go further back than the earlier ones? Or am I misremembering.
    I get 23" from the brake pedal to the seat or about 28 3/4" to the floor below the brake pedal at the top of the floormat.
    Edit: just remembered I'd be 5/16 - 1/2" forward due to my seat risers.
  30. Aug 7, 2022 at 9:20 PM
    NickB_01TRD
    Nick
    KY
    I'll have to measure mine all the way back and see. If I can remember to do it anyway.
