  1. Aug 4, 2022 at 11:49 PM
    daveeasa
    David
    I have a rear sway in on mine, aftermarket. No idea what it does or if I want it :)
    bubons likes this.
  2. Aug 5, 2022 at 12:11 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Nah, its ladder bars or traction bars limit limit wheel hop/axle wrap.
    Also good for towing.
    bubons and 5N0W808[QUOTED] like this.
  3. Aug 5, 2022 at 12:17 AM
    daveeasa
    David
    I did manage to get my 4 pin connected and powered up today. Still need to zip tie it and test to confirm it's working right. Also redid the big bolts attaching the bumper so other than figuring out the flip up plate I'm capable of towing.
    Still need to do a legit 7 pin and the brake controller though.
    shifty` and 5N0W808 like this.
  4. Aug 5, 2022 at 5:48 AM
    Hey hey hey, welcome to the forum @bubons
    Totally forgot to ask, did you go with the Master 'gaiters model?
    I've been debating it, but then I've got to disassemble and paint it. Then hope my paint job didn't suck and won't be flaking or peeling 6mos down the road.
    The only thing that bugs me about it is, I actually pop my tailgate off a couple times a year. The lack of "clean" weatherproof connector + no-wire-touching-metal-holes harshes my OCD's buzz.
    ... ", tactically pro".
    Curious more than anything, what did retrofitting rear entail?
    bubons[QUOTED] likes this.
  5. Aug 5, 2022 at 6:18 AM
    daveeasa
    David
    @shifty` , I’d be happy to prep your masterbater tailgate handle for quick disconnect now that I’ve installed mine. I intend to do that on my own truck once I have a chance. On the bench it should be easy, I have all the goodies. Definitely something I’d be happy to do for you.
    shifty` likes this.
  6. Aug 5, 2022 at 6:20 AM
    daveeasa
    David
    I run mine through the square spare tire hole. Haven’t found a grommet for that yet but I haven’t tried my 3rd gen grommet to see if it might fit. It’s not too bad loose in that spot right now. Maybe not cosmetically perfect but not bad. Plenty of length on the RCA to chew a little inside the tailgate, this allowing the camera to be swapped easily with a replacement.
    shifty` likes this.
  7. Aug 5, 2022 at 9:41 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Welding brackets to my diff housing for the bar itself and to my frame for the end links.
    shifty`[QUOTED] likes this.
  8. Aug 6, 2022 at 7:48 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    De-badging...I bought some cans of Plasti Dip, but after some thought it seemed easier (and nicer looking, IMHO) to just remove them entirely. I used fishing line to saw them off (it was ~ 130 degrees yesterday, so no neat for a heat gun!), then scraped away the biggest chunks of sticky foam with wooden sticks (you can see that most of the sticky foamy stuff stayed on the truck, not the badges). A 3M Eraser Wheel to get most everything off, followed by Goo Gone and Turtle Wax Sticker Remover. I'll post some pics of the finished job after I finish.Badge.jpg BadgeF.jpg
    Voss, oscardog86, RUSTYNUTS and 4 others like this.
  9. Aug 6, 2022 at 10:48 AM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    +1 for that damn 3m eraser. Only way i got the Body Moulding goo off after 20 years of baking on in the AZ sun. MEK and other assorted solvents had nothing on that eraser
    RUSTYNUTS likes this.
  10. Aug 6, 2022 at 11:07 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Wd40 works great
    Jack McCarthy likes this.
  11. Aug 6, 2022 at 11:27 AM
    w666
    Maryland
    Before (months ago)
    After (just now)
    Voss, oscardog86, KK6PD and 3 others like this.
  12. Aug 6, 2022 at 11:37 AM
    Siebler
    CJ
    Eastern Oregon
    I had so many hard baked chunks and stuff that wd40, goof off, citrus oil, etc all just made a gummy mess while taking off very small amounts with massive effort (multiple hours multiple days trying all the tricks, sticks, solvents, etc) and that was not caring about paint since I was prepping to line it anyway so i wasnt being gentle even. Eraser on a drill had entire truck done in 15 minutes.
  13. Aug 6, 2022 at 12:53 PM
    snoope
    snoope The Old Man
    Used it as a Truck :thumbsup:
    Lumber run out to the Big Orange Box store :eek2: :rolleyes: .
    Momma decided to join me as it was her 1st "day trip" since knee surgery and I will tell you , these Extra cabs beat the Taco extra cabs hands down :bowdown::bowdown::bowdown: those "Suicide Doors" are the Bomb :yes:
    Our "4-Wheelie walker" fit perfectly behind the passenger seat once I flipped up the bottom cushion :cool: and she found it easier to get in & out of the Tundra than her Corolla o_O
    And the longer lengths of finish board actually "FIT" in the bed ;)
    Life is good :hattip:
    RUSTYNUTS, NUDRAT and des2mtn like this.
  14. Aug 6, 2022 at 2:17 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Changed out a ball joint now I'm working on how to mount this fan.
    Voss, oscardog86, RUSTYNUTS and 3 others like this.
  15. Aug 6, 2022 at 2:18 PM
    FrenchToasty
    Mo
    Bone stock
    30022CD0-DE19-4EAB-BED2-D695CACF0C19.jpg 8E9F33EE-431F-486A-A55D-65B53F280D87.jpg 95CE79C8-66FD-43CB-8F0B-9A57233BB395.jpg
    Do some sketchy shit like I did
    Voss, RUSTYNUTS, shifty` and 5 others like this.
  16. Aug 6, 2022 at 2:21 PM
    des2mtn
    Shady Grove
    Tonto cover
    Might figure out something like this, nice.
    And yeah, cardboard's sketchy - I'm using OSB board as backing.
  17. Aug 6, 2022 at 2:23 PM
    FrenchToasty
    Mo
    Bone stock
    It’s a piece of 1 by from a pallet, it’s semi safe….
  18. Aug 6, 2022 at 5:19 PM
    des2mtn
    Shady Grove
    Tonto cover
    So I wanted to support all four corners so the fan can't flop around and send the blades into the condenser. This brace is bolted to the sub frame in two spots. Result is looking good so far.
    oscardog86, RUSTYNUTS and 805Tundra like this.
  19. Aug 6, 2022 at 5:25 PM
    FrenchToasty
    Mo
    Bone stock
    She’s deep!!! I feel like I have enough rigidity on the center, I’m mounting behind that pillar so it’s flat and sturdy. And the right side at least has the top close enough to be solid, and the bottom will hopefully be carried by the strength of the aluminum, tactical weight reduction
  20. Aug 6, 2022 at 5:28 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    @FrenchToasty Does the extra fan in front of the condenser help with the AC blowing cold on startup on the morning?
  21. Aug 6, 2022 at 5:30 PM
    des2mtn
    Shady Grove
    Tonto cover
    I am using tabs on the back of the center pillar. I don't have a sheet of anything to do like you did on the left side plus my fan actually is a little bigger than yours
  22. Aug 6, 2022 at 5:43 PM
    FrenchToasty
    Mo
    Bone stock
    Haha yeah on “cold mornings”
    I’ve charged my AC per weight and it wants to trip on hi head when at a light when it’s hot, so I had to “recover” some Freon so it would stop doing that, thus reducing my cooling capacity
  23. Aug 6, 2022 at 5:44 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    HVAC guys.
    RUSTYNUTS and Jack McCarthy like this.
  24. Aug 6, 2022 at 5:46 PM
    FrenchToasty
    Mo
    Bone stock
    Right! Hahaha
    alb1k[QUOTED] likes this.
  25. Aug 6, 2022 at 6:30 PM
    Sunnier
    Sunny
    San Diego, CA
    Pucked.
  26. Aug 6, 2022 at 6:32 PM
    alb1k
    Left Coast
    It's good
    Phucked?
  27. Aug 6, 2022 at 6:59 PM
    Jack McCarthy
    Bill
    North of Boston
    Okay. I guess that’s not an issue I have to worry about since mine doesn’t trip when I’m high.
  28. Aug 6, 2022 at 7:16 PM
    Sunnier
    Sunny
    San Diego, CA
    I always trip when I’m high.
  29. Aug 6, 2022 at 7:21 PM
    FrenchToasty
    Mo
    Bone stock
    Someone’s using the wrong stuff…..
  30. Aug 6, 2022 at 7:23 PM
    FrenchToasty
    Mo
    Bone stock
    @des2mtn be careful for the hood release, you need some clearance……
    Luckily I wanted to add speed holes to the aluminum anyways……
    To close
    just right
    42A08F42-0A92-4491-854B-87FD65281217.jpg 202EB696-D3E3-4A52-8C12-185CA8F57C1C.jpg
    krreddick, Voss, oscardog86 and 2 others like this.
