  1. May 12, 2018 at 8:55 PM
    #391
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    Scraped a fender backing into a covered parking spot pole and either broke or discovered broken access cab window latches. It has not been a positive-direction day for my new-to-me Tundra. At least they are super minor problems - nobody would notice the scrape if I didn't tell them, and $9 on Ebay will fix the window latches better than new. Other than that I incessantly cruised craigslist looking for a camper shell and wrote a post here asking about bed rail systems.
  2. May 13, 2018 at 12:20 AM
    #392
    az chip
    az chip New Member
    Craig
    Arizona
    2003 Tundra TRD
    Installed seat covers. I am a mechanic and cloth seats are my nemesis.
    aRabidChicken, BestGen and Jerry311SD like this.
  3. May 13, 2018 at 12:22 AM
    #393
    az chip
    az chip New Member
    Craig
    Arizona
    2003 Tundra TRD
    If you bought them from the same seller I did. Re-use your old roll pins in the new latches. The ones he provides are the wrong diameter.
    NomadicFrog[QUOTED] likes this.
  4. May 13, 2018 at 9:11 AM
    #394
    NomadicFrog
    Mark
    Flagstaff, Arizona
    I probably did order from the same seller: he mentions in the product description that if his don't fit to drill out the holes larger. I assumed this wasn't a bad idea since apparently the ones he sends are metal and I guess the existing ones are plastic? But I'll take your advice over a random Ebay seller.
  5. May 13, 2018 at 12:37 PM
    #395
    Outbound
    Aaron
    Northern Alberta
    Ordered these SEMA wheels today. Hopefully I'll have them installed within a couple weeks. God bless the USA. Local dealership here in Canadistan wanted $350 CDN pesos per wheel. These came to $1058 CDN pesos. Estimate $130 duty/taxes, and I'm still saving $400+.
    https://www.ebay.com/itm/142209544293
  6. May 13, 2018 at 3:06 PM
    #396
    az chip
    az chip New Member
    Craig
    Arizona
    2003 Tundra TRD
    The problem is that the pin he provides is to small for the latch itself. The OEM pin is to big for the hinge he sells. Drilling out the provided hinge is a perfect fit as the hinge and latch are now snug and no rattle.
  7. May 13, 2018 at 8:37 PM
    #397
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Today for mother's day I put LED headlights and blue LED map lights,door lights and the lights in the DVD player.
    Passenger side only.
    az chip and Jackson like this.
  8. May 13, 2018 at 8:40 PM
    #398
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Love them so far.....
    mudslinger79, Jackson and az chip like this.
  9. May 15, 2018 at 11:09 AM
    #399
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    Or you could get some steel rims for 300 dollars and they look just as good and perform off-road perfectly
    Rex Kramer likes this.
  10. May 15, 2018 at 11:10 AM
    #400
    Need to know stuff
    Does this use the same mounts as stock so, all u need is a ratchet with a socket?
  11. May 15, 2018 at 11:57 AM
    #401
    Outbound
    Aaron
    Northern Alberta
    Yeah...no. They don't look as good. Not by a long shot. Especially since I've never seen any with the same style.
    My truck is pretty low mileage and babied. Its not exactly a beater despite its age. I dont mind having the high end stuff on it. If it had double the mileage and actually had rust...then I'd cheap out.
    dak13 likes this.
  12. May 15, 2018 at 12:03 PM
    #402
    Matty4wd
    Matty4wd Young Tundra Enthusiast
    San Antonio, Texas
    2005 Tundra Limited
    What bulbs did you use for the door lights?
  13. May 15, 2018 at 12:15 PM
    #403
    Need to know stuff
    I guess it comes down to opinion on what looks good
  14. May 15, 2018 at 12:37 PM
    #404
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    I bought these for my Mercedes. Super fuckin bright! I recomend them.
    They are (error free) also My Car freaks out if you put a different bulb in.
    Size 194.
    I had to use diffrent one in the dvd player / Dome light.
    They are (polarity dependent) so if it doesnt work take it out and flip it 180. :thumbsup:
    https://www.amazon.com/AUXITO-Chips...rd_wg=2IGTw&psc=1&refRID=HMGEZWHQMEE5HWAY3DV5
    Matty4wd[QUOTED] likes this.
  15. May 15, 2018 at 1:16 PM
    #405
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    What grill is that ??
  16. May 16, 2018 at 12:48 PM
    #406
    Yota03
    Yota03 Master Yota
    Tennessee
    2003 Toyota Tundra SR5
    Yes comes with new hardware and bolts right up.
  17. May 17, 2018 at 6:27 PM
    #407
    Casper421
    In the woods
    06 DC
    Most would rather have alloy instead of heavier steel. How do steel wheels perform perfectly off-road?
    Brown Bear and Outbound like this.
  18. May 18, 2018 at 6:51 AM
    #408
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    IMG_0310.HEIC.jpg Picked up a nice Leer shell for the truck.
  19. May 18, 2018 at 1:57 PM
    #409
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Flowmaster 40 installed.
    New front speakers. My speakers in the front sound like they are blown.
  20. May 18, 2018 at 2:09 PM
    #410
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    I have a 40 series Flowmaster. Single in/single out. Sounds amazing.
    Matty4wd and Jerry311SD[QUOTED] like this.
  21. May 18, 2018 at 2:15 PM
    #411
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    I got a single in and single out . Dumped infront of the rear axle. Still have the resonator on it .
    Sounds good.
    I'm trying to find a squeak right now. Sounds like a little bird chirping under the truck right now when I hit bumps
    I Grease the rear springs and replaced the carrier bearing. It's still there.....
  22. May 18, 2018 at 3:01 PM
    #412
    mudslinger79
    Christopher
    Williamsburg, Va
    Dude!!!!! Me too!!! I took my oldest son to his Dr. today and heard it going over the harsh speed bumps in the parking lot. Got it on both sides, sounds like in the front wheel/shock/control arm area.
    Jerry311SD likes this.
  23. May 18, 2018 at 3:07 PM
    #413
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Might be the rear shocks from what I'm reading. I'll know when I change them out.
    I have sprayed almost everything under the truck. People on another forum said they had the chirp coming from the top of the rear shock. I'll spray it tonight
    mudslinger79 likes this.
  24. May 18, 2018 at 3:10 PM
    #414
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Read this one here is the one I wsw looking at
  25. May 18, 2018 at 7:43 PM
    #415
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I used to have a squeak in the back. I found out it was the back wall of my bed was slightly bowed in. It was just enough to rub on the back of the cab when going over bumps. I pulled the back wall out about a quarter inch and the sound went way.
    mudslinger79 and Jerry311SD like this.
  26. May 19, 2018 at 11:41 AM
    #416
    Outbound
    Aaron
    Northern Alberta
    Got the new muffler installed today. Had to enlist The Woman for a second set of paws, but I got 'er in. No more drone, nice and quiet. Super happy about that. I went with the NAPA Quiet Flow SS muffler.
    I'm considering Plasti-Dipping my chrome mirror caps black. Not sure if I'll get around to that today though.
  27. May 19, 2018 at 3:34 PM
    #417
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Nice I'll do my mirrors soon
    Outbound[QUOTED] likes this.
  28. May 19, 2018 at 3:43 PM
    #418
    Outbound
    Aaron
    Northern Alberta
    If you beat me to it, let me know if you took the caps off or left them on the truck. From the bit of reading I've done, the caps look like a pain to take off and there's a fairly high risk of breaking the tabs. I'm thinking of taping off the cap, and covering up the immediate area of the truck from overspray then doing the Plasti-Dip without removing them
  29. May 19, 2018 at 3:51 PM
    #419
    mudslinger79
    Christopher
    Williamsburg, Va
    I'm really glad my truck came color matched. No chrome. But, my front bumper was replaced (carfax states accident) well it was not prepped correctly and the paints all fruity and peeling. Pisses me off every time I see it. Got a quote to get it stripped, prepped RIGHT and repainted. That's happening, hopefully, this summer/fall.
  30. May 22, 2018 at 10:46 AM
    #420
    Yota03
    Yota03 Master Yota
    Tennessee
    Installed an Airaid jr cold air intake. It uses the stock box with a high flow dry filter and smoother more direct tube. I also removed the restrictive charcoal filter from the lid of the stock box. Not sure what gains I got since I have no dyno test, but throttle response is definitely a bit better. I think it was a nice addition to my exhaust setup. I'm pretty happy with it.
    Before:
    After:
    Outbound, BestGen, Brown Bear and 3 others like this.
