  1. Jul 16, 2022 at 7:18 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    we need to find a way to flatten that skid plate. Thats the only way most of the bolts will go back in.
    5N0W808[QUOTED] and des2mtn like this.
  2. Jul 16, 2022 at 7:19 PM
    BFH over some wood. Just don't leave too many skid marks in the process.
  3. Jul 16, 2022 at 7:29 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Okay this makes a lot more sense. Break out the Diablo blade and sway bar no more :sawzall:
  4. Jul 16, 2022 at 7:36 PM
    thunder100
    thunder100 New Member
    MD
    Black 06 DC 4x4
    Installed my airbags that have been sitting in the closet for 2 months. Truck held the camper well with stock springs, not much sag (pic of camper is pre air bags). Excited to drive with a little less sponge on bumps and turns. Surprised how stiff it feels at 15psi without a load in the bed.
    MS22, oscardog86, shifty` and 6 others like this.
  5. Jul 17, 2022 at 7:18 AM
    (If you're not on mobile, this should jump straight to the chorus as intended)
    https://www.youtube.com/watch?v=faaxsHyyIzY#t=0m48s
    5N0W808[QUOTED] and Mr.bee like this.
  6. Jul 17, 2022 at 1:41 PM
    cadebucket
    cadebucket New Member
    Utah
    2005 Tundra DC Limited
    this kit off Ebay. https://www.ebay.com/itm/224584488708. The only thing that ended up fitting was the bezel, I ended up modifying the stock headunit mounts to work with my aftermarket headunit.
    shifty`[QUOTED] likes this.
  7. Jul 17, 2022 at 1:59 PM
    Interesting. I took the part number and cross-referenced in a few places.
    I found this review on scAmazon which decribes exactly what me and a lot of the other guys on here found with the Metra kit: Gaps at top and bottom. Same review says the kit you used solves the gap problems us later-1st-gen owners are seeing with Metra's kit.
    I think I'm going to pick up one of the other type and try it out.
  8. Jul 17, 2022 at 2:09 PM
    cadebucket
    Utah
    The the bezel looks great with no gaps. It just sucks that the mounts and harness that came with it didn't fit. I just ended up cutting the stock radio harness because I wanted to get it done. It was never going back to stock anyway.
  9. Jul 17, 2022 at 3:05 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Doing some @shifty` recommended work. I should have ordered a new seal that goes between the window and cowl, but that’s easy enough to add later. Gotta go, I’ve got two chickens to paralyze.
    KK6PD, NUDRAT, Jack McCarthy and 2 others like this.
  10. Jul 17, 2022 at 3:09 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I'm looking at relocating my shock reservoirs, and wondered if anyone saw an issues with this location? Mounting on top of the frame, but clears all hoses and tucks pretty nicely behind the mud/splash guard. What do ya'll think?
  11. Jul 17, 2022 at 3:29 PM
    alb1k
    Left Coast
    It's good
    Someone just did that. Looks like a pretty good spot from here. I’ll try to find the post.
  12. Jul 17, 2022 at 3:38 PM
    alb1k
    Left Coast
    It's good
    Silver1stgen13 and FrenchToasty like this.
  13. Jul 17, 2022 at 4:31 PM
    tundrainsc
    tundrainsc Happy Tundra 1st Gen
    06 Limited 4.7 2WD
    I cleaned the bottom of the motor, around valve covers, steering rack, boots, every thing covered with 16 years of oil and grease. I used Palmolive dish liquid in low pressure power washer. I know I have had a slight valve cover leak in the past. I have been using high mileage Valvoline the last year ( 2000 miles) . The leak seems to have decreased. I am interested to see how the bottom side looks a year from now.
  14. Jul 17, 2022 at 5:06 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
  15. Jul 17, 2022 at 5:09 PM
    alb1k
    Left Coast
    It's good
    Does seem like a good spot, although I don't have front resi...so just observing.
    Kimosabe[QUOTED] likes this.
  16. Jul 17, 2022 at 5:28 PM
    If you're talking about the rubber seal that's at the edge of the cowl, that shrinks with time, it's not sold separately. Gotta buy a whole new cowl piece. @EvilMilkshake was asking about it also.
    If it's something else, 'splain. If it helps, here's pics from my overhaul. Exploded diagrams here. If you snapped any fasteners getting the cowl off, see here.
  17. Jul 17, 2022 at 5:31 PM
    alb1k
    Left Coast
    It's good
    @shifty`
    Yes, and mine shrunk with time. But, not sold separately - bummer.
  18. Jul 17, 2022 at 5:38 PM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    Not today, but 5 days ago I replaced my Ranchos with a fresh set. Here’s how that 5 day old set is holding up. [​IMG] [​IMG]
    Ranchos suck dong. I installed the hardware finger tight and then snugged it once the truck was on the ground as directed by rancho technical support. ~250 miles, 15 on smooth gravel road and 150 Yards of low speed easy rock garden, and here we are.
  19. Jul 17, 2022 at 5:42 PM
    alb1k
    Left Coast
    It's good
    Are you in 1K for that - all 4 corners?
    5 days seems like you have a refund possibility.
    5N0W808 likes this.
  20. Jul 17, 2022 at 5:47 PM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    No. I bought my first set for $177 ea on sale 2 years ago. This is my 2nd time replacing them with the warranty. I have The original shocks on the rear (they’re due for replacement).
  21. Jul 17, 2022 at 6:05 PM
    alb1k
    Left Coast
    It's good
    Well, no refund but upgrade the lower bushings as a possibility.
    FrenchToasty likes this.
  22. Jul 17, 2022 at 6:08 PM
    I started digging today because I was curious how much it would cost if I wanted to replace the bedside rail plastics, the bumper plastics, and the tailgate plastics. I remember @FirstGenVol mentioned the tailgate guard plastic was exorbitant, and I remember looking and seeing it was not proportionally priced. I find it laughable it's around $65 for each bed side rail plastic but I'm in for almost $150 for the tailgate cap, which is way easier to make.
    The plastic bumper "wings" are also reasonable, but the license plate surround is another one where it's just stupid pricing.
    I was happy to see Toyota actually sells the little rubber bumpers at the tip of the grill (circled below). But I'm pretty sure a computer/PC noise-free fan rubber mount would work, and not cost $3/ea
    NUDRAT likes this.
  23. Jul 17, 2022 at 6:10 PM
    daveeasa
    David
    You short bed people and your rail caps…
    shifty` and alb1k like this.
  24. Jul 17, 2022 at 6:12 PM
    alb1k
    Left Coast
    It's good
    I drilled through my midsize bed rail caps - they haven't been visible in 17 years anyway.
  25. Jul 17, 2022 at 6:23 PM
    I was also surprised to learn 1GT AC owners years 2002+ can also get a full replacement power side-slider window for around $600, the entire assembly. Not sure if it's pre-tinted. But still pretty cool.
    Sad you can't just replace the trim around it. I'm looking through all the exploded images, and nada.
    oscardog86 and 5N0W808 like this.
  26. Jul 17, 2022 at 6:27 PM
    daveeasa
    David
    But not RC?
  27. Jul 17, 2022 at 6:34 PM
    daveeasa
    David
    This.
    cut off the back of the cab and weld on the DC from a yard? :)
  28. Jul 17, 2022 at 6:47 PM
    I'm not sure. Only one way to really find out. But you could guesstimate by taking some measurements and comparing to an AC maybe? Unfortunately I don't know if the outer trim is the same on power slider vs. manual slider vs. solid 1pc.
    Actually ... I went ahead and pulled the parts list for an '02 RC Limited 4.7 4WD. Here.
    It would appear there are four window options for the '02 RC, which isn't the case with my '06, note the description on the 4th, in parens, says power slider. The MSRP showing is about 20-30% higher than actual cost to a participating dealer. I'd probably buy the motor used, but the part numbers are the same! 2000-2001 owners may not be so lucky! :
  29. Jul 17, 2022 at 7:02 PM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    I definitely thought about that, but I’m so fed up right now, I don’t want to mess with it. I’m also a tad worried about potentially leaving my truck stranded on jack stands until I can get a replacement shock if something goes wrong.
  30. Jul 17, 2022 at 7:07 PM
    alb1k
    Left Coast
    It's good
    Try to swap them for new replacements under warranty and sell them uninstalled. Sounds like you are switching brands anyway.
    shifty` and NickB_01TRD like this.
