  1. Jul 7, 2022 at 8:12 AM
    ToyoLife
    ToyoLife New Member
    06 DC Limited 4x4
    DIY Emblem Delete. They were trying to charge me $400.00 :eek:. Did it with less then $50.00 of materials and a few hours. Did the side emblems as well.
  2. Jul 7, 2022 at 8:42 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Cant believe they were charging that much! I deleted mine awhile back and havent regretted it once. I think it looks so much cleaner. Did the sides and tailgate as well
  3. Jul 7, 2022 at 8:50 AM
    I dunno, now all I see are the waves, ripples, and dings in the tailgate :D
    But that may also just be what's reflecting off the clearcoat.
    NUDRAT, KK6PD and oscardog86 like this.
  4. Jul 7, 2022 at 8:59 AM
    ToyoLife
    ToyoLife New Member
    06 DC Limited 4x4
    It's the reflection. Tailgate and paint is in great shape. Still need a back up cam tho.
    Seems like folks are just trying to get away with charging as much as they can nowadays.
  5. Jul 7, 2022 at 12:45 PM
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    New drive belt. Was getting squealing at times in the dead of winter but it went away so just got to it now. Checked all the pulleys and they seem fine. Two or three have a tiny bit of play but spin smoothly and without noise so I’m calling them good for now.
    Belt I pulled off was unbranded and had a bunch of small cracks in the ribs:
    New:
    Lol looking at this photo now I kind of want to pull it out and orient the text in my direction. Please tell me I’m insane.
    Lextech, NUDRAT, abcinv and 3 others like this.
  6. Jul 7, 2022 at 1:16 PM
    oscardog86
    Southern California
    Youre insane, haha jk i almost want to do that too now that you mention it
  7. Jul 7, 2022 at 1:20 PM
    Belt wasn't hard, but still some squeal? Did tensioners seem fine? Did you spin all the pulleys to make sure bearings weren't going bad?
  8. Jul 7, 2022 at 1:24 PM
    I would lie awake at night with the image of the upside down Text on that belt. It would haunt me…..
  9. Jul 7, 2022 at 1:33 PM
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    yeah there was never a chance I would leave it alone once I noticed it in the photo lol
    oscardog86 likes this.
  10. Jul 7, 2022 at 1:35 PM
    Now you got me all paranoid. I guess I'm glad I didn't show any text when I did mine.
    My old one was fine. If anyone needs a good Delco 2UZ-FE belt with maybe 1k miles on it, pay the cheap ass ride and it's yours.
    FWIW, it looks like Delco makes the Gates belt or vice-versa.
  11. Jul 7, 2022 at 1:36 PM
    oscardog86
    Southern California
    thats awesome you actually changed it
  12. Jul 7, 2022 at 1:38 PM
    oscardog86
    Southern California
    Finally got around to starting to POR 15 some of the rusty areas under my truck. Did the rear axle last weekend. Got worried about the fact that i painted over the fill and drain plugs but luckily they both cracked loose. Re-torqued and good to go. Did get a little paint on my arm, guess itll be there for a few weeks, haha.
    Probably gonna paint my LCAs this coming weekend.
  13. Jul 7, 2022 at 1:49 PM
    They get to looking old so fast and prefer the HD green belts. Pretty sure this was done during last alternator swap, but the Delco belt was looking brown. When I pulled it out, it was supple, no cracks. Pretty sure it went in with the previous alternator, which would've been like 1k-2k miles ago? Maybe 3k ago. But hardly any use. Didn't realize it until I looked at the invoice for when the factory alternator caught fire. I still need to get rid of the 2k(ish) mile 100A alternator and brand spanking new 130A alternator I've got laying around taking up space.
    w666 and oscardog86[QUOTED] like this.
  14. Jul 7, 2022 at 2:37 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Getting there
    Trailscape, Voss, Filthyphil and 11 others like this.
  15. Jul 7, 2022 at 2:39 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    pretty rad.
    FrenchToasty likes this.
  16. Jul 7, 2022 at 2:45 PM
    daveeasa
    David
    Someone help me understand the benefits of an X in the flow?
  17. Jul 7, 2022 at 2:46 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    It evens out the exhaust pressure and helps with pulses of the exhaust gasses, kinda like a expansion chamber on a 2 stroke
  18. Jul 7, 2022 at 2:46 PM
    daveeasa
    David
    So with a v8, there is significant variation between sides through the cycle?
  19. Jul 7, 2022 at 2:50 PM
    It was mostly sarcasm. I say mostly cause I would have thought about it prior to installation, but likely wouldn’t have changed it if I noticed after. I’m function over form most of the time.
  20. Jul 7, 2022 at 2:53 PM
    empty_lord
    05 rollover special
    Crossplane V8 engines greatly benefit from x pipes unlike most engines.
    Archive, 5N0W808, NUDRAT and 3 others like this.
  21. Jul 7, 2022 at 6:12 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    X and H pipes balance the pressure pulses increasing flow and scavenging. Hp and torque increases are modest. Exhaust will be a little louder and perhaps a bit raspy. Placement seems to usually be more fit than science. Hot rodders been doing since the start of V8s
    Archive, 5N0W808 and FrenchToasty like this.
  22. Jul 7, 2022 at 6:56 PM
    alb1k
    Left Coast
    It's good
    I had a cross pipe on my 77 Jimmy 350cc, but it was also a drive shaft catch, in case of a joint failure, lol.
    5N0W808 likes this.
  23. Jul 7, 2022 at 7:36 PM
    empty_lord
    05 rollover special
    X pipe on a modern v6 is good for abit more power. it benefits all engines. but all my largest gains have been with a v8.
    no real point on an inline 4 unless you have 2 banks. anything more than that.. i havent played with
    oscardog86, alb1k and FrenchToasty like this.
  24. Jul 7, 2022 at 7:45 PM
    FrenchToasty
    Mo
    Bone stock
    I bet @chrisb is itching right now, all this talk about Xs and pipes, and exhaust……. one for the homieB1225087-FB15-4F55-976D-F10AAF34537B.jpg
  25. Jul 7, 2022 at 7:48 PM
    empty_lord
    05 rollover special
    i love how similar yours is to mine.. and i gave this guy no instructions other than where to put the mufflers and to include an X pipe.
  26. Jul 7, 2022 at 7:52 PM
    FrenchToasty
    Mo
    Bone stock
    Hahaha I was wondering!
    Clearly he’s a master at his craft! Did he make the xpipe? All of it looks good, and I bet you’ll be very pleased! That mid range is a kick in the pants and it sounds/feels great. When vvti hits you can kinda feel it more, but ur def pulls hard thru 3-4k
    I want some frame to frame shots, I was able to keep mine all above the frame rails, high and tight like a tiger
    5N0W808 likes this.
  27. Jul 7, 2022 at 7:54 PM
    empty_lord
    05 rollover special
    everythings tucked up high. the only things that might be a bit low are the mufflers. but shouldnt be a lot. i'll get some really good photos when i get the truck back from him. my guess would be monday
  28. Jul 7, 2022 at 7:57 PM
    empty_lord
    05 rollover special
    i think my tundra might be one of the cheapest things to ever set a tire in his shop. LOL rx7 getting a full cage, an audi A7 getting a full exhaust, his 1000+ hp evo, his tesla swapped evo. all that was in the shop when i dropped it off.
    oscardog86 and FrenchToasty like this.
  29. Jul 7, 2022 at 7:57 PM
    FrenchToasty
    Mo
    Bone stock
    The cross over from driver to passenger was the hardest to keep high, because of the drive shaft, but since it has the carrier bearing, I just put lots of weight on the drive shaft and left a finger(fat finger) amount of gap between the two; lots of off roading and heavy flexing, I have never made contact.
    And flanges at the cats for removal? Or only at the headers x cats
  30. Jul 7, 2022 at 7:59 PM
    alb1k
    Left Coast
    It's good
    I'm just going to sit here and pretend I have cool exhaust.
