  1. Jun 28, 2022 at 8:39 AM
    As a former Floridian who worked at a tint & audio shop in the Orlando area for years, separating "good film" and "ceramic" doesn't make sense. Ceramic is great, qualifies as "good film".
    Find an authorized Llumar brand tint installer. Have them install Llumar's ceramic film to whatever limit your local/state ordinance permits. Llumar is one of the best products on the market to this day, 20 years after I left that world, and they still warranty their tint for life. You should have zero problems finding a competent Llumar tint shop near you. If you do, hit their locator tool here. Click the "automotive tint" box. Then put in your zip code and search. If you want nothing but the best, when you get their results, click the "Show LLumar® SelectPro™ Dealers Only" and choose one of the shops (usually ones with a red pin) to get it done.
    Expect to spend between $225-375 depending on your configuration for a GOOD problem-free install that will never bubble, crack, or peel. Trust me, tint is NOT where you want to risk skimping. It's an absolute bitch to clear off residual glue from improperly installed film and start over, we used to charge $200 to remove failed tint installs, which was $5 more than we charged for the actual install back then. It usually took me about 2 hours to peel, clear, and prep windows for new tint without damaging defrost lines etc. Basically people paid double a normal install price, plus what they paid for the original crap tint job.
  2. Jun 28, 2022 at 9:19 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  3. Jun 28, 2022 at 9:24 AM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    One of my links broke after my 2”lift. I was on a trail tho.
  4. Jun 28, 2022 at 11:00 AM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    Ha.
  5. Jun 28, 2022 at 12:03 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Looks like the poly pinch weld puck I bought for my jack isn’t gonna cut it. Didn’t foresee that lifting the jack moves it backward in addition to up. This creates interference with the OEM fiberglass running boards.
    Now I need to order the taller puck. :frusty:
  6. Jun 28, 2022 at 12:40 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    Couldn't agree more and happy to wait
    Looks good, thanks for sharing! This is the route I would go as well, nice to be able to take them off.
    RUSTYNUTS and alb1k[QUOTED] like this.
  7. Jun 28, 2022 at 1:59 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    I'll gladly take that shell off your hands; let me know if you decide to part with it (though I don't know where you're located).
    Oh, the rims look good too!
    Openbaffle[QUOTED] likes this.
  8. Jun 28, 2022 at 2:20 PM
    Are you currently hunting a DC cap in metallic grey?
    I just saw one last month, was $850, but mint shape. Seller was in either Asheville NC or Anderson SC, can't remember which.
    abcinv[QUOTED] likes this.
  9. Jun 28, 2022 at 2:24 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Going full POR 15 mode here. Base coat for the sliders, final for the weld tabs.
    I had it and never used it until now, but their metal prep/etcher stuff does seem like a really good adhesion promoter at this point. I didn't bother with it on the tabs, I just laid the POR 15 up on those.
  10. Jun 28, 2022 at 2:26 PM
    Looks good! Hope you wore gloves. That stuff can be an absolute bitch to get off your skin. :rofl:
    oscardog86 and alb1k[QUOTED] like this.
  11. Jun 28, 2022 at 2:30 PM
    alb1k
    Left Coast
    It's good
    I so wore gloves, even bought a new batch this morning to make sure I had them. I could have used elbow length gloves, but I'm pretty good so far :thumbsup::thumbsup::thumbsup:
    oscardog86, NUDRAT and Jack McCarthy like this.
  12. Jun 28, 2022 at 2:37 PM
    PHM would be proud of you, young apprentice. Gotta take care of those puppies :rofl:
    w666, abcinv, oscardog86 and 5 others like this.
  13. Jun 28, 2022 at 2:54 PM
    Jack McCarthy
    Bill
    North of Boston
    You'll also have to put a coat of black paint over it for the sliders. POR-15 is UV sensitive unless you don't mind paint fade. It's not like you have to worry too much about rust there in CA.
    If you have a non-empty can, use plastic wrap to get a good seal between the can and the lid, it'll last longer. Same if you keep it in the refrigerator although don't put it near the food. lol
    oscardog86 and shifty` like this.
  14. Jun 28, 2022 at 3:46 PM
    alb1k
    Left Coast
    It's good
    I knew about the UV, but good point. They are getting Raptor 2K at some point.
    Sweet tip on the lid - I managed to use my half empty can for this part. Fun fact, I destroyed the lid a few times and it there was no lid. The dried part on top was like 3/8" and I could not bash through it with a screwdriver. I flipped the can over and punched a bleed and an air hole in the bottom to get the 1/3 quart out.
  15. Jun 28, 2022 at 3:51 PM
    alb1k
    Left Coast
    It's good
    I went off the reservation today. Spoon fed a big boy can off Permatex copper anti-seize into my grease gun. Forced out the Super Lube PTFE grease on all 8 corners of the upper and lower control arms. (TC UCA, Solo LCA / (with added zerks).
    I'll report back in 500 miles.
    oscardog86, shifty` and Jack McCarthy like this.
  16. Jun 28, 2022 at 3:59 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Never seen that done, I like it a lot.
    BUT, did anything get done to treat the inside of the frame?
  17. Jun 28, 2022 at 4:03 PM
    alb1k
    Left Coast
    It's good
    No - do you mean heat/rust concerns from the welds?
  18. Jun 28, 2022 at 4:16 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    I got Llumar Ceramic put on when I moved to FL, stuff looked great for year & for the two subsequent owners. 1st choice in my book!
    shifty`[QUOTED] likes this.
  19. Jun 28, 2022 at 4:21 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    yes, exactly
  20. Jun 28, 2022 at 4:40 PM
    alb1k
    Left Coast
    It's good
    What you can see I"m addressing. Any ideas for inside the frame?
    NUDRAT[QUOTED] likes this.
  21. Jun 28, 2022 at 5:10 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Blaster's new product is getting good reviews. I'll likely try it this winter instead of Fluid Film. To get inside use a spray can extension wand.
    Surface Shield® Rust Protectant - B'laster Products (blasterproducts.com)
    Amazon.com: Woolwax® 24" Spray can Extension Wand by Kellsport : Automotive
    These triggers are nice if you're doing a whole truck
    Can-Gun1 2012 Premium Can Tool Aerosol Spray (2-Pack) - - Amazon.com
  22. Jun 28, 2022 at 5:12 PM
    alb1k
    Left Coast
    It's good
    Ah, great call. I want to try the Blasters anyway. I have a few cans of FF here and it's great stuff, not the prettiest.
  23. Jun 28, 2022 at 5:56 PM
    Openbaffle
    Damn. These are looking really nice.
  24. Jun 28, 2022 at 7:04 PM
    alb1k
    Left Coast
    It's good
    I was just under there bolting the things back on for now. Got a little reminder that the frame is only boxed in the front. The only part that was welded behind the box, is still accessible. So the plan is scrape the burnt paint and POR15, I feel much better.
  25. Jun 28, 2022 at 7:40 PM
    snoope
    snoope The Old Man
    Thank you, exactly the "wisdom" I needed....:hattip: thumbnail_IMG_4319 Riva sunset.jpg These Sunsets are not the problem... it is when 2-5 pm comes around :cool:
    NUDRAT and Vallejo206 like this.
  26. Jun 29, 2022 at 2:29 PM
    Openbaffle
    I wasn't rubbing at all but wanted to confirm today. Have plenty of room. Removed my mud guards a while ago. Tons of room with the SPC too.IMG_0563.jpgIMG_0565.jpg
    oscardog86, bmf4069, NUDRAT and 4 others like this.
  27. Jun 29, 2022 at 4:00 PM
    abcinv
    Tommy
    NW Georgia
    I'm not "actively" looking, more like hoping one will fall into my lap.
    But $850 mint...I should probably start looking! That's cheaper than I thought (and is why I haven't spent much time on it).
  28. Jun 29, 2022 at 5:14 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    The 3pm rain helps.
    snoope[QUOTED] and alb1k like this.
  29. Jun 29, 2022 at 6:24 PM
    I'll keep another pair of eyes peeled.
  30. Jun 30, 2022 at 1:30 PM
    New license plate frame in. Was tiring of the dealership frame being there, but I like having a frame.
    I have an extra of these, pay shipping and it's yours. 1st Gen'ers only need apply. EDIT: I think it'll fit in a USPS priority bubble envelope, that's $7.95 IIRC?
    oscardog86, WV8DAD and 5N0W808 like this.
