  1. Jun 15, 2022 at 10:53 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Not Tundra related, but I need some help and I'm probably overthinking things. I just bought a 2001 accord for my soon to be 16 year old and the PO must have nailed a curb really hard. The tie rod and control arm were bent so I replaced those, but still can't get alignment in spec. I took it to a frame shop and they think they can loosen the subframe and shift it over to get things lined up. My question is camber is off and so I'm wondering if the knuckle is bent also. I can wait and see what the frame shop can do ($400 estimate), replace the knuckle now and see where that gets me or buy an adjustable upper ball joint to get camber in spec.
    I guess my concern is spending the $400 at the fame shop and then still having to replace the knuckle. If I'm going to do that, I'd rather just replace the knuckle. I have mental issues with wasting money and if I could have just replaced the knuckle and not spent $400 at the frame shop I'll judge myself for years.
    Somebody want to talk me off the crazy ledge?
  2. Jun 15, 2022 at 11:09 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    How far off?
    Probably best to replace the knuckle if you can DIY it for cheap. And if that doesn't do it then frame shop.
  3. Jun 15, 2022 at 11:16 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    That’s a baofeng 82
    KK6PD and 5N0W808[QUOTED] like this.
  4. Jun 15, 2022 at 11:23 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Y'all need to get on this dude's level
    CodyP, KingSequioa007, KK6PD and 4 others like this.
  5. Jun 15, 2022 at 12:01 PM
    Was speaking of the top bumper strip.
    But generally speaking, any of your trim that was black or dark charcoal which is now ashen. :D
  6. Jun 15, 2022 at 12:04 PM
    Not only this, @rock climber but also, in which direction? Camber, caster, toe?
    Is it possible to compare (or measure) the knuckles on the driver and passenger side with reference points to check?
  7. Jun 15, 2022 at 12:04 PM
    daveeasa
    David
    Yeah, calling Billy right now on the front bumper situation. That thing is not long for this world :)
    I don't know that I'll have much of any black/dark charcoal trim once I'm done. Outside of the decals that is, which are new-ish.
    shifty`[QUOTED] likes this.
  8. Jun 15, 2022 at 12:47 PM
    rock climber
    When I read your question how far off? I thought you were referring to talking me off the ledge and I was thinking "all the way off duh!
    Junkyard knuckle is $85 and close by.
    Good idea.
    Here are the alignment numbers. It's in spec, but just barely.
  9. Jun 15, 2022 at 12:49 PM
    alb1k
    Left Coast
    It's good
    I just got off the phone with Billy. Looks like my sliders are soon to be installed.
  10. Jun 15, 2022 at 12:56 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Looks like one of the RF engineers HAM radio setup from my work.
    Those guys are like next level poindexters. :rofl:
    alb1k likes this.
  11. Jun 15, 2022 at 12:58 PM
    daveeasa
    David
    Hah, he texted me after I called and said he'd call me after he got off the phone. If I had known it was you talking to him I would have said "tell Erik to stop bugging you" or something :) :) :)
    Stoked for you and your sliders!
    oscardog86 and alb1k[QUOTED] like this.
  12. Jun 15, 2022 at 3:41 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Being that far off in caster and camber isn't a knuckle only problem. Not with a new lower control arm.
    If it drives ok, and doesn't wear tires out, leave it alone.
    If it pulls or has some other issue, then have the frame shop work on it. Knuckle may be the camber but the caster would be crossmember/chassis.
  13. Jun 15, 2022 at 4:23 PM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    Nothing to see, but dropped it off with the paint guy today. Between his time and a pre-planned vacation for me, probably won’t have it back in my hands for about a month, but excited to have the end in sight.
    oscardog86 likes this.
  14. Jun 15, 2022 at 4:53 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I’m 500miles from my next oil change. $80 worth of Mobil 1 and Napa gold. I think I’ll take that excuse to do the diffs. Did the t-case 4500 ago. Drain and fill for the trans will start at 10.5k miles.
    MS22, oscardog86 and alb1k like this.
  15. Jun 15, 2022 at 9:14 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Think that the lower ball joints on those fail relatively often. Make sure they are in good shape or replace as preventative. Probably not causing your issue at all just a heads up.
    rock climber[QUOTED] likes this.
  16. Jun 15, 2022 at 11:20 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    Looks like a "Field Day" rig!
    Last Field Day I participated in was in the 90's. We had two earthquakes that night! SoCal 'ay!
    So much for that camping effort!
    des2mtn[QUOTED] and alb1k like this.
  17. Jun 16, 2022 at 12:26 AM
    KK6PD
    ROAD
    I also have the manual for the Baofung 82 that alb1k has, also a nice rig.
    The hot ticket is the Baofung CHIRP software, it's free, works with Windows, and will fully program your radio. The cable you need is the same alb1k needs, a PC-03 Programming cable, Amazon has them $22 bucks!
    https://www.amazon.com/BTECH-PC03-Genuine-Programming-Cable/dp/B00HUB0ONK
    You could take your current radio, READ what's programmed into it, and change from there. There is a lot of things this radio can be programmed to listen to beside GMRS.
    You could send me your radio file, I'll check out what you have, if I make changes, it's easy to upload the new file into the radio!
    I like the midland GMRS, most power, not as many features as the Baofung....
    I also will be installing a Yaesu dual, or possibly QUAD Band rig!
    Toys Toys Toys...
    oscardog86 and 5N0W808[QUOTED] like this.
  18. Jun 16, 2022 at 12:43 AM
    alb1k
    Left Coast
    It's good
    Ha! I run chirp on a Mac. Had to get the right cable. And figure out drivers or versions or whatever. At one time, there seemed to be a magic sequence to make the radio talk to the computer. USB fist, then power radio, whatever, lol. I was fortunate to have a friend like (is it Road?) aka @KK6PD help me with cleaning up building my file/image. And then the settings, oof. But, I have an image that has VHF, UHF, including local fire, law, marine, ham, and whatever the gmrs and other things are. And added a single simplex channel for a trip that worked just fine. But, if any of you need help, do not ask me. Ask @KK6PD, I know enough to tell you he's the one to ask. And it sounds like he will help.
    5N0W808 and KK6PD[QUOTED] like this.
  19. Jun 16, 2022 at 4:20 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm a little behind on this page and apparently missed your tag, so im not sure if you got any more answers on this, but the toytecs are 5100 shocks. Not sure about the springs though.
    It was a little squatted at first.......
    But it calmed down.
    And a somewhat bad before pic from years ago.
    5N0W808, snoope, oscardog86 and 2 others like this.
  20. Jun 16, 2022 at 6:07 AM
    I'm guessing those are Eibach springs.
    Lots of people seem to like the 5100 + Eibach combo. For our AC, I think it's reco'd to run the Eibach 650# springs, but they have a 700# spring too.
    I definitely like your stance, your lift turned out well. I've always lilked the idea of coilovers, but I've nearly always hated the way they ride on vehicles I've used COs to lower. Maybe it's different with lifting. I think a static strut/spring combo is a better fit for me than a CO. That's also the reason I'm trying to get that added feedback/pics from guys like @Dave8699 ... Static is static. If I choose the wrong option of the two in front of me, I can't just crank my CO to adjust, then re-align.
    End goal on this 1st step is maybe 1" rake front to back. It's looking like the 5100/885 is going to get me near-level like your Toytecs, but I'm seeing AC/4WD trucks with this setups looking like they have up to an inch of squat, and AC/2WD with significant squate. I suspect the 5100/884 is going to give me the mild rake I'm seeking out having a AC/4WD with no armor (yet).
    One thing is certain, either option will get me 275/70/17 no-rub clearance w/o excess wheel gap in the fender, and I won't be swapping out early-fatigued parts 5-10k miles down the road, so I can't lose too much. Worst case scenario, I go 5100/884 and wind up with a little too much rake up front and strut shim for a simple no-geometry change solution, or spring swap to 885. or I go 5100/885, end up with a true level, or a tiny bit of squat, and 1" block or 1.5" AAL out back.
  21. Jun 16, 2022 at 7:28 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I rub a tiny bit on the fender liner while turning left forwards or back. I'm betting a proper alignment would get rid of that.
    The ride isn't necessarily rough, but it isn't squishy.
    For the rake, we left the AAL out due to time and tool constraints, but that should put the 1" rake back in, but I'll jack the COs up to get it back level. Eventually.
    5N0W808 and shifty`[QUOTED] like this.
  22. Jun 16, 2022 at 8:31 AM
    I'm guessing some of that may be due to the how much tire meat you've got running those 16s, too. But would need to break out a ruler with a decent comparison to prove it. Perception of height/width is limited by photo, but the general meat I'm seeing on your 16s looks on par with what you'd get in a 285/70/17.
  23. Jun 16, 2022 at 8:07 PM
    Fleawalker
    Fleawalker New Member
    South FL
    2001 V8 4x4 Access Cab
    None (yet)
    @bmf4069 Ironman is looking awesome man. I was looking to be your twin but brothers from other mothers suits me just fine. Well done and I hope you work out the little issues soon.
    bmf4069 likes this.
  24. Jun 16, 2022 at 8:24 PM
    Fleawalker
    South FL
    None (yet)
    Have you considered Roadmaster RAS ?
  25. Jun 16, 2022 at 8:27 PM
    Fleawalker
    South FL
    None (yet)
    I had the RAS installed and it raised the rear a decent amount
  26. Jun 16, 2022 at 9:35 PM
    Fleawalker
    South FL
    None (yet)
  27. Jun 16, 2022 at 10:21 PM
    Fleawalker
    South FL
    None (yet)
    You can see how much extra lift from the RAS gave to the springs. I have some rust work to doSAM_0305.jpg
    dirtnsmores, Krewcial, Voss and 2 others like this.
  28. Jun 16, 2022 at 10:28 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Can’t see it from my house! (The rust)
    dadjazz, Voss and 5N0W808 like this.
  29. Jun 17, 2022 at 4:17 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I've got the AAL sitting in the truck. I just need it to not be hot as hades out to get it on. It really sucks not having a garage or shade to work in. Canopy would work, but I can't get one over the truck in the driveway and stake it down, and with the wind here it HAS to be staked down.
  30. Jun 17, 2022 at 4:19 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    More than likely. I'll get a good alignment then we can carry a rotozip, sawzall, and BFH on the trail with us. :D
    5N0W808[QUOTED] likes this.
