  1. May 4, 2022 at 8:51 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    I just bought a singer sewing machine a couple weeks ago an taught myself to sew so i could make my own awning bag. Worked out great and i can see having a sewing machine being useful for lots of other little projects down the road. Id like to make some tool bags or something for camping as well.
    RUSTYNUTS, alb1k, NUDRAT and 3 others like this.
  2. May 4, 2022 at 11:08 AM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    My truck's battery platform (the steel piece, not the plastic tray) was covered with powdered battery acid both on top and underneath. I tried to remove it but couldn't lift it at all even with the 4 bolts removed (2 10mm, 2 12mm), and prying on it would bend the metal instead of getting it to lift off. I think it's rusted on there real tight. So instead of risking bent metal, I vacuumed it up and sprayed a ton of WD40 on and underneath it. Better than nothing... It looks like crap but way better than before.
    Also, one of my front breather valves is seized. Gonna have to deal with that. I don't know if that's the diff or the transfer case.
    Mogo Gogo, Jack McCarthy and NUDRAT like this.
  3. May 4, 2022 at 12:53 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    That’s not tacked down?
  4. May 4, 2022 at 1:00 PM
    DarkMint
    Ben
    Maybe it is. I assumed not because there is at least 1 bolt there purely to retain it it seems.
    alb1k[QUOTED] likes this.
  5. May 4, 2022 at 1:41 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Pretty sure @DarkMint and my 04 DC are same and mine is indeed tacked in a few places. I’m not in position to remove all and check but I can see some of the tacked places.
    One thing he is showing are those 2 hoses with caps and I am now curious what they are because I have same hoses.
    DarkMint and alb1k[QUOTED] like this.
  6. May 4, 2022 at 2:44 PM
    alb1k
    Left Coast
    It's good
    ALICE radio packs look interesting and have wide strap attachment points. Maybe too tall for AC, close for DC, but, I am trying a german military number that is much shorter and cheap as surplus.
    shifty` likes this.
  7. May 4, 2022 at 3:03 PM
    shifty` Inside his chest they found ten thousand pencils
    I have similar on my '06, I never noticed those until I was cleaning up my VC leaks after finishing the gaskets. Both are breathers from the front 4wd stuff, tcase and diff, or the tcase and trans, or trans and diff, I'd need to go back and look. Pretty sure tcase and diff.
    Up till the point you said you sprayed it with WD40, I was going to say you should indiscriminantly spray a rust converter product up in there. WD40 will repel the paint from sticking now it's there.
    Throwing a wire bottlebrush on a drill and shoving it up under the metal is a good way to break off the excess rust flakes if you really want to get at it. I'd say use a flex hone, but I don't think it'd get into the right-angles and corners too well.
    chrisb and BubbaW[QUOTED] like this.
  8. May 4, 2022 at 3:08 PM
    I hate I'm linking to scAmazon's site, you can probably get a similar set at Harbor Freight or Northern Tool if there's one local to you. It'll probably be made from the same factory scAmazon is sourcing theirs from. But a kit like this is a good way to go. Brass is more forgiving on the metal and paint, if it's a concern. If not, steel bristles will strip more aggressively. Leave the round brush-end intact so it's easier to chuck up in the drill, or cut it off shorter and fold it up so it'll chuck nice.
    https://www.amazon.com/dp/B07C1ZXZ34/
    DarkMint, NUDRAT and alb1k like this.
  9. May 4, 2022 at 5:52 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    Applied some of my surfboard ding repairs skills to the truck today. Slightly better looking and stronger then the duck tape that was there before.
    1C56885E-4462-4C0B-B3D6-6F154272C0CC.jpg 392BBBF3-BA24-43E5-BBF2-44E64D1FEDC9.jpg
    F9097517-D3B8-4116-B690-5CAD4150CE59.jpg 7714BB72-CF2C-43F7-BAB0-6D52CBDD2D7E.jpg
  10. May 4, 2022 at 6:26 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    1st gen tundra center console is too round, but maybe a 2nd gen console or some other flat sided, narrow junkyard console would fit.
    txagg likes this.
  11. May 4, 2022 at 6:34 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    I don't get why so many physicians are automobile clueless.
    A vehicle is so incredibly similar in operation to a human body, they're practically fraternal twins.
  12. May 4, 2022 at 6:35 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    There is a guy on mud that sews heavy canvas tool bags to match the factory original ones. Made the mistake of going down that rabbit hole and reading through his posts. Pretty interesting stuff if you have the time. He got pretty deep talking about the machines he used and what was good vs not.
  13. May 4, 2022 at 6:45 PM
    alb1k
    Left Coast
    It's good
    Thank you brother, I'll check that out. I used to have a Consew, which was a good Chinese (I think) knock off of a Singer. I bet he likes Juki.
    txagg[QUOTED] likes this.
  14. May 4, 2022 at 6:50 PM
    805Tundra
    Ben
    Central Coast
    comp was kind of going off last night. Stayed up way to late watching lol
    FrenchToasty and alb1k[QUOTED] like this.
  15. May 4, 2022 at 6:54 PM
    alb1k
    Left Coast
    It's good
    That's the problem with the AUS leg. But, finally a good finals day. Notice how they held off on the ladies semis because they wanted to give time for the swell to drop? They need to stop these in water interviews.
  16. May 4, 2022 at 7:01 PM
    805Tundra
    Ben
    Central Coast
    I know it starts so late. Just wait for the next one in Indo. I’m staying up for that one for sure, I don’t care if my kids wake me up at 630am. Haha ya too big for them. The commentators are a bunch of dummies.
  17. May 4, 2022 at 7:06 PM
    alb1k
    Left Coast
    It's good
    So bad, I usually have the volume off. I wish they would get the guys announcing the PGA. That would be awesome.
    805Tundra[QUOTED] likes this.
  18. May 4, 2022 at 7:22 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    I could be way off, but from what I remember it was commercial equipment that's not really made anymore. Also seems like they typically had to be sourced from another country like Vietnam or something. Toyota made sewing machines for some time.
    chrisb and alb1k[QUOTED] like this.
  19. May 4, 2022 at 7:25 PM
    alb1k
    Left Coast
    It's good
    Es verdad...
    ktundra, NUDRAT, Darkness and 3 others like this.
  20. May 4, 2022 at 7:27 PM
    805Tundra
    Ben
    Central Coast
    Did you see how they got the winners name wrong twice lol
  21. May 4, 2022 at 7:34 PM
    alb1k
    Left Coast
    It's good
    I cringed the when Kaipo shouted on the ski "Margrets World Champ, JJF!" and Robo next to him is, uh, Jack Robinson...
  22. May 4, 2022 at 7:47 PM
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    Not Tundra related but still counts in my book. Wife’s 2003 Sequoia Limited was bought with the power folding mirrors not working and bad slop in the mirrors. Previous owner super glued switch at the half way point to keep the motor from running. Well a $40 used ebay switch and a $10 plastic gear and lots of cussing and I got it to work.
    ktundra, NUDRAT, tacoguybill and 7 others like this.
  23. May 4, 2022 at 7:47 PM
    805Tundra
    Ben
    Central Coast
    Dude so bad, then the chick called him Jack Florence :rofl:
  24. May 4, 2022 at 7:47 PM
    alb1k
    Left Coast
    It's good
    Jeez. LOL
  25. May 5, 2022 at 6:21 AM
    Power folding as in, fold in and out for parking purpose? I didn't know that was a thing. I have zero purpose for it but would love that on my truck. Wonder how tough a retrofit is?
    FrenchToasty likes this.
  26. May 5, 2022 at 6:24 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    If you look up “antman” on t4r.org he is the king of bad ass mods, abs he retrofitted power folding mirrors into his 5th gen, someone then stole his idea and started mass producing it. But you might find some good info on his build page.
    ktundra, NUDRAT, chrisb and 1 other person like this.
  27. May 5, 2022 at 7:17 AM
    daveeasa
    David
    I’ve come across several power folding mirrors in my time searching. They are significantly more expensive. I’ve never had a vehicle with them so I don’t know what I’m missing. Typically when parking on the street it’s easy enough to futz with the driver side by hand. I think real tow mirrors might be a different story but while I do like heated mirrors, I don’t quite get the folding yet.
    I also don’t understand why tow mirrors don’t have integrated ditch lights. That seems like such a no brainer.
    oscardog86 likes this.
  28. May 5, 2022 at 7:33 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I would’ve loved having power folding mirrors on my tundra. Great to easily pull into most new home garages with only a couple of inches clearance on either side. Also parking on Boston’s narrow city streets where mirrors have been clipped by drivers on multiple occasions.
    shifty` likes this.
  29. May 5, 2022 at 7:50 AM
    dlowry81
    dlowry81 New Member
    Doug
    Yes power fold in for parking purposes. Cool feature, but a PIA to fix. I'm not sure why the Tundra isn't the same, but I prefer the mirror switch location in the sequoia which is where that odd little console plug is in front of the drive side cup holder on the Tundra. Both share the same console it's just the Tundra has the weird little hole/plug and the Sequoia has the mirror switch adjustment and power fold switch there. The mirrors are crazy expensive and the plugs are completely different so any retrofit would be fairly work intensive I think.
  30. May 5, 2022 at 6:21 PM
    alb1k
    Left Coast
    It's good
    The guy in Canada wants to make me some custom bags so I’ll be doing that I think.
    Here’s step one of the tonneau rack. I really don’t recommend this for my style of tonneau, they weren’t made for load bearing. Better to get a backflip and mount your rack to your rails. Next step is to bolt the top down, trim the rear lip, and pull it all off to deal with the failing clear coat.
