  1. Apr 28, 2022 at 8:31 AM
    I agree with Nick's take on this one. But Bill, you're saying the part inside wasn't Denso/Toyota labeled? I've heard that with other things, or at least one other thing, the carrier bearing, which I think is spicer, and possibly with gears.
  2. Apr 28, 2022 at 2:21 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Thanks for this! During a truck bath I noticed the cowl was loose. Thought of you.
    shifty`[QUOTED] likes this.
  3. Apr 28, 2022 at 6:47 PM
    tacoguybill
    tacoguybill The Burrito Bandido
    Bill
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    @shifty` correct, the part inside said Koyo Japan just like the one in the photo, wish I had taken a picture of it
  4. Apr 29, 2022 at 2:59 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Koyo is the OEM bearing for Toyota.
  5. Apr 29, 2022 at 12:14 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I'll be interested to hear how that can works for you @Mogo Gogo
    Mogo Gogo likes this.
  6. Apr 29, 2022 at 2:02 PM
    tacoguybill
    Bill
    Saaaan Diaaago
    Well shit that’s about $40 less than I needed to pay through the dealership if I’d have gone through partsgeek
  7. Apr 29, 2022 at 5:05 PM
    Geo_travlr
    Geo_travlr New Member
    2005 Tundra AC limited
    Well, I believe I have the Icon 3 leaf progressive pack and I left my overload spring. It gave me around 1.5'' of lift in the rear. It's not a rougher ride at all, but I do have a canopy and various tools in the bed.
    Darkness likes this.
  8. Apr 29, 2022 at 11:29 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Late update but finally pit some real miles on the truck after doing the DD injectors/plugs/manifold cleanout with starter.
    Just shy of 1000 miles, My MPG went from a previous very consistent 13.5ish to 15.5-16.9 on the last 3 tanks (varying highway). Undoubtedly because it holds gears better and such which was unbelievably noticable going accross the mountains and some long steep grades.
    Worth the maintenance/ upgrade for sure.
  9. Apr 29, 2022 at 11:57 PM
    Geo_travlr
  10. Apr 30, 2022 at 12:00 AM
    Geo_travlr
    Put the overload back. That'll give you lift in the rear. I installed mine with the overload in, no problem. If you cut down the U bolts you might have to buy new ones that'll be long enough.
  11. Apr 30, 2022 at 12:49 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Finally got some good wifi so I'm catching up here.
    EVERYBODY who has ucas and coilovers should do this. You should also turn your wheel lock to lock and repeat to see how all that works out. Good job taking the time for homework, it saves a lot of trouble later.
    It might depend what hitch. I have the Toyota one and didn't mess with it.
  12. Apr 30, 2022 at 7:25 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm not sure what mine was. Maybe when Casey gets back from his adventures with Bob he can examine it.
  13. Apr 30, 2022 at 8:25 AM
    alb1k
    Left Coast
    It's good
    I was scratching my head on that one and chalked it up to maybe AC/DC. I swapped springs twice and shackles once and never pulled the hitch.
    chrisb likes this.
  14. Apr 30, 2022 at 8:27 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Well, the good news is I got the starter out. “F” that thing. The bad news is that I pulled the wire out of the knock sensor connector…
    I tried re-pinning the connector and I think I’m going to have to give it a try and see if it works.
    Worst case, I can replace it later. And now I know I can get the plenum out of the truck in less than 40 minutes. Stupid, weak, flimsy ass wiring!
    chrisb, RUSTYNUTS and bmf4069 like this.
  15. Apr 30, 2022 at 11:37 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yup. I've had that thing off 3 times now. I've gotten pretty good at it.
  16. Apr 30, 2022 at 11:51 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Thinking that I should go the ospho route since I grease rubbed my frame? Or I may have made things harder for either product application. I just wanna don't right and 1 time. I'm not sure how the hell I'm gonna get the grease off totally for either application...
  17. Apr 30, 2022 at 12:18 PM
    Kauaitundra1
    Kauaitundra1 New Member
    2000 TRD Tundra limited 4x4
    Anyone know if a ECM for our 1st gen trucks is plug and play? Or need dealer programming?
  18. Apr 30, 2022 at 12:18 PM
    Kauaitundra1
    Anyone ever had a failed throttle motor?, I think the magnetic clutch wont engage as the motor runs whenever it has battery power?
  19. Apr 30, 2022 at 12:38 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    So far it seems to be working. I buttoned everything back up, connected the battery and winced as I cranked it. Hope it lasts for at least another 200k miles.
    **** Scratch that. DTC shows P0330. Damnit!!
  20. Apr 30, 2022 at 2:48 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    Got a quick question for you all…so obviously my tires are a bit loud but whenever I go around a gradual right hand curve they quiet down and seem smoother. More noticeable at higher speeds. No steering shake at all. Could this be an alignment issue? Balance issue? Or worse? Or nothing?
  21. Apr 30, 2022 at 3:26 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I'll keep that one in mind. I probably have stippled a few if I knew it's meaning.
    Curious what that below wire is....the stippled wire ?
  22. Apr 30, 2022 at 3:31 PM
    alb1k
    Left Coast
    It's good
    Are those new tires or could it be a tire wear issue?
  23. Apr 30, 2022 at 3:38 PM
    805Tundra
    Ben
    Central Coast
    They are pretty new, maybe 6k miles on them. It is the weirdest thing. I would LOVE them if they were as quiet on the right hand curves. I just want to make sure there isn't something else i might be missing.
  24. Apr 30, 2022 at 3:49 PM
    alb1k
    Left Coast
    It's good
    Weird. Seems to me tire noise is generally from tires. I've heard of tires getting both louder and quieter with wear. Haven't heard the turn thing. Have you put the fronts to the back since you got them?
    805Tundra[QUOTED] likes this.
  25. Apr 30, 2022 at 3:54 PM
    805Tundra
    Ben
    Central Coast
    It is definitely odd, I am taking the truck in to get another alignment in a couple months after the suspension is completely done settling. I will ask them to rotate and rebalance and see if that helps. It might be a tire thing which is fine with me, just wanted to make sure it isn't something more serious.
  26. Apr 30, 2022 at 3:57 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    You sure it's a tire issue and not a wheel bearing issue?
  27. Apr 30, 2022 at 4:05 PM
    805Tundra
    Ben
    Central Coast
    I don't think it its a wheel bearing issue but not possitive at the moment, no squealing or growling with sharp turns. At the moment just gets quieter on slight gradual turns to the right, mainly around curves.
  28. Apr 30, 2022 at 4:16 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Every wheel bearing I've had go out started out as just overall louder road noise and a hey where'd that noise go in a curve.
    Not saying it's 100 percent your issue but if was tires I'd expect it on both sides
  29. Apr 30, 2022 at 4:21 PM
    805Tundra
    Ben
    Central Coast
    For sure, it isn't side specific at the moment. just quieter in the cab. the rest of the time it just sounds like loud knobby tires, but who knows it could be.
  30. Apr 30, 2022 at 5:31 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Last nights fire
    Meteor crater, quite the tourist trap, but it was pretty cool
    Another natural wonder, super sad it wasnt running at all, but last week it was a gusher
    10D8D839-8789-4795-A663-C7892FC174B8.jpg 136700F2-0C72-4F5D-802E-77DDA87D626B.jpg
    Schnebly at sunset, I thought it was washed out from the dust, probably from the fires…..
    Uglies for dinner…..mmmmm
    Schnebly look out during the day, can’t beat that with a rock!
    E64156D8-5F31-4715-BED9-DB6827F8911B.jpg E0A99656-66C7-48AA-91DF-609A11C9EE89.jpg 7E2FDB5D-7921-49A5-ACE1-C788D98AA9B0.jpg E2CF5CD0-55B1-4722-A999-73D519EA5938.jpg
    Loaded and squatting good, not much travel to the bump stops, new leafs are in order!
    Me throwing a rock and totally missing the water down below, if you note the hut at the top right in the other pic for scale….
    Had a great time with @des2mtn and @Casper421, thanks for putting up with my boys, the dogs, and the Ford! They had a ton of fun too!
    Voss, ktundra, robabeatle and 15 others like this.
