  1. Apr 23, 2022 at 8:09 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
  2. Apr 23, 2022 at 8:38 PM
    2005tundra_nopayments
    2005tundra_nopayments 1st gen Tundy
    Jr
    Central Ca
    2005 tundra double cab 4.7
    give us the details! I want leather like that in my truck
    KK6PD likes this.
  3. Apr 23, 2022 at 9:15 PM
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    Katzkins $1300 installed
  4. Apr 24, 2022 at 8:02 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Noice!
    Darkness likes this.
  5. Apr 24, 2022 at 8:22 AM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    I love my katskins; really transformed a 20 year old truck.
  6. Apr 24, 2022 at 3:00 PM
    shifty` Inside his chest they found ten thousand pencils
    Been stuck in classes the last couple of days (work) but managed to knock this out. Potato pictures, but I like the look and operation of this BakFlip FM a hell of a lot more than my TonnoPro, so I guess the TonnoPro is going up for sale, $125 here, $150 on CL.
  7. Apr 24, 2022 at 3:01 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Did you treat it with Crisco or is it naturally that shiny?
    Darkness, bmf4069, robabeatle and 3 others like this.
  8. Apr 24, 2022 at 3:11 PM
    Unfortunately, it's naturally that shiny. Which, in reality, my truck is shiny, so it's not as obvious out in the sunlight, it just looks extra glossy in shadows.
  9. Apr 24, 2022 at 3:22 PM
    artsr2002
    'Yonder
  10. Apr 24, 2022 at 4:34 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Did and learned a few things today I’ll cover this eve. Here’s the coil-out sitting on stops wheel stuff.
    Voss, Darkness, bmf4069 and 8 others like this.
  11. Apr 24, 2022 at 5:14 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Just wait until you need to pull your leaf springs (if you have a hitch).
  12. Apr 24, 2022 at 5:19 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    This is not what i need to hear since I need to replace my leaf spring bushings. :facepalm:
    bmf4069, 805Tundra, Mogo Gogo and 2 others like this.
  13. Apr 24, 2022 at 5:21 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Enough rust to need new bolts? It would be worth it to cut em off and put the nuts on the frame side.
    toyota engineers would climb over a mountain of virgins to screw a mechanic.
    Durk2, bmf4069, chrisb and 4 others like this.
  14. Apr 24, 2022 at 5:26 PM
    Jack McCarthy
    Bill
    North of Boston
    I guess I’ll find out when I put the impact wrench on them. They don’t appear corroded enough to distort the nut or threads.
  15. Apr 24, 2022 at 5:44 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    Replaced valve cover gaskets, spark plugs, and PCV valve between yesterday and today. Also cleaned up the valve covers a bit while they were out.
    Pretty pleased to see that the previous owner took care of the engine.
    Passenger side
    Driver side
    Spark plugs - replaced not that long ago, but I figured while replacing spark plug seals it would be good to inspect and replace.
    oscardog86, bmf4069, chrisb and 10 others like this.
  16. Apr 24, 2022 at 5:45 PM
    FrenchToasty
    Mo
    Bone stock
    Plugs don’t look terrible, maybe keep them for spares, or make a wind chime
    chrisb, 805Tundra, Sirfive and 3 others like this.
  17. Apr 24, 2022 at 8:23 PM
    alb1k
    Left Coast
    It's good
    Today was productive. Test fit some 1.25" Spidertrax spacers. Completely removes any frame rub with room to spare. Crowds the pinch weld and windshield reservoir. But, gave me a good baseline because I'm testing .75" spacers tomorrow. Either .75" does it or I go 1.00". Once I know I'm ordering them in steel.
    I modded the pinch weld with no cuts or drilling, went with the less is more approach. If I need more room back there, which I doubt, it means modding the tub.
    If you have changed a lot on your front suspension - I recommend pulling your springs and sway bar sometime and measuring your tower to bottom shock mount distance with as much truck weight on the bump stops as possible. Showed me two things. Solo arms engage the front bump stop first, OEM engage the rear first. And, there's more distance from the top of the Solo LCAs to the bump stops. I spaced my stops down 3/8". Also begins to show where your tires could bash on up travel and on up travel turns.
    I just realized I didn’t take any final pinch weld mod photos….
    Voss, Darkness, oscardog86 and 9 others like this.
  18. Apr 24, 2022 at 8:25 PM
    FrenchToasty
    Mo
    Bone stock
    Did you find any mushrooms down there?
  19. Apr 24, 2022 at 8:32 PM
    alb1k
    Left Coast
    It's good
    No kidding. Moist rich looking soil. Maybe just wet dirt, but It felt like potting soil...
  20. Apr 25, 2022 at 8:43 AM
    Yours is exactly what I expected and hoped to see @72k(ish) miles. Wasn't the reality I found, I'm slightly jealous. :D Reply or two after that, you can see how much crust I scrubbed, blew and vacuumed out out with the time I had available - some really substantial chunks came out from under the baffle - but I'm super disappointed with what I saw as you can imagine.
    I should've swapped my plugs while in there, but I wanted to re-boot a couple of my coils (4&6) because they were slightly toasty.
    Anyway, good find on your side, that's comforting to see, your internals look great. I have a series of flushes and short-interval oil changes coming up to try and clear out and purge the remaining crust and varnish, which means lots of sweating for me as I watch my oil pressure needle between OCI hoping none of that garbage clogs my pickup tube screen.
  21. Apr 25, 2022 at 9:30 AM
    daveeasa
    David
    Is the PCV valve a normal wear item? But a pain to replace if valve cover gaskets already done?
  22. Apr 25, 2022 at 9:33 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Thanks @shifty` ya I was pretty pleased considering its sitting at 234k miles. Part of the reason I bought the truck was I know the previous owner and he takes great care of everything he has. I'm sure if you're persistent and patient you can get that stuff flushed out without causing any clogging issues.
    While in there I discovered I need to replace a couple coils.
    shifty` likes this.
  23. Apr 25, 2022 at 9:34 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    PCV should be a normal wear item, but I don't know if there's a maintenance interval for it. Should be easy and accessible after VCs are done.
  24. Apr 25, 2022 at 9:51 AM
    Jack McCarthy
    Bill
    North of Boston
    Takes less than a minute to replace the old one. You can even pull out the old one and test it by shaking it and blowing through it. (Only works in one direction)
    alb1k and daveeasa[QUOTED] like this.
  25. Apr 25, 2022 at 10:33 AM
    Yes, it is. I think the OEM change interval is 15, 20 or 30k miles? I looked it up in my OM, but don't recall the maintenance interval, was definitely 30k/mi or less though.
    For my later-model 1GT it's easy thread-in/out. I think on earlier models it may be a simple pop-in/out?
    I swapped mine out before doing my VC gaskets because I had concerns it may've been stuck and maybe causing extra pressure, which caused my sudden VC leak. When I pulled it, it's definitely chunky in there, same shit you see in my linked pics was gummed in there, but it was technically operating.
    Anyway, I'd do it if I were you. The valve itself is cheap af, and if you haven't done it yet or know it hasn't been doing, can't hurt anything, I guess?
    oscardog86 and alb1k like this.
  26. Apr 25, 2022 at 10:37 AM
    Thanks for the vote of confidence. Just a little extra work I thought I'd be avoiding (along with annoying maintenance like VC gaskets I wasn't expecting to suffer with), I'll get it done, and up to MY normal level of expectation for how my vehicles would be maintained. This whole situation has just inspired me to do a full fluid rotation on everything at this point to get to a baseline now I've seen that nonsense.
    RE: Coils, not sure if you caught it, maybe your tubes are cracked and this doesn't apply, but for $50 Denso has their name on a set to re-boot and re-spring the coils. https://www.rockauto.com/en/moreinfo.php?pk=4718148&cc=1426935&pt=10150
    5% coupon for RockAuto is floating around here also, which should cover shipping and maybe part of tax.
    alb1k likes this.
  27. Apr 25, 2022 at 11:36 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Good thinking on the fluid swap. Makes a world of difference.
    Sadly, I have 2 coils that are cracked and need full replacement. Sucks, cuz I just ordered a starter from Rockauto and should have ordered coils too.
  28. Apr 25, 2022 at 3:25 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Rubbing Issue - Do I need an alignment
    I've noticed recently that my driver-side tire is rubbing on the bumper trim; most noticeably when backing out of the driveway or turning and the shock compressing. I measured clearance between tire and trim and it seems the tire is more forward on the driver side. No issues with the passenger side. I'm wondering if my LCA could have moved, and if a new alignment is needed? Or could it be caused by something else?
  29. Apr 25, 2022 at 3:27 PM
    FrenchToasty
    Mo
    Bone stock
    Put a bunch of high octane doll hairs in the tank today!
  30. Apr 25, 2022 at 5:42 PM
    FrenchToasty
    Mo
    Bone stock
    Thanks fellas and fellinas, the clutches are soooo much happier! I don’t even think I herd(@Tundra2) them bark as I was backing out of my driveway to go do unnecessary 8s; while I was there I thought this clapped out Mercedes’ was starting a fire in the dumpster? So after they left I went and CIO and the lid was melted but nothing actively burning, so maybe they were just burning oil?
    Anyways I did a bunch of locked turns from a stop while all the Bettie’s were pushing their carts and walking in the center of the driving isle….. and even some off camber sharp turns down some of the drainage in the back. Feels so much better not feeling that rachet coming from the rear, now I can ocd on other weird noises…..
    Darkness, chrisb, tacoguybill and 7 others like this.
