  1. Apr 12, 2022 at 9:54 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    @Rheywood456 That was a sick video, thanks for sharing! Is that at Lake Powell? Or Ozarks?
    Rheywood456 and FrenchToasty like this.
  2. Apr 12, 2022 at 10:01 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Denso is the OEM manufacturer for radiators. You can order one from Rock Auto or other vendors for a lot less than Toyota is going to charge you for the same thing.
    Sweet video!
  3. Apr 12, 2022 at 1:42 PM
    Feno
    Feno New Member
    James
    Berkshires, NY
    03 AC SR5
    Finally, got the cabin whisper quiet, I can't believe how well these first gens drive, so smooth, coming from a POS '05 ranger I guess anything makes a difference. If you have a wind rushing noise coming from behind you in an Access cab, use a piece of garage door opening seal ( 6 bucks @ Lowes) against the cab frame to butt up against the door seal around the rear hinge, perfect!
    805Tundra, bmf4069, Sirfive and 3 others like this.
  4. Apr 12, 2022 at 6:12 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Oh shit, I thought it was the other way. Like, 80 was closer to 70. Oops.
    But yeah, I remembered your thread on that. It'll be on the way soon.
  5. Apr 12, 2022 at 6:23 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    Got the extended links installed today
    Voss, 5N0W808, Beefnbread and 6 others like this.
  6. Apr 12, 2022 at 6:24 PM
    805Tundra
    Ben
    Central Coast
    I replaced my radiator in my Tacoma with a Denso from rock auto. No issues. Definitely the way to go to save some money
  7. Apr 12, 2022 at 7:09 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    The radiator for dads q45 was a tyc from rock auto. No problems, and the box showed up pristine. Not even a scuff.
    the pool noodle seal came from walmart and has lasted all winter. I wonder if it’ll last all summer?
  8. Apr 12, 2022 at 7:41 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Suddenly diff breather relocate to gas cap or tail light doesn't seem high enough.
  9. Apr 12, 2022 at 9:16 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I've seen this on a 08 GM vehicle. Was the purge canister flow valve if I remember right. It was stuck open so it would allow fuel vapors to enter the engine while you were filling up causing it to be too rich. Would crank for a really long time then would run fine once it started. No idea if there's anything like that on these trucks.
    0h6SR5[QUOTED] likes this.
  10. Apr 12, 2022 at 9:19 PM
    daveeasa
    David
    My only failed start was in mammoth at least 17 years ago. Drove up, tank was closer to empty than I should have left it, from sea level and warm to cold and snowy. The next morning, truck would not start. Turned over but didn't start. So we took the skis down the road and found our way to the slopes, had a good day, I forget how we got back. Truck started fine in the afternoon, filled it up with gas, worked perfectly since then. I assume some condensation in the fuel from going hot to cold? Dunno though, it was unusual/unexpected.
    oscardog86 likes this.
  11. Apr 12, 2022 at 11:16 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I would crank down on that top nut a bit. Looks like the washers are barely contacting the rubber bushings. Don't crank down so much as to crush the bushings but make them nice and toight.
  12. Apr 12, 2022 at 11:43 PM
    viducce
    viducce New Member
  13. Apr 12, 2022 at 11:45 PM
    artsr2002
    'Yonder
    Looks good. I like.
  14. Apr 13, 2022 at 1:42 AM
    805Tundra
    Ben
    Central Coast
    I was thinking the same thing the more I look at it.
  15. Apr 13, 2022 at 1:54 AM
    artsr2002
    'Yonder
    Generally crank down on until the rubber bushing begins to compress a tiny bit. Keeps the bar in constant contact and not loosey goosey. Some folks crank down too much and deform the hell out of the bushings and they get destroyed quickly that way. Nice n toight.
    NUDRAT, alb1k and oscardog86 like this.
  16. Apr 13, 2022 at 6:43 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Who’s got links to their favorite AC stereo threads?
    found out my rear speakers are inop. I’ll pull the door panels when i get home, see if they’re unplugged, but thinking i might get some good 6x9’s and boxes, and run em off a 2 channel amp through 20ft of wire so i can set em on the tailgate if i need to.
    i put sony xplodes in my comanche back in highschool, but im not really fluent in audiophile lingo. What say ye, all knowing board?
    bandaid the system ive got, or get a decent HU and start from scratch?
    Ive got the 6-disc, and it doesnt say jbl anywhere, and the cd and casette player work. Im not a fan of touchscreens, i like knobs and buttons. But if its going to be an uphill battle, im not opposed to changing it.
    5N0W808 likes this.
  17. Apr 13, 2022 at 6:44 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I think @robabeatle has a pretty sweet setup.
    robabeatle likes this.
  18. Apr 13, 2022 at 6:49 AM
    6x9’s in boxes on a 2 channel amp, your dating us, er I mean yourself now @Sirfive . I say update the head unit as it will make adding an amp easier. As far as the 6x9 boxes being used, and being mobile to put in the bed, they make really nice Bluetooth speakers for that now.
    SharkDog, 5N0W808, NUDRAT and 3 others like this.
  19. Apr 13, 2022 at 6:56 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I can barely keep my phone charged. But you’re right. Those tallboy sized jl audio miniture boom tubes are pretty decent.
    5N0W808, NUDRAT, artsr2002 and 4 others like this.
  20. Apr 13, 2022 at 8:04 AM
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    Sir please don't post anymore pics of a 1st gen that clean. My wife will divorce me if I go buy fender flares and repaint my whole truck and that's exactly what that pic makes me want to do. Seriously though that is beautiful! :thumbsup:
    KK6PD, abcinv, artsr2002 and 4 others like this.
  21. Apr 13, 2022 at 8:49 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Yeah give it 3-4 more threads I think
    artsr2002 and 805Tundra[QUOTED] like this.
  22. Apr 13, 2022 at 8:59 AM
    805Tundra
    Ben
    Central Coast
    Any tips? its kind of awkward and having a difficult time getting it tighter. I Can install UCA and Coilovers but can't get this link tightened enough lol
  23. Apr 13, 2022 at 9:02 AM
    alb1k
    Left Coast
    It's good
    If I recall, getting on the bolt from the bottom with a wrench is a tough fit. I feel like a used a big flathead screwdriver down there and jammed it between the LCA and the bolt head.
    805Tundra and oscardog86 like this.
  24. Apr 13, 2022 at 9:05 AM
    805Tundra
    Ben
    Central Coast
    ya that is where im having trouble as well, i will give the screwdrive method a try. thanks!
  25. Apr 13, 2022 at 9:11 AM
    oscardog86
    Southern California
    I used the recommendation from someone on here and had a "thin" wrench that fit in that small space to get it tight. But I agree that something like a screwdriver jammed in there should work.
    alb1k and 805Tundra[QUOTED] like this.
  26. Apr 13, 2022 at 9:21 AM
    Casper421
    In the woods
    06 DC
    Have a pair of alligator(long nose) vice grips for the bottom bolt?
  27. Apr 13, 2022 at 9:41 AM
    805Tundra
    Ben
    Central Coast
    unfortunately i do not have those, just the beefy vice grips but maybe i can the the tip of them locked on to the bottom bolt
  28. Apr 13, 2022 at 9:49 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    viducce, KK6PD, FirstGenVol and 2 others like this.
  29. Apr 13, 2022 at 10:11 AM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    This is in the Ozarks. My account is Lake Powell Droner. Used to live at Powell hence the name haha
  30. Apr 13, 2022 at 10:13 AM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    I’ll have to double check but local is showing $137 and free pickup so I don’t have to deal with damages from shipping as they’re very prone to.
