  1. Apr 5, 2022 at 3:46 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    What a game changer, very very nice sir. I need to look mine over after seeing this.
  2. Apr 5, 2022 at 4:06 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Are these the right lines for a 4wd AC? The description is kinda vague.
    5N0W808 likes this.
  3. Apr 5, 2022 at 4:25 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It looks like they list the Toyota part number there at the bottom. Can you cross reference those on Toyota website?
  4. Apr 5, 2022 at 7:36 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I'd think it's a little bit easier to tell when they go bad if you have a double cab. My rear driver door would stay open on slight inclines while my front driver door wouldn't. After replacing the front door check, they both stay open in the same circumstances.
    alb1k likes this.
  5. Apr 5, 2022 at 7:38 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Any way to protect the door check from wearing out prematurely?
  6. Apr 5, 2022 at 7:42 AM
    des2mtn
    SW
    Tonto cover
    I reread your message and saw you were questioning more how they go bad. I would think a killer for them would be opening the door and letting it swing open and bounce off them, like when the front of the truck is on a decline.
    My driver's one is the only one that has worn out, probably since it gets the most use. Same thing on the Tacoma. I keep a small 2x4 to prop my door if I need it open a longer time, like when camping.
  7. Apr 5, 2022 at 8:05 AM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    If it's actually the pressure hose that you messed up, I would suggestion taking it to a shop and having them rebuild it. Will probably cost 20 bucks and be same day turnaround. Will also be better than that new one imo
    bmf4069[QUOTED] and FrenchToasty like this.
  8. Apr 5, 2022 at 8:06 AM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Lube with graphite or phene or whatever
  9. Apr 5, 2022 at 11:55 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Too late, but that's a good idea. Not sure if we have a place like that here though.
    txagg[QUOTED], Darkness and chrisb like this.
  10. Apr 5, 2022 at 11:57 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Tractor dealerships often can make hydraulic hose. (I just found this out and was furious I didn't know before.)
  11. Apr 5, 2022 at 12:08 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    I just realized that I put the bottom bolt in backwards :frusty:, do you all think i should be fine? it looks like there is enough clearance from the CV axle.
  12. Apr 5, 2022 at 12:09 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    The bottom shock bolt? A lot of people end up doing that, because if not, you have to unbolt your lower ball joint to get the bolt to clear the Cv when trying to remove that bolt to get coil overs out
    oscardog86 and Darkness like this.
  13. Apr 5, 2022 at 12:13 PM
    805Tundra
    Ben
    Central Coast
    ya the bottom shock bolt, thats how it was when i removed the old shock which is why i didn't have to remove the lower ball joint lol
  14. Apr 5, 2022 at 12:13 PM
    FrenchToasty
    Mo
    Bone stock
    You should be fine
    RUSTYNUTS and 805Tundra[QUOTED] like this.
  15. Apr 5, 2022 at 12:14 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    A said above by @FrenchToasty Mine is in backwards too. No issues to speak of. Although, now that I think about it I think my gas mileage has gotten worse.
    Either the bolt or the lift and big tires. Hmmm
  16. Apr 5, 2022 at 12:14 PM
    805Tundra
    Ben
    Central Coast
    i thought so, thanks for confirming :)
  17. Apr 5, 2022 at 12:15 PM
    805Tundra
    Ben
    Central Coast
    lol. awesome looking forward to saving at the pump
    RUSTYNUTS and FrenchToasty like this.
  18. Apr 5, 2022 at 12:16 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I got it backwards. Backwards bolt, new coilovers, tires, and wheels made my mileage worse.
    805Tundra[QUOTED] likes this.
  19. Apr 5, 2022 at 12:18 PM
    805Tundra
    Ben
    Central Coast
    I figured...didn't buy this thing for the gas mileage lol
    Kimosabe likes this.
  20. Apr 5, 2022 at 12:20 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Yup. I've never heard a girl say, "oh, cool Prius."
  21. Apr 5, 2022 at 12:38 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Hit or miss but a lot of the Napa's here make them too as well as a bunch of industrial supply houses.
  22. Apr 5, 2022 at 12:40 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Prius doesn't have a hand brake, so women think they are useless.
    RUSTYNUTS and Kimosabe[QUOTED] like this.
  23. Apr 5, 2022 at 1:22 PM
    Hummer
    Hummer New Member
    2023 Tundra CrewMax Limited 10K miles
    Studs Baby, Studs!
    When changing out the winter snow tires I noticed a broken sway bar link. First time to break one in 234K miles. The truck seemed to have swayed excessively when taking corners a few days earlier. The parts arrived yesterday and I replaced both sides today. I had to use an angle grinder to cut the lower link nuts off. Not fun but it came off and all bolted up easily.
    Changed air filter and engine oil/filter, too. Should be good to go for a while.
    RUSTYNUTS, NUDRAT, KK6PD and 2 others like this.
  24. Apr 5, 2022 at 1:47 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    I did the same thing and luckily noticed before I got it all buttoned up. It seemed like it would interfere, so I fixed it. Not too hard to do actually
    RUSTYNUTS and bmf4069 like this.
  25. Apr 5, 2022 at 1:54 PM
    Jack McCarthy
    Bill
    North of Boston
    I have, but it's usually under a tone of sarcasm and contempt.
  26. Apr 5, 2022 at 2:08 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Bottom bolt backwards club reporting in:
    5N0W808, tacoguybill, alb1k and 5 others like this.
  27. Apr 5, 2022 at 2:19 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
  28. Apr 5, 2022 at 2:21 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I think my lower bolts are backwards as well an I don't even have 4wd
  29. Apr 5, 2022 at 2:23 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    @txagg Nice!
    I've really been thinking about getting one of the Toyota "Hybrid" emblems and sticking it on my truck. To make it acceptable in case I drive out to California in the next couple weeks.
    Like this
    chrisb, CodyP, Darkness and 1 other person like this.
  30. Apr 5, 2022 at 2:28 PM
    Durbin7
    Durbin7 New Member
    Ohio
    Filled up the tank all the way to full, 1st time in a long time, lol. I bought some Lucas fuel treatment, never used it before, but thought I would see if there is any difference with mpg's. I think I average 15 mpg, which for a couple truck, I suppose I should not complain.
    Darkness likes this.
