  1. Mar 28, 2022 at 9:15 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Basically any rub? That’s all I’m worried about. I don’t like using my frame as a steering stop. It just leads to rust lol
    NUDRAT, 5N0W808 and alb1k[QUOTED] like this.
  2. Mar 28, 2022 at 9:55 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I didn't notice any rub. I wasn't looking for it but I think I would have noticed. I'll lock it up tomorrow and see how she looks.
    empty_lord[QUOTED] likes this.
  3. Mar 28, 2022 at 9:58 PM
    empty_lord
    05 rollover special
    Sweet. Solo should pay you a commission when I inevitably buy these lol
  4. Mar 29, 2022 at 7:22 AM
    @txagg the Dewill stud remover here looks like it'd handle your issue with valve cover bolts...
    txagg likes this.
  5. Mar 29, 2022 at 11:31 AM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    Haha! After welding a nut didn't work, I went full mangle and drilled her out. Will post pics soon. Oven cleaner, and then washing with dawn and hot water after did the trick and they cleaned up like new.
  6. Mar 29, 2022 at 12:17 PM
    Yeah, I really wish I'd have had the xtra time to hit mine with oven cleaner. The only thing that sucks about not having enough extra vehicles.
    txagg[QUOTED] likes this.
  7. Mar 29, 2022 at 12:24 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I guess I missed the oven cleaner trick/tip explanation
    Darkness likes this.
  8. Mar 29, 2022 at 4:11 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Heres a picture of them after they were cleaned up
    What little bit of discoloration you see is from flash rusting. I cleaned it up with some vinegar after I took this. You can see my mangle work on the tabs, pretty shameful. I started to give the tops of the covers a good cleaning, but decided that would make the rest of the motor look bad. Trying to be more inclusive
  9. Mar 29, 2022 at 6:23 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Those tabs are the dumbest engineering in the world
    txagg, bmf4069, shifty` and 1 other person like this.
  10. Mar 29, 2022 at 6:42 PM
    I honestly don't understand the purpose. You hafta hammer them in to get them to stay, and the spark plug tubes would keep them in place.
    txagg likes this.
  11. Mar 29, 2022 at 7:37 PM
    empty_lord
    05 rollover special
    SUPER rare. But I’ve had the seals come loose and want to fall out.
    shifty`[QUOTED] likes this.
  12. Mar 30, 2022 at 9:33 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Couple months back while on a trip to SC to see family, in particular my 7 yr grn son birthday, I had an intermittent P0420, catalytic converter is not functioning efficiently. Wasn't too concerned given I really did not suspect CAT's given it was coming and going. I had also ran close to empty, filling up at a questionable cheap gas place son pulled into. Truck ran great during trip and heading home(approx. 500miles)
    Since trip I have off and on researched, viewed videos, tested etc....temp differences front to back of Bank 1 Cat checked good, no noticeable leaks and simply suspected weak rear O2s even tho I changed them 2 yrs ago. I have not checked with NAPA where I bought initially about the Denso's they sold me but I can not find thru searches what the below O2s are for(help me out @Shifty). In any case, after monitoring Innova before change extensibly and after changing them all to OEM from Toyota Cool Springs, the rear is now straight lining like it should and not looking weak and erratic like the previous installed.
    Voss, txagg, bmf4069 and 6 others like this.
  13. Mar 30, 2022 at 9:39 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @BubbaW thats a great result. I've had weird luck with cats that most people wouldn't agree with on the 420 code. On my GTI I had previously changed the downstream sensor, then got the 420 a year later. I decided to try the upstream, figuring what the heck, spend a little on the sensor because if I have to buy a new cat I may as well use new sensors on it. The code cleared. I assume the upstream may have been getting bad readings and throwing off the results.
    Same happened with my wifes Element. I thought the upstream is just for air/fuel ratio and the downstream is for the cat. Seems like the downstream depends on the upstream for its baseline to measure from.
    oscardog86 and BubbaW like this.
  14. Mar 30, 2022 at 9:55 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    I'm done with the rabbit hole of AF/O2 sensors so don't come along wanting me redo my thinking :eek2: ;)
    Seriously, all the reading and Utoobs I watched, tells me simply that our rears are making sure that our CATs are not seeing too much pollutants so them folks on the left coast are happy campers :) and that the ECM does not use them to adj/alter fuel trim. Rears are simply dumb assholes causing me to be approx $200 poor.
    Of the many videos watched, the 2 below were very enlightening, especially the Toyota Master Tech....
  15. Mar 30, 2022 at 10:27 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    True, but I'd rather spend $200 on sensors than have to replace cats.
    Cats, the hardest thing to give away free
    And the hardest thing to prevent from theft
  16. Mar 30, 2022 at 10:31 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    no chit….my tirement check is ok but need that $2k plus for Smoky Mnt trips :facepalm:
  17. Mar 30, 2022 at 3:18 PM
    Dannydirtyfingers
    Dannydirtyfingers New Member
    Texas RR
    2004 Tundra AC SR5 2wd
    5100 Bilsteins 4th notch, JBA uppers
    Installed suspension Maxx endlinks and tire rotation. Leaf springs and timing kit still need to be done. Woohoo.
  18. Mar 30, 2022 at 5:10 PM
    I cannot find proof of either of these O2 sensors existing. And I tried all of the following iterations:
    4214012C05
    42140-12C05
    12C0542140
    12C05-42140
    4213008C14
    42130-08C14
    08C1442130
    08C14-42130
    And then flipflopped the two for another 8 combinations. Literally comes back to nothing. I couldn't even find a supersession anywhere.
    BubbaW[QUOTED] likes this.
  19. Mar 30, 2022 at 5:21 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Same….going to town fri and while there, see if Napa folks wanta offer where they got them.
  20. Mar 30, 2022 at 5:34 PM
    Dannydirtyfingers
    Texas RR
    round rock/austin
    5N0W808 likes this.
  21. Mar 30, 2022 at 5:50 PM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    No one gives a fuck, but I mighta been banned for a bit, I mighta worked on the truck a bit. It might be old a bit. I might work on bits a bit. I might never be able to afford every bit I should do. But, I keep on fixin what I can. Cheers.
    NUDRAT, 5N0W808, tacoguybill and 4 others like this.
  22. Mar 30, 2022 at 6:10 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Got the rest of the truck put back together from the valve cover job. She fired right up, was smoking a little and smelled like oil burning. Guess it will be a couple of days before I know the verdict. Noticed a lot of the emission hoses are split on the ends, so that's probably my next job. Added a spoon of downy fabric softener to the PS reservoir, should fix the faint whine.
    5N0W808, bmf4069 and FrenchToasty like this.
  23. Mar 30, 2022 at 6:51 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    What's this now? Fabric softener?
    Jack McCarthy and RUSTYNUTS like this.
  24. Mar 30, 2022 at 6:54 PM
    Dannydirtyfingers
    Texas RR
    i would like to know as well!
  25. Mar 30, 2022 at 7:19 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I installed a new dash cam today. My old cheap one started acting up. I went with the same one we have in the RAV4.
    VIOFO A119 V3 Dash Cam Front, Dashcam GPS, True HDR, 2880x2160P Quad HD+ Dash Camera for Car, Super Night Vision, 140° Wide Angle, Motion Detection, G-Sensor, Time Lapse, Loop Record, Parking Mode 24h https://www.amazon.com/dp/B07SRQH4R7?_encoding=UTF8
  26. Mar 30, 2022 at 7:23 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    silicone based? Anti foaming?
  27. Mar 30, 2022 at 7:40 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    I have spent the last few minutes searching why would add anyone add fabric softener to the brake system, NADA....WTF..
    I'll bite, WHY??? Maybe the added viscosity helps dampen a failing part?
    ALL my rides have a DashCam! I wouldn't go anywhere without one. So far they have saved my ass three times. I use a BlackVue DR590X-2CH in the Kia, and a Garmin in the truck. Simply a GREAT INVESTMENT!
    https://www.amazon.com/gp/product/B08DKMDXYF?ie=UTF8
    Here's a clip of what happened to me a few days ago. I posted it on "Dashcam Lessons" on YouTube!
    I'm getting into the Left Turn Lane, when this Weasel pops out in front of me thru 2 lanes of stopped traffic...
    FirstGenVol[QUOTED] likes this.
  28. Mar 30, 2022 at 7:41 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Power steering whine.
  29. Mar 30, 2022 at 7:51 PM
    KK6PD
    ROAD
    OK, so poorly designed pump, or one that's failing?
  30. Mar 30, 2022 at 8:06 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    It's to add smell to it so you know what's leaking.
    shifty`, 5N0W808, oscardog86 and 3 others like this.
