  1. Mar 28, 2022 at 5:47 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    No one wants to be defeated.
  2. Mar 28, 2022 at 5:51 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    ...Showin' how funky and strong is your fight
    Darkness and Sirfive like this.
  3. Mar 28, 2022 at 5:52 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    You beat me to it. Haha
    Darkness and artsr2002[QUOTED] like this.
  4. Mar 28, 2022 at 5:55 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    The first stuck bolt we find on ironman:
  5. Mar 28, 2022 at 5:58 PM
    Or, just leave the drain plug on and drop a hose down in there to pump the fluid out through the fill hole.
    oscardog86 and Darkness like this.
  6. Mar 28, 2022 at 6:01 PM
    artsr2002
    'Yonder
  7. Mar 28, 2022 at 6:01 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    sure that would work well enough but I don't think my OCD would go for that. Haha
    oscardog86 and NUDRAT like this.
  8. Mar 28, 2022 at 6:02 PM
    wack that drain plug a few more hours and get back to me.
  9. Mar 28, 2022 at 6:21 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    I switched to working on my bicycle tonight. Its getting more miles lately anyways.
    I'll keep hitting it with PB blaster along with occasional hammer wacks. Sleep on it and try again in a day or two.
  10. Mar 28, 2022 at 6:24 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I got 4.5 deg
    FrenchToasty likes this.
  11. Mar 28, 2022 at 7:18 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Speaking of, anyone got a good set of EZ-outs? @5N0W808 @bmf4069
    bmf4069 likes this.
  12. Mar 28, 2022 at 7:19 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Ive got a couple, but not a whole set. Good call.
    unfortunately, i dont have a red leather jacket.
    Darkness and bmf4069 like this.
  13. Mar 28, 2022 at 7:22 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Damn, that’s a lot of caster!
    Darkness likes this.
  14. Mar 28, 2022 at 7:31 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I need to watch some project farm again to find the best set.
  15. Mar 28, 2022 at 7:45 PM
    alb1k
    Left Coast
    It's good
    I was running 3 before the arms. Less and it felt squirrelly. @assassin10000 gave me the specs for the shop and called it. Said caster would be 4-6. It feels good. I haven’t got it up to speed yet though.
  16. Mar 28, 2022 at 7:51 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    What did camber end up at?
  17. Mar 28, 2022 at 7:54 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    if i can get 3.5 and zero camber i'd be in heaven. at 3 degrees ive got .7 degrees of camber. i cant adjust it out. i believe this is the limit of the access/reg cab lift height
    oscardog86 likes this.
  18. Mar 28, 2022 at 8:10 PM
    alb1k
    Left Coast
    It's good
    I’ll have to go get the sheet since these numbers mean more to some of you guys. :)
  19. Mar 28, 2022 at 8:16 PM
    empty_lord
    05 rollover special
    how steering lock to lock? thats my only thing holding me back. but i think i have a fix for that already.
  20. Mar 28, 2022 at 8:16 PM
    alb1k
    Left Coast
    It's good
    Here is where it is today.
    Sirfive likes this.
  21. Mar 28, 2022 at 8:17 PM
    empty_lord
    05 rollover special
    oof. thats alot of caster. probably more than im after. but going off what i see i think 3.5 is easily attainable for me with the cams almost centered.
  22. Mar 28, 2022 at 8:19 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    as the test dummy, you had to have known this was coming. Im liking those lca’s more every day.
    Darkness and alb1k[QUOTED] like this.
  23. Mar 28, 2022 at 8:21 PM
    empty_lord
    05 rollover special
    @alb1k grab some photos of the alignment cams whenever you get a chance. im curious where yours are at
  24. Mar 28, 2022 at 8:21 PM
    alb1k
    Left Coast
    It's good
    What upper arms are you running? I feel like the Camburg ones build a lot in, but I may be remembering wrong.
  25. Mar 28, 2022 at 8:21 PM
    alb1k
    Left Coast
    It's good
    Will do.
  26. Mar 28, 2022 at 8:22 PM
    empty_lord
    05 rollover special
    i've got camburgs. it got me back to a reasonable caster but my camber still suffers
    alb1k[QUOTED] likes this.
  27. Mar 28, 2022 at 8:26 PM
    artsr2002
    'Yonder
  28. Mar 28, 2022 at 8:28 PM
    alb1k
    Left Coast
    It's good
    It’s funny, I had the tires practically skipping when I put the things in. But the caster before and after alignment is pretty close to the same. I guess that’s fairly built in. Last alignment and before these lowers, I forgot to tell them to get to 3 deg so they put it at 1.5-2. Super loose on the highway.
  29. Mar 28, 2022 at 8:32 PM
    empty_lord
    05 rollover special
    2.7-3 has been my sweet spot. 2.6 and bellow i rub and she gets a little loose. i think 3.5 is the best spot for me.
  30. Mar 28, 2022 at 9:11 PM
    alb1k
    Left Coast
    It's good
    I'll have to get back to you on that, not much drive time yet. Steering goes a bit tighter radius, I've never been one to hold lock, so it feels the same to me except it will go a little farther than I expect on a tight turn.
