  1. Mar 27, 2022 at 11:42 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I'll get it aligned tomorrow - that should show what is needed, if anything. :laser:
    Darkness[QUOTED] likes this.
  2. Mar 27, 2022 at 11:43 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Dash swap complete. Finally have a darker interior. Just need the final bits. Nice having a console that’s actually solidly mounted.
    Leather door panel is meh. But it looks better. It’ll be a good template to make new cards.
    [​IMG] [​IMG] [​IMG]
  3. Mar 27, 2022 at 11:45 PM
    alb1k
    Left Coast
    It's good
    Couch wrenching. 4 tire deflate / inflate.
  4. Mar 28, 2022 at 5:51 AM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    I have a hard enough time keeping one hose from getting all tangled.
  5. Mar 28, 2022 at 6:45 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Since the cam plates were removed they are also going to throw off your caster too.
  6. Mar 28, 2022 at 6:56 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm not as knowledgeable about suspension as many here. What is the appeal/benefits of the fancy lower control arms?
    oscardog86 likes this.
  7. Mar 28, 2022 at 7:03 AM
    des2mtn
    SW
    Tonto cover
    The potential benefits of these have already been covered but these are even beefier units than the OEMs. These allow more caster when running a non-adjustable UCA such as a uniball. The bushings on these might be better than OEM too.
    Covering suspension basics though - one of the main benefits of a long travel suspension (which the Solo LCA is not) is the longer lower control arms. This pushes both the wheels and the lower shock mount out further from the frame and you'll be able to run a longer shock at an angle, leading to more wheel travel.
  8. Mar 28, 2022 at 7:11 AM
    daveeasa
    David
    Oh, so the solo with an adjustable UCA has less value / effect? I didn’t realize that.
    Mine are still all boxed up. I’m waiting for Erik to get his squared.
    alb1k likes this.
  9. Mar 28, 2022 at 7:14 AM
    des2mtn
    SW
    Tonto cover
    Not necessarily. Uniball UCAs like Total Chaos will have more caster built in. You can adjust SPCs to change the caster.
    Darkness and alb1k like this.
  10. Mar 28, 2022 at 7:21 AM
    shifty` Inside his chest they found ten thousand pencils
    "Leather". :D
    But honestly your door "leather" looks better than mine.
    Darkness likes this.
  11. Mar 28, 2022 at 8:45 AM
    empty_lord
    05 rollover special
    It was done by someone. No clue who.
  12. Mar 28, 2022 at 8:51 AM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    Agreed!
    des2mtn likes this.
  13. Mar 28, 2022 at 8:52 AM
    805Tundra
    Ben
    Central Coast
    Curious how it ends up and what the solution is, hopefully an alignment and small coilover adjustment is all that is needed.
  14. Mar 28, 2022 at 9:50 AM
    empty_lord
    05 rollover special
    SUV is only sequoia and DC. The access and reg are smaller
    des2mtn[QUOTED] likes this.
  15. Mar 28, 2022 at 9:51 AM
    des2mtn
    SW
    Tonto cover
    Yeah, I figured it was a different fan shroud than the AC and RC due to size difference. It would just be interesting if the 05-06 DCs don't say SUV on them since the 04 DC has its own quirks.
  16. Mar 28, 2022 at 9:56 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    The step child…..
    5N0W808 and des2mtn[QUOTED] like this.
  17. Mar 28, 2022 at 10:40 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    The ball joint also sits farther forward to kick the tire forward and gain space for bigger tires.
    "With these LCAs we were able to set the lower ball joint forward 1″. This will allow you to fit a bigger tire and will gain 2-3 degrees of caster."
    Specs
    • Stock length
    • Lower Ball Joint pushed forward 1″
    • Recommended 33″ (35″ tire can fit, but needs modification)
    • 2-3 degrees of caster gained
    • CNC laser cut and CNC bent
    • 3/16″ cold roll steel
    • Boxed design for superior strength
    • MIG welded
    • Made in the U.S.A.
    oscardog86 and des2mtn[QUOTED] like this.
  18. Mar 28, 2022 at 11:17 AM
    empty_lord
    05 rollover special
    I’m curious what caster is achieved with uniball uppers.
  19. Mar 28, 2022 at 4:57 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    My front diff drain plug is f'd and I can't get it out. I believe this is a somewhat common problem with the female hex getting rounded off. What's my best plan of attack? Weld on a bolt head or something? Ugh
  20. Mar 28, 2022 at 5:01 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Heat cycle & penetrating oil before rounding it out. Maybe a few taps with a hammer.
    is it rounded bad? Might need to drill it for an ez out.
    oscardog86 and FrenchToasty like this.
  21. Mar 28, 2022 at 5:16 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    Yeah it was Pretty rounded off last time I changed it and I put it off until the next change. Surprisingly It didn't get any better... Haha. I should have good access to drill it for easy out. Thought I've seen on here people welding on a nut or something...
  22. Mar 28, 2022 at 5:17 PM
    FrenchToasty
    Mo
    Bone stock
    Hit it with a ball pein hammer, it will shock the threads loose and smoosh the washer creating world peas
    tacoguybill, oscardog86 and Darkness like this.
  23. Mar 28, 2022 at 5:18 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Thats usually the step after breaking the EZ out.
    FirstGenVol and FrenchToasty like this.
  24. Mar 28, 2022 at 5:23 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I agree. Shock the threads. Hehe. peas.
    FrenchToasty likes this.
  25. Mar 28, 2022 at 5:27 PM
    daveeasa
    David
    I had this problem on my '16 Tacoma. Others here are real men. I tried and failed. Ordered a special part to convert allen key to hex and felt I was losing the battle. Took it to the neighborhood mechanic and they were too scared to even try. Took it to the dealer, $200 and a sage mechanic got it done with the chisel method.
    I figure that was money I'm happy to spend. I dropped off a six pack for the guy for saving my bacon. Plenty of mods I can be successful at without destroying my truck with a one time GTFO situation.
    You can pre-purchase the correct plug with a nice clean hex on it for next time, and the appropriate crush washer. But I figure unless you really don't trust your dealer, they likely have at least one good mechanic there who can get it done.
    Darkness and bmc02[QUOTED] like this.
  26. Mar 28, 2022 at 5:29 PM
    artsr2002
    'Yonder
    By the way, you did try and remove your fill plug first correct? Always, and I do mean always, make sure you can fill it back up first before you drain it. This is the way.
  27. Mar 28, 2022 at 5:36 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    I removed my fill plug first! I made that mistake once a long time ago, never again
  28. Mar 28, 2022 at 5:42 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    The fill plug came out so easy I may have went at the drain plug a little ham fisted... That was stupid
    I have replacement plugs that I ordered a while back. Just have to get this one out first.
    I think welding on a nut would be a better first attempt then chisel method. As I could always try that next. I've never tried an easy out on something this large and that's a lot of drilling...
  29. Mar 28, 2022 at 5:43 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    I gave it several good smacks driving in the hex socket. I'll gladly beat on it some more though...
  30. Mar 28, 2022 at 5:45 PM
    FrenchToasty
    Mo
    Bone stock
    just beat it!
    Darkness and Sirfive like this.
