  1. Mar 26, 2022 at 8:54 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Negative
    des2mtn[QUOTED] likes this.
  2. Mar 26, 2022 at 8:56 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    You must have small hands and arms!
  3. Mar 26, 2022 at 8:56 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Ah, with the wheels off, does one hub spin more freely than the other? Sorry, can't tell if you've already tried, but me thinks this would help diagnose too.
  4. Mar 26, 2022 at 8:56 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Id be suspect of the brakes. But mainly because when i got my truck the brakes were dragging. Wasn’t the caliper, but the MC, because both brakes drug evenly.
    RUSTYNUTS and des2mtn like this.
  5. Mar 26, 2022 at 8:57 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I’m assuming if I did, then that would be from a sloppy bearing. That’s usually what happens when bearings go bad right? Question is; what would cause the bearing to tighten up?
    Sirfive likes this.
  6. Mar 26, 2022 at 8:58 PM
    des2mtn
    SW
    Tonto cover
    Yep, try spinning the rotors/ hub with the calipers off too and see if that makes a difference.
  7. Mar 26, 2022 at 8:59 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    if its sat for a while the grease could be dry. When you get the rotors off give the hubs a couple whacks with a hammer and see if it frees up?
  8. Mar 26, 2022 at 8:59 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    They both drag a little more than I’d expect them to but not sure in comparison.
  9. Mar 26, 2022 at 9:01 PM
    FrenchToasty
    Mo
    Bone stock
    Mine definitely don’t spin freely like a skate board wheel or anything like you’d expect really. Your pads will always have a slight drag on the rotor.
    des2mtn and RUSTYNUTS[QUOTED] like this.
  10. Mar 26, 2022 at 9:02 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Yep that’s the plan for tomorrow. Remove both fronts, pull the calipers, and see what’s what. I just really don’t like the 11-12 mpg on the freeway with current gas prices.
    des2mtn likes this.
  11. Mar 26, 2022 at 9:02 PM
    des2mtn
    SW
    Tonto cover
    The hub bearings are roller bearings I think. They can't really "tighten" up. The rollers could seize up maybe, but I think you would start hearing noise and the bearing would fail.
  12. Mar 26, 2022 at 9:03 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Drive 10 miles and feel for heat.
    RUSTYNUTS likes this.
  13. Mar 26, 2022 at 9:06 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Yeah I get that. It’s impossible to explain in text how hard I’m spinning them but to me the drag seems excessive. Once the brake are removed, it should spin like a lot right? I know it still won’t be like a skateboard wheel but… you know
  14. Mar 26, 2022 at 9:07 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    What would you rather have to replace, bearings or MC?
  15. Mar 26, 2022 at 9:08 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    35’s. Remember. I’m that guy
    5N0W808[QUOTED] likes this.
  16. Mar 26, 2022 at 9:08 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    I work from home office nowdays so put so few miles itll be a while before I fuel up (especially at these prices im still on the $3.20 stuff). When I do ill post up but I cant imagine it wont be better just based on what im feeling I e had to input on the pedal compared to what it was. But again i was at 200k miles and my plugs were not looking that great either so a major maintance if nothing else so im sure it didnt hurt the MPG
  17. Mar 26, 2022 at 9:12 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    How’d that happen? You said 33’s and I quoted you and it was 35’s in your quote. You edited as I clicked on quote.
    FrenchToasty likes this.
  18. Mar 26, 2022 at 9:15 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    whatevers broke. MC wasnt difficult, but i was lucky that i had time to diagnose it over a couple days, and didnt fire a parts cannon at it.
    RUSTYNUTS[QUOTED] and des2mtn like this.
  19. Mar 26, 2022 at 9:18 PM
    FrenchToasty
    Mo
    Bone stock
    Tricky Ricky
  20. Mar 26, 2022 at 9:23 PM
    des2mtn
    SW
    Tonto cover
    Yup, I would diagnose with the calipers off before ordering bearings etc. When doing MC work on my truck I had issues which led to the calipers sticking.
    If it's the master cylinder, changing it out isn't bad at all. Hardest part is bleeding the MC properly, then bleeding the rest of the truck. A couple hours tops.
    For the bearings, believe you'll have to take the spindles off to press them correctly, not sure if that's the case for 2WD though. Taking out the spindles is a bit more time consuming but not too bad. If you don't have a press, you can pay a machine shop press them. A little bit more involved then changing the MC but could be done in a day too.
    I want to say @Darkness has a good write up on the bearings in his build thread - his truck is 2WD.
  21. Mar 26, 2022 at 9:51 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    Steering wheel was canted to the right a few degrees when driving straight. I loosened the steering shaft pinch collar and rotated it one tooth.
    Make a witness mark on the steering rack side first. It's easier to slide the collar up towards the wheel once you remove the bolts and tap a flat blade screw driver in to spread the collar. I managed to do all the adjusting through the driver's side wheel well.
    shifty`[QUOTED] and FrenchToasty like this.
  22. Mar 26, 2022 at 9:57 PM
    Riverdale21
    OTP ATL
    Not required. I cut this stuff into 4x12" and 6x12" strips and laid it over the header tubes where I could. It's a 1/2" thick high temp fiberglass insulation with aluminum cover. Not a full 360* all around tube wrap. I will say though stainless zip ties fucking suck.
    AC PERFORMANCE Reduce Radiant Heat Heatshield Armor 1/2" Thick x 1' Wide x 3' Long Exhaust Pipe Heat Shield Silver (12.7mm Thick x 1 Foot Wide x 3 feet Length) https://www.amazon.com/dp/B0833WMG3D?_encoding=UTF8
  23. Mar 27, 2022 at 7:52 AM
    des2mtn
    SW
    Tonto cover
    @RUSTYNUTS Here you go:
    tacoguybill and Darkness[QUOTED] like this.
  24. Mar 27, 2022 at 9:33 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Let’s do this Solo thing.
    MS22, 805Tundra, 5N0W808 and 5 others like this.
  25. Mar 27, 2022 at 12:14 PM
    alb1k
    Left Coast
    It's good
    So I suck and spent an hour getting the LBJ loose. One joint. Took me that long to realize where I needed force. Here are the Moog and solo next to each other.
  26. Mar 27, 2022 at 12:17 PM
    Casper421
    In the woods
    06 DC
    BFH for the win! Or pickle fork since you’re not reusing the lbj’s.
    oscardog86 and Darkness like this.
  27. Mar 27, 2022 at 12:53 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    If I’m feeling it I may swap the dash today. Airbag cover will be here later so I’ll have to swap that when I have it.
    txagg, NUDRAT and daveeasa like this.
  28. Mar 27, 2022 at 1:06 PM
    daveeasa
    David
    Excited to see it. Remember to take before photos.
  29. Mar 27, 2022 at 1:55 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Washed and waxed Gringo today. I used Griot's Ceramic 3-in-1.
  30. Mar 27, 2022 at 2:02 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I managed to accomplish a few things this weekend. I started with playing around with vinyl wrap and attempted covering the lower chrome piece on the bumper. I was hoping it would match the gunmetal on my wheels, but not quite right. For my first attempt "wrapping", it looks okay from 10 feet away and the sun in your eyes.
    Then I went about replacing my fuel pressure regulator and damper. I thought I would replace the intake plenum gaskets and clean out the carbon buildup in the intake with some cleaner. Weird though, there was quite a bit of oil pooled up in the plenum. Is that normal? It seems really out of place. What could cause that?
    I also decided to clean out the rats nest that had accumulated in there (damn cottonwood trees) and tried to clean out some of that buildup too.
    Before:
    After:
    oscardog86, MS22, txagg and 5 others like this.
