  1. Mar 22, 2022 at 11:31 AM
    OEM filters with Mobil 1 Extended Performance Full Synthetic (5W-30).
    But it's worth noting I've only had the truck for the last 10% or so of its miles, and the Toyota dealership fully serviced when I bought it, I'm assuming with dino/non-syn. So the change to full syn happened within the last 2k-3k miles or so, and I don't believe it's possible that buildup happened within the last 3k miles.
    I won't name the specific express oil change place he used, but the PO was in Wedowee, and service records I could piece together show they were on a reasonably regular maintenance schedule, but only list the weight, not the type. Going by the service cost, I'm guessing it had to be dino.
    If you saw the size of some of the stuff that came out of the covers, it'd raise an eyebrow. I'm interested in understanding why the driver side bank is so rough, while the passenger side looks at least remotely acceptable, similar story to @txagg. Maybe the oil fill tube holds steam which cools that side faster causing the oil to season things?
    Anyway, whatever it may be, I'll be buying a couple of liters of LiquiMoly to flush, doing my next couple of changes with cheaper dino and engine flush after 800-1200 miles. I'll try to scope some pics of the head before/after to see how well it tackles the varnish. My oil pressure remains reasonable, so I don't think anything is clogged (yet).
    txagg and abcinv like this.
  2. Mar 22, 2022 at 11:39 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I was wondering if Seafoam in the oil would help..?
  3. Mar 22, 2022 at 11:50 AM
    I actually did Seafoam treatment during my 1st oil change owning the truck. But regular Seafoam is just good for general loosening of deposits, it won't de-varnish stuff. They make a special engine flush product for that, specifically.
    For something like this, you'd need a gasket-safe engine flush that will de-varnish things without destroying any internal seals and whatnot. Ze Germans have that down.
  4. Mar 22, 2022 at 12:01 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I did the Liquid Molly engine flush a few years ago. It came out blacker than anything even @Darkness has seen.
    Voss, CodyP, Tundra2 and 7 others like this.
  5. Mar 22, 2022 at 12:05 PM
    I've had LM fix a compression issue with at least one engine in the past, and mine isn't an unusual story. I use Seafoam religiously as a general cleaner between oil changes and in my yard/house small engine tanks.
    I've never used it as a de-varnisher, but I've also never seen a properly-lubed head look this bad. When I opened it up, I honestly thought fresh oil wasn't making it to the head, no other explanation. I immediately remembered what txagg posted with his driver side head, but his was about half as bad.
    I never expected to have this many oil-related quirks at purchase.
  6. Mar 22, 2022 at 2:57 PM
    Feno
    Feno New Member
    James
    Berkshires, NY
    03 AC SR5
    Finally got new skids on the old girl
    275/70/16 16 x 8 nascar D ring steelies.
    Spidertrax 1.25 spacers. Dropped rear 1 inch via shackles.
    Rub at the pinch weld but will fix that tomorrow.
    NUDRAT, Voss, Kimosabe and 9 others like this.
  7. Mar 22, 2022 at 5:16 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
  8. Mar 22, 2022 at 5:19 PM
    try www.generalleedecals.com
    5N0W808[QUOTED] likes this.
  9. Mar 22, 2022 at 5:24 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    They’re all over the place. White, flat black, or full color.
  10. Mar 22, 2022 at 6:07 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    There was a screen printing place in deer park that made stickers in any shape and size you want. They even did metallics.
    i had em make my numberplates when i was raced dirtbikes. I need em to get em to make me a big buell emblem sticker, cause the shop that does it up here said they wouldnt do logo’s.
  11. Mar 22, 2022 at 6:10 PM
    tacoguybill
    tacoguybill The Burrito Bandido
    Bill
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    Changed out my front/rear diff, transfer case oil, transmission drain and fill and finally got around to putting my temporary hood and grill on while I get the ol sunburnt one prepped for paint. Wondering if I qualify for the 2 tone Tundra thread now :D
    NUDRAT, Voss, oscardog86 and 7 others like this.
  12. Mar 22, 2022 at 6:46 PM
    Worth a shot. Color me shocked they don’t make those.
  13. Mar 22, 2022 at 7:47 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Dash, kick panels, and center console plus a broke door (but a good insert to reupholster) came today. The driver side lower dash piece is gouged a bit but totally useable. All in all for the price it’s solid stuff. He didn’t charge for the door panel. So that’s nice
    The steering column trim is scratched up on the bottom side. But that should be fine. Now all I need are to get the rest of the hood door panels and some seats. The rest painted black will match well enough for now till reg cab parts pop up
    [​IMG] [​IMG]
    NUDRAT, Voss, shifty` and 5 others like this.
  14. Mar 22, 2022 at 7:52 PM
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    You need that piece that holds the mirror heater switch and dash light dimmer?
    FrenchToasty likes this.
  15. Mar 22, 2022 at 8:21 PM
    empty_lord
    05 rollover special
    If the yard doesnt have it yea. I also have to locate the airbag cover. They’re going to get back to me tomorrow
  16. Mar 22, 2022 at 9:08 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    Whenever I see lottsa moola being shelled out, it sorta gives me an ITCH I gotta scratch.... Sooooooooo...
    The sale at the the online store just rocks... almost wish I needed more stuffs! Do wish & hope they have a sale like this next March, I'll be starting a list, checking it twice!
    I'm already working on Part Deux!
    Voss, Tundra2, oscardog86 and 4 others like this.
  17. Mar 22, 2022 at 9:34 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Stupid question: couldn’t find a catch pan or……….?
    alb1k and tacoguybill[QUOTED] like this.
  18. Mar 22, 2022 at 10:21 PM
    tacoguybill
    Bill
    Saaaan Diaaago
    Hahahaha very astute observation good sir, the hood was sitting on the side of my house for 3-4 months until I got around to it so there were little bits of dirt and clay on the edges that I couldn’t stand being in the picture. My gallon jug of water sacrificed itself for the greater good:sadviolin:
  19. Mar 23, 2022 at 5:14 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Ordered the extended travel cv axles from RA. I don't remember if anyone else has tried them yet, so if not I'll guinea pig them. The trackmotive brand only had one available, so I got the FVP ones with the same part #.
  20. Mar 23, 2022 at 5:41 AM
    Seriously, this would look so good if everything was that dark gray metallic color above the red line here. Shouldn't be too spendy to get a shop to do the work, either. Have them pin-stripe a separating line in some color they know will punctuate it without standing out. (obviously not maroon like shown here)
    Voss, RUSTYNUTS, KK6PD and 2 others like this.
  21. Mar 23, 2022 at 5:54 AM
    I found a shop here that won't do US flags. Owner a former marine of 30 years service before retiring and opening a sign store. I thought he was kidding, but quickly realized he was very serious about it.
    "US Code is pretty clear about desecration of the flag. Nobody gives a damn about that stuff anymore, it's pathetic". His words, not mine.
    Not the same situation as the 'ol criss-cross apple sauce above, more about sign printing shops than anything.
    Voss likes this.
  22. Mar 23, 2022 at 6:12 AM
    tacoguybill
    Bill
    Saaaan Diaaago
    That actually does look pretty awesome, I guess I hadn't really thought about making it any different than what it once was....I'm just keeping it simple because we're using the booth on the weekend when no one else is around for the low low price of a bottle of Jameson and materials haha
    I'll probably pull the mirrors off to remove the old plasti-dip and color match along with the oxidized fender flares when the hood is in.
    I've been in for 17 now and wouldn't think twice about it, idk some people just take that stuff(and themselves) too seriously, probably tucks his polo shirt into his khaki's and still has a raging high and tight lol
    shifty`[QUOTED] likes this.
  23. Mar 23, 2022 at 6:58 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    I don't think too tight, but they were a bit loose before. Funny thing is the other side is still on.
  24. Mar 23, 2022 at 9:28 AM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    Got my bumper back on the truck after repairs and powdercoat, alongside some new ditch lights.
    NUDRAT, Voss, Rheywood456 and 7 others like this.
  25. Mar 23, 2022 at 11:12 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Gave the plate a little love. Here’s what it currently looks like.
    NUDRAT, Kimosabe, RUSTYNUTS and 3 others like this.
  26. Mar 23, 2022 at 11:55 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    So fresh, and so clean. Jet dry really does help with water spots.
    i feel like i wash it for every tank of gas. :washing:
    the titans silver is so much easier. Just keep the wheels, tires, and innards clean and you can go months without washing the paint.
    oscardog86 likes this.
  27. Mar 23, 2022 at 12:07 PM
    MagneticPro
    MagneticPro New Member
    Alabama
    2005 SR5, 2025 Platinum
  28. Mar 23, 2022 at 12:11 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Ordered a beefy looking coil compressor. I have the updated lower coil mounts that I need to swap onto my Fox coilovers, this compressor should do the trick. In the distant future I'm going to get a nitrogen tank and start playing with the valving on my shocks so the compressor will come in handy later. I may do a little bit of a tool review here if it works out well.
    Tool was $165 which seemed good. Shipping is $37 for ground, ouchole!
    RUSTYNUTS, artsr2002, txagg and 3 others like this.
  29. Mar 23, 2022 at 12:12 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I see a First Gen
    And I want to paint it BLACK
    :rockband: :headbang:
    Voss, Trailscape, RUSTYNUTS and 5 others like this.
  30. Mar 23, 2022 at 12:15 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    You ordered that one Accutune recommends from the thread where the 2.5 gen needed help compressing their Foxes, didn't you? Thing looks nice.
    Darkness[QUOTED] and oscardog86 like this.
