  1. Feb 27, 2022 at 4:02 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Bled the brakes and added diff oil. First break in run with the 4.88 gears. 20 minutes, maybe 6-8 miles. All grandma style and for the most part under 40MPH. Gears are quiet so far. The diff housing was too hot to comfortably hold a hand on it when I parked. Take your new gear break in seriously...
    No leak.
  2. Feb 27, 2022 at 4:08 PM
    alb1k
    Left Coast
    It's good
    Just bought one, thanks, Erik. I got hosed on shipping :) Is that a rocket launcher?
    bmf4069 and Jack McCarthy like this.
  3. Feb 27, 2022 at 4:25 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    bmf4069 and alb1k[QUOTED] like this.
  4. Feb 27, 2022 at 4:34 PM
    Jack McCarthy
    Jack McCarthy I’ve got my eye on you.
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    alb1k likes this.
  5. Feb 27, 2022 at 4:38 PM
    thunder100
    thunder100 New Member
    MD
    Black 06 DC 4x4
    Finally put some real tires on. They were awesome in the snow in VT this weekend compared to my old Goodyear wranglers.
    NUDRAT, savagefen, oscardog86 and 5 others like this.
  6. Feb 27, 2022 at 4:43 PM
    MagnoliaTom
    MagnoliaTom New Member
    Tom
    Northwest Houston
    2002 Tundra SR5 Access Cab
    Changed the oil and filter as well as a new air filter. Full synthetic oil and OEM oil filter. Also cleaned the Maf sensor with some CRC spray. Gave the interior a vacuum and quick wipe down.
    txagg, NUDRAT and alb1k like this.
  7. Feb 27, 2022 at 5:11 PM
    alb1k
    Left Coast
    It's good
    I need to write down in my phone the part number for that XL oil filter that fits our trucks.
  8. Feb 27, 2022 at 5:22 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    Got the 5160s installed and took them for a little test drive. They ride incredible.
    5B93BA1C-19FE-4D9B-8FF1-2803FDCCEFEC.jpg C0731BB6-2D11-4F3D-B8E4-E889609CC7B9.jpg 3E90982E-8F54-4FB8-B66C-79A0704AABF9.jpg
    Darkness, 5N0W808, NUDRAT and 7 others like this.
  9. Feb 27, 2022 at 5:39 PM
    alb1k
    Left Coast
    It's good
    Laser guided rocket launcher, well, missile launcher. Looks like a good mod.
    chrisb, bmf4069, sn_85 and 1 other person like this.
  10. Feb 27, 2022 at 5:41 PM
    alb1k
    Left Coast
    It's good
    I knew you would like those. Now you need TC drop shackles. Do it.
    805Tundra[QUOTED] likes this.
  11. Feb 27, 2022 at 5:43 PM
    alb1k
    Left Coast
    It's good
    Or is that a flex shot? Maybe I misread the terrain.
    805Tundra likes this.
  12. Feb 27, 2022 at 5:53 PM
    805Tundra
    Ben
    Central Coast
    It’s a flex shot haha, definitely hard to tell with the lighting. Here is the other side D6F9BF62-025B-4214-9966-95A32DBE8E6E.jpgB497E531-B4F6-4560-A341-4DE16BD72D72.jpg
    NUDRAT, oscardog86, bmf4069 and 4 others like this.
  13. Feb 27, 2022 at 5:54 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    What do the drop chackles do again?
  14. Feb 27, 2022 at 5:57 PM
    805Tundra
    Ben
    Central Coast
    they lower the rear suspension
  15. Feb 27, 2022 at 5:58 PM
    FrenchToasty
    Mo
    Bone stock
    If you lifted to high? Or is it lowering it in a way I’m not thinking?
  16. Feb 27, 2022 at 6:14 PM
    805Tundra
    Ben
    Central Coast
    Ya i believe most people run them when the lift is higher than desired, you could add it to a stock truck to reduce rake and level the truck but most people will lift the front to level it out.
    alb1k and FrenchToasty[QUOTED] like this.
  17. Feb 27, 2022 at 6:33 PM
    alb1k
    Left Coast
    It's good
    They do two things. Lower leaf spring lift height, and because they are longer, smooth out 1st gen leaf springs.
  18. Feb 27, 2022 at 6:35 PM
    alb1k
    Left Coast
    It's good
    Yeah - you are good!
  19. Feb 27, 2022 at 7:07 PM
    alb1k
    Left Coast
    It's good
    You gotta send me a pin for that area. Looks like north of Morrow Bay, but I'm not sure.
    oscardog86 and 805Tundra[QUOTED] like this.
  20. Feb 27, 2022 at 8:26 PM
    805Tundra
    Ben
    Central Coast
    :thumbsup:
    alb1k[QUOTED] likes this.
  21. Feb 27, 2022 at 9:48 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    The OEM filter for the 4.7 is the 90915-yzzd3. Most parts stores dont carry the longer filter they sell the 90915-yzzd1 sized filter which I know was used on the Tacomas. That's one small reason I'll only run OEM filters on tundras because that's about the only way to get the "longer" filter. Do people run the smaller one and get by all day long though? Yeah and their stuff is probably just fine too. Just piece of mind I suppose.
  22. Feb 27, 2022 at 9:50 PM
    alb1k
    Left Coast
    It's good
    Thank you!
  23. Feb 28, 2022 at 2:34 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    txagg, NUDRAT, chrisb and 2 others like this.
  24. Feb 28, 2022 at 4:43 AM
    des2mtn
    des2mtn Barf me out, gag me with a spoon!
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I want to say that I've seen on here that there is an even larger Mobil1 filter that is compatible with our trucks which boosts the oil capacity to seven quarts.
    With that being said, I just stick with the YZZD3 filter from the dealer.
  25. Feb 28, 2022 at 5:54 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    looks great. What tires are those? Size/specs/brand.
  26. Feb 28, 2022 at 6:25 AM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    FYI, I've also seen Walmart stock Toyota OEM oil filters. Good for those hours and days when the parts dept is closed and you need to grab an oil filter.
    https://www.walmart.com/ip/Toyota-90915-YZZD3-Genuine-Oil-Filter/143155999
  27. Feb 28, 2022 at 7:24 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I filled up the truck over the weekend.
    $3.599/gal for 87 octane
    $83.xx to fill it up.
    If gas prices don't chill TF out soon, I'm going to have to look into alternate means of transport. (250/300 miles a week just to get to/from work)
    thunder100, bmf4069, NWPirate and 2 others like this.
  28. Feb 28, 2022 at 7:36 AM
    shifty` Got patience on my neck like a cold, cold knife
    Given recent conflict, and the tendency for the fossil fuel industry to stuff a cactus in our ass anytime conflict kicks off, I've seen esimates we may be as high as $5/gal in areas it's currently $3.50/gal right now. They really wanna be Putin it in our butts. Of course, gas prices will skyrocket immediately without real-world justification, then take forever to taper down.
    bmf4069, KK6PD, FirstGenVol and 3 others like this.
  29. Feb 28, 2022 at 7:50 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Yeah, my wife's Audi gets ~28mpg and she works from home. In the short term, I can drive that a few days a week to offset the 14.2mpg I've been getting with the truck lately.
    I'm hoping the 911 with its new induction and new EFI will get up into those mid-to-upper 20s. But 70s sports cars aren't known for being fuel sippers.
    May have to explore a shitty small car or a decent motorcycle for commuting.
    I made good progress on the new EFI yesterday, so I'm hoping to have it fully sorted by April. I'll know better what kind of economy I can squeeze out of it then.
    txagg, bmf4069 and shifty`[QUOTED] like this.
  30. Feb 28, 2022 at 7:51 AM
    Casper421
    In the woods
    06 DC
    I haven’t seen $3.59/gal in years! Unless I head into Reno.
