  1. Feb 11, 2022 at 8:00 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    I fount this site which does explain speaker impedance, power, and sound! It's worth a read!
    https://geoffthegreygeek.com/multiple-speakers-share-power/
  2. Feb 12, 2022 at 5:44 AM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    Finished completely rebuilding my front end yesterday. Only part that gave me trouble was the only non OEM one I used. It was recommended on here to go with Moog aftermarket links. I love that they can be greased, but the quality is subpar. Went to put the nuts on after I dropped the truck and they would not thread. Tried the nuts on the old end links and they worked. Bolt was poorly cast from the factory and would have needed to be taken off and massaged. Didn't have time for that, and don't want junk parts on my truck so pulled them and put the original ones back on. Heres the junk part: https://www.amazon.com/dp/B000V528JU?ref=ppx_yo2_dt_b_product_details
  3. Feb 12, 2022 at 6:10 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Everyone always says Moog is a good option, but I've had more shit parts from them than anyone else. I've had good luck with the AC Delco Pro line.
    txagg[QUOTED] likes this.
  4. Feb 12, 2022 at 6:12 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    My personal experience on parts-store/ OEM sway bar links is that if you do any serious off-roading is that they'll eventually snap.
    shifty` and txagg[QUOTED] like this.
  5. Feb 12, 2022 at 6:18 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Moog was the go-to company for suspension parts in the 60s. Suspect it's all Chinesium or Turknology now.
  6. Feb 12, 2022 at 7:01 AM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    I noticed some power steering pump whine after changing the rack out. It was very loud at first and has got more quiet now. It's only been driven 15 minutes or so since swap. I filled the reservoir and went lock to lock a bunch before ever starting it. Is this normal or is something jacked up?
  7. Feb 12, 2022 at 8:40 AM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Got my SkidRow Cat Guards Installed. Just another inconvenience for these thieves. If they really want them they’re gonna take them. But at least now this will slow them down.
    Still running their 10% off. Code is “1stGen10”
    SkidRow Skid Plates
    5N0W808, oscardog86, abcinv and 3 others like this.
  8. Feb 12, 2022 at 8:46 AM
    Casper421
    In the woods
    06 DC
    Nice! Question though, how easily can you bent those down out of your way? Appears pretty easy. Is it 1/8” or 3/16” thick?
  9. Feb 12, 2022 at 8:56 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I would not call it an easy bend, I've hung on mine a bit and it's possible, not easy. They could be built a little farther forward I think. I haven't tried to put a sawzall in there, maybe could cut the front pipe with some angled cuts. I have wondered if running some weld beads along the pipe would wreak enough havoc on a blade to make it tougher.
  10. Feb 12, 2022 at 8:58 AM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    I believe they are 1/8” thick. Pretty stout. Maybe the Rock could bend them. Or a 600lb gorilla. Lol
    oscardog86 likes this.
  11. Feb 12, 2022 at 9:00 AM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    I do agree they could be a bit longer to cover more area. But either way they can’t get a cat out around them without modifications to the guards / plates. Which IMO is a good deterrent because they are looking for the quick and easy low hanging fruit
  12. Feb 12, 2022 at 10:29 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    I only buy Moog Japan parts. Or OE Toyota.
    NWPirate likes this.
  13. Feb 12, 2022 at 10:42 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    2 down, 2 to go. I also ordered a battery tray from Toyota for my larger 27F. This is the first OEM part I've been disappointed with. It's flimsy as hell and showed up warped. Way overpriced too.
    Part # for O2 sensor nuts- 90179-08059
    Tundra2, oscardog86, NWPirate and 2 others like this.
  14. Feb 12, 2022 at 11:22 AM
    bfunke
    South Carolina
    Both my 2000 and my 2018 came with 27F size trays. They are just plastic but all they do is keep the acid off the metal.
  15. Feb 12, 2022 at 11:27 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Been fighting this connector a while. Do I have to remove it from the bracket in order to disconnect it?
  16. Feb 12, 2022 at 11:31 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    I believe I stuck a small flathead in there instead of trying to push the latch.
  17. Feb 12, 2022 at 12:55 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Time to reset the code and hope the engine light doesn't come back on.
    oscardog86, chrisb, dinosaur and 10 others like this.
  18. Feb 12, 2022 at 2:35 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Wired up a chase light, being on the topper, I didn’t have many options for clean wiring. The wiring snakes along the bulb seal of the back window, down the bed by the tail light, and under the bed and along the frame. Auxbeam panel makes for nice and easy connections! F2C14A9C-6294-4323-A843-6F90CBB33FEC.jpg
    oscardog86, chrisb, abcinv and 4 others like this.
  19. Feb 12, 2022 at 3:47 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    oscardog86, chrisb, Tundra2 and 7 others like this.
  20. Feb 12, 2022 at 4:03 PM
    shifty` Dead heads and frog legs. Mmm... cake mix!
    Lock-to-lock action was done with both front wheels in the air, and cap off the res?
    Not sure if that's the SOP with our Tundras but that's how I was always taught to do it.
    chrisb likes this.
  21. Feb 12, 2022 at 4:07 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    A bust perhaps? :notsure:
  22. Feb 12, 2022 at 6:08 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Yessir. having it in the air makes it easier.
  23. Feb 12, 2022 at 7:13 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    No code! Drove the truck to the local watering hole.
    oscardog86, KNABORES, txagg and 10 others like this.
  24. Feb 12, 2022 at 7:20 PM
    Casper421
    In the woods
    06 DC
    Celebrating a non mangler moment, well deserved!
  25. Feb 12, 2022 at 7:23 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'll drink to that!
    txagg, abcinv and shifty` like this.
  26. Feb 12, 2022 at 7:25 PM
    Yeah you will!
  27. Feb 12, 2022 at 7:27 PM
    alb1k
    Left Coast
    It's good
    and what video game are we playing tonight?
    bmf4069[QUOTED] likes this.
  28. Feb 12, 2022 at 7:30 PM
    Minecraft?
    bmf4069 likes this.
  29. Feb 12, 2022 at 7:32 PM
    alb1k
    Left Coast
    It's good
    I thought, but it doesn't look tooly enough on the bottom. Maybe I don't know.
  30. Feb 12, 2022 at 7:32 PM
    alb1k
    Left Coast
    It's good
