  1. Jan 28, 2022 at 3:29 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’m still curious about the VFtuner or whatever it’s called, not sure what the price tag is on an entire “setup”
    5N0W808 likes this.
  2. Jan 28, 2022 at 3:39 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Wholly shit, did you really run it all the way up to 135! Mad props yo.
    i failed at this 0-60 attempt, but a better one and gps track addict post will be here the next time i need to go anywhere.
    https://youtu.be/0ZAGTG6QLOU
  3. Jan 28, 2022 at 3:46 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Yea the dyno tech did and shit was scary! I was 2 feet in front of it. Lol
    5N0W808 and Sirfive[QUOTED] like this.
  4. Jan 28, 2022 at 3:46 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Me too. If that VF tuner would be more user friendly. I would definitely look at buying it.
    5N0W808 likes this.
  5. Jan 28, 2022 at 3:47 PM
    FrenchToasty
    Mo
    Bone stock
    So is that one of the drawback then? Unless you know tuners like the top of your hand
  6. Jan 28, 2022 at 4:04 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Yea unless you are super savvy with thier particular tuning software and access to a dyno on a daily. I rather have the remote turning DAP offers. Not sure if he offers our trucks that option though. Remote tunning style. That's really the best I think because they review the driving styles you drive on a daily.
    Sirfive and FrenchToasty[QUOTED] like this.
  7. Jan 28, 2022 at 5:36 PM
    shifty` Inside his chest they found ten thousand pencils
    I couldn't find the part at their website. But after digging around URD's site, I'm curious if anyone has done their TB adapter upgrade to throw the larger RCF throttle body on? I guess you'd probably need to change up your intake box also eh. Not sure it would just swap in.
  8. Jan 28, 2022 at 5:39 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Say what!? Haven't been on thier website in a few months. I have to check this TB adapter out. RCF TB you say? Wonder what size it is compared to ours.
  9. Jan 28, 2022 at 5:40 PM
    I was looking at mine while under the truck cleaning up from my valve cover leak and popping off the skid plate to swap alternator and serpentine out this weekend. I didn't look too hard, but I didn't see anywhere obvious to grease them. I'll just reiterate here, I'm relatively suspension/wheel/tire ignorant, electrical and engine are my general expertise.
  10. Jan 28, 2022 at 5:40 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    None of these plugs come gapped. Had to set them all myself lol.
    bmf4069 likes this.
  11. Jan 28, 2022 at 5:47 PM
    I think the stock throttle body is 76mm, and I think the Lexus RCF throttle body is 84mm?
    I dunno. Just looked like an easy way to provide more air flow inbound. Aisin's replacement TB was under $200 if I found the right part, and it looks like URD and at least one other place sell the TB adapter, under $100 too.
  12. Jan 28, 2022 at 5:47 PM
    No iridiums for you, eh? :D
  13. Jan 28, 2022 at 8:57 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I can lube my aftermarket UCAs, LCAs and tie rod ends, not so much.
  14. Jan 28, 2022 at 10:47 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    r9k is known to produce numbers. but its not the cleanest way. the VF tuner should be able to eek more power up. but it will take more effort to do so. i do see 20 hp gains being potentially doable with VF tuner.
  15. Jan 29, 2022 at 7:51 AM
    EvilMilkshake
    EvilMilkshake New Member
    05 AC Limited 4x4
    Without the accompanying upgrades, would these even do much besides lean out the rich-running 2UZ? ~$270 sounds doable to test. The $600-700 from Toyota, not so much unless you upgraded more.
  16. Jan 29, 2022 at 8:08 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Upsizing the TB won't affect fuel mixture at all.
    It has the effect of making the throttle more sensitive at lower pedal inputs (larger TB allows more air at fewer degrees open), less sensitive to input changes (30% open to 40% open is still a lot open), but allows more air at WOT. (it's just a bigger hole to suck air through)
    The metering is done by the MAF and the O2 sensors.
    It's not much of an upgrade unless you spend a lot of time at WOT.
    KingSequioa007 and shifty` like this.
  17. Jan 29, 2022 at 8:44 AM
    Sounds like fun!!! :rofl:
    KingSequioa007 likes this.
  18. Jan 29, 2022 at 9:06 AM
    Casper421
    In the woods
    06 DC
    Today marks 4 years with Big Booty Judy and I’m very happy with how she’s turned out!
    9228C0D3-2450-4215-9F15-3462B3E04C88.jpg C0B6ECC4-AA6B-4448-8F5E-B02B2A85BF1B.jpg
  19. Jan 29, 2022 at 9:06 AM
    EvilMilkshake
    05 AC Limited 4x4
    It won't even affect WOT. The TB will open larger, earlier as you stated, in which the computer will read too much air based on pedal position and balance out as soon as the TB is open. The top end won't make any difference. It may feel more pep from idle, but will produce no gains without plenty of other upgrades.
    https://youtu.be/7hPYXz-V6Xc
  20. Jan 29, 2022 at 9:20 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    It may or may not affect WOT depending on the engine and components. If the TB is the primary restriction to induction, then enlarging it will totally have an effect. If the intake manifold is the primary restriction, then you're correct and the TB will have no effect on WOT.
    I haven't studied the 2UZFE enough to know where the flow restrictions are. We all know the exhaust manifolds are an impedance to flow, but IDK that anyone has really looked at the intake side of things beyond pulling the carbon screen from the airbox and the endless debate of CAI/intake options.
    I know you know that an engine is a system and all the components have to work in concert to make power.
    Having put an oversized TB on a previous engine (after doing all the other engine mods) I can tell you that it can have a positive effect on power. Whether it will or won't on a 2UZFE, I cannot say.
  21. Jan 29, 2022 at 10:30 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    I think it can work in conjunction with the URD MAF Calibrator which evens out flow flow volume coming in. And a decent CAI.
  22. Jan 29, 2022 at 10:31 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    I would definitely enjoy a 20 HP gain.
  23. Jan 29, 2022 at 10:33 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Have Iridiums now (NGK Laser Iridiums). These are also Iridium according to PulseStar which I'm doing R&D on these free of charge.
    chrisb likes this.
  24. Jan 29, 2022 at 11:07 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Where did you find that Aisin replacement RCF TB?
  25. Jan 29, 2022 at 2:02 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    I think he was asking because iridium plugs come pre gapped. My understanding is you should not attempt to re gap an iridium plug
  26. Jan 29, 2022 at 2:22 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Yea I've heard that too and never understood why, Iridium is one of the strongest elements around. And Pulstars instructions call for adjusting gap as needed for factory specs. Even though the tech rep sent me this set saying they were gapped to 1mm.
    txagg[QUOTED] likes this.
  27. Jan 29, 2022 at 3:30 PM
    empty_lord
    05 rollover special
    They can be gapped. But never with the gapping tool you can easily find. Proper feeler gauges and a tool to bend the electrode is fine if your careful
  28. Jan 29, 2022 at 4:09 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Yea I rarely gap my plugs. I was careful in using the measuring tool when gapping them. And you're right, it's difficult finding a proper gapping tool.
  29. Jan 29, 2022 at 5:44 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    First of many boxes arrived today. $500 down, $4500 to go. I don't know if I discussed it here, but I'm taking off the 1st weekend in April to rebuild a shit ton in Ironman. Full front end rebuild, some interior shit, prop shaft, fix the rear axle/brakes, lift, all that good shit.
    oscardog86, chrisb, shifty` and 15 others like this.
  30. Jan 29, 2022 at 5:46 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Here's my list:
    oscardog86, chrisb, shifty` and 9 others like this.
