  1. Jan 8, 2022 at 5:05 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    @FirstGenVol Tell me about your sliders. Where did you get them, and do they function well as a step?
  2. Jan 8, 2022 at 5:08 PM
    shifty` Inside his chest they found ten thousand pencils
    Interesting enough, I'm not seeing it in my exploded parts for either picture.
    https://parts.toyota.com/a/Toyota_2...COWL-PANEL--WINDSHIELD-GLASS/841420-5553.html
    Maybe it's like the 3rd brake light and they don't give you a gasket unless you buy the whole cowl cover assembly? That would suck. It seems like it's a common-ish looking part, maybe possible to source 3rd party?
    However, I see the cowl push pins and their little white hat-shaped receivers are there. I'm just going to order a handful of each. Those things are bastards. I think I may just replace them all.
    Cowl push pin: 904670704522
    White receiver: 9046708184
    5N0W808, NUDRAT and Voss like this.
  3. Jan 8, 2022 at 5:32 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    They were made by White Knuckle Offroad. Pricey, but there aren't a ton of options for our trucks. And yes, they work great as a step which is part of the reason why I picked these. Some people prefer sliders that hug the body but I wanted this style.
    oscardog86, Darkness, chrisb and 6 others like this.
  4. Jan 8, 2022 at 5:40 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Today I successfully created more work for myself installing a Ram Mount. Ram Mount is in but cab lights don’t turn on when I open the driver side door. Driver side back door and both passenger side doors will turn cab lights on when opened. And for some reason my headlights don’t turn off on their own when I turn off the engine now.
    Darkness likes this.
  5. Jan 8, 2022 at 5:42 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    The head lights shut off when you open the drivers door so it's the same problem.
    Chances are the switch is just crapped up.
    chrisb, NUDRAT and Voss[QUOTED] like this.
  6. Jan 8, 2022 at 5:43 PM
    Voss
    2003 AC TRD 4x4
    Oh good, just 1 thing I need to fix. Nice
  7. Jan 8, 2022 at 6:10 PM
    I went and looked at mine, they may've changed the function in later models. My plunger is about halfway up the rear suicide door, and it doesn't seem like there's a plunger for the rear suicide door. So weird.
    Voss[QUOTED] likes this.
  8. Jan 8, 2022 at 6:17 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Honest question - why would one need a ground plunger on a suicide door when the main door has to be open for the suicide door to be open?
  9. Jan 8, 2022 at 6:17 PM
    Voss
    2003 AC TRD 4x4
    It’s the plunger on the rear door. After taking all the molding off again to check if I cut any wires, I played with the plunger and the cab lights flickered on and off. Seems I need a new one.
    Thanks!
    alb1k and shifty`[QUOTED] like this.
  10. Jan 8, 2022 at 6:19 PM
    Voss
    2003 AC TRD 4x4
    Pretty weird indeed! The plunger on the rear door is for the front door. At least he one where the 2 doors meet. There’s another separate one somewhere for the back door I would think since my cab lights turn on once the back door is open.
    Darkness and alb1k[QUOTED] like this.
  11. Jan 8, 2022 at 6:29 PM
    On my '06, the front side of the rear door acts as the jamb for the driver door. All amenities for the driver door are mounted on the rear door: The loop the driver's door latches onto, the courtesy light plunger for the driver's door , and who knows what else. I couldn't find a plunger for the rear door anywhere.
    But I don't know what's on the pre-'05 models. They may be different. Or I may've missed where the rear plunger was, or maybe it's not a plunger after all? I didn't try pushing in the driver's door plunger and opening the rear door.
    Voss likes this.
  12. Jan 8, 2022 at 6:31 PM
    alb1k
    Left Coast
    It's good
    Ok, now I think I see it. Yew @shifty`
    Voss likes this.
  13. Jan 8, 2022 at 8:36 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Yeah. Looks like that’s the whole ID. BTW the truck is a 2000, I just put ‘99 cuz I have yet to find anyone with an earlier manufacture date. Mine’s 06/9934AE1F20-0391-464E-8437-B3409254D865.jpg
    Voss and daveeasa[QUOTED] like this.
  14. Jan 9, 2022 at 12:22 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    IIRC they come apart pretty easily to clean up. It's literally nothing besides a spring loaded metal disk so a long as the spring works it's just dirty.
  15. Jan 9, 2022 at 12:28 AM
    alb1k
    Left Coast
    It's good
    After a lot of looking and seeing some in person, along with testimonials, I think those are the best 1st gen option. Probably other rides as well. Of course I went a different route, lol, I'm working in left field.
    Darkness, chrisb and FrenchToasty like this.
  16. Jan 9, 2022 at 3:57 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm looking for some rear mud flaps.
  17. Jan 9, 2022 at 5:48 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    If the light comes on once the rear door is open - might be a bit of a frayed wire, or loose wire to the switch. Opening the door would flex the wire.
    But i'm with others, try cleaning/inspecting your switch. I don't think anyone opens the back door enough to fray those wires.
  18. Jan 9, 2022 at 5:54 AM
    EvilMilkshake
    EvilMilkshake New Member
    05 AC Limited 4x4
    Search the phone number and you'll find the company that made your keyless entry.
    RUSTYNUTS[QUOTED] likes this.
  19. Jan 9, 2022 at 7:09 AM
    daveeasa
    David
    My install was bumped due to rain from 12/27 to 1/18. I’ll definitely post photos once it’s done. I’m curious how I will like them. Intended primarily as a ridiculously overpriced step for my undeserving children :)
    oscardog86, chrisb, Voss and 3 others like this.
  20. Jan 9, 2022 at 8:07 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I humbly request less fuck boy dick pic style photos and more real photography styled shots.
    chrisb and daveeasa[QUOTED] like this.
  21. Jan 9, 2022 at 8:12 AM
    alb1k
    Left Coast
    It's good
    What? The camera is angled to fit the length of the sliders. Of course they could be framed more corner to corner, lol
  22. Jan 9, 2022 at 8:28 AM
    HMU! Fronts are spoken for, I'd like to move them both. Do we have the same fender flares? Link to my truck in sig if you need to compare.
    I'm getting them cleaned up and treated today. You know how I do.
    bmf4069[QUOTED], alb1k and abcinv like this.
  23. Jan 9, 2022 at 10:22 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Who’s welded something attached to their truck? Disconnect battery and extra ground to earth?
    ive always been able to remove whatever im welding and amn’t comfortable welding on an efi vehicle. Not welding ‘to’ the truck, but tacking to brackets in place.
    alb1k likes this.
  24. Jan 9, 2022 at 10:30 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’ve welded on it plenty of times without touching the battery………
    But yes just remove the negative cable on the battery
    oscardog86 and alb1k like this.
  25. Jan 9, 2022 at 10:48 AM
    daveeasa
    David
    Once I’ve seen with my eyes, you too can see. This is all I have so far. When I picked it up it was already off. He does a test fit and tack weld, then finish welds and powder coat which is all done so just waiting on final weld in.
    alb1k and FrenchToasty like this.
  26. Jan 9, 2022 at 10:57 AM
    alb1k
    Left Coast
    It's good
    Me too on accident. Scares me every time I realize it, but no problems.
  27. Jan 9, 2022 at 11:00 AM
    FrenchToasty
    Mo
    Bone stock
    Maybe @Outbound could explain better, but I’m sure if your welder wasn’t working properly or properly grounded, it might cause issues, but I haven’t fried anything…….. yet
    oscardog86, alb1k[QUOTED] and chrisb like this.
  28. Jan 9, 2022 at 11:01 AM
    lowell66dart
    lowell66dart New Member
    lowell
    South Louisiana
    2001 Tundra 4WD
    Rough Country level, RAS rear springs, Magnaflow, custom front bumper
    Ok. Looks like I have just tested positive for the beginning stages of slider fever. Can’t afford those awesome White Nucs. Quick search on Summit turned up some Trail Gear components. What I have come up with is their 58 inch slider and legs, L brackets and gussets and a $10 oversized fee for ~$350 shipped. Going all bolt on. Gotta sleep on it a few nights.
    oscardog86, alb1k, Darkness and 3 others like this.
  29. Jan 9, 2022 at 11:01 AM
    alb1k
    Left Coast
    It's good
    CBI ditch light bracket mounting today. Not bolt up on 05 DC, but I think they will be. Progression and my makes sense to me math.
    I think if I get the brackets 3/16 more forward I’m good.
    EDIT:
    Haven’t test fit yet, but I’m feeling good about my amateur mill skills.
    2nd Edit:
    I have a bit of rear hood lift. I’m going to let it wear in. Currently matches my front hood lift after I adjusted my bumps to eliminate rattle.
    shifty` and Voss like this.
  30. Jan 9, 2022 at 11:02 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
