  1. Dec 29, 2021 at 3:54 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    You don't need the whole rear end. Pull the other axle shaft and pull the clamshell out.
    TRDGen and Tundra2[QUOTED] like this.
  2. Dec 29, 2021 at 3:54 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Quality usually. The SQ (sound quality) guys like them in the car audio world. Not your typical SPL (sound pressure level) type stuff.
    -.04.is toe out. That'll make steering light and somewhat touchy at fwy speeds.
    Caster should be 2.5-3.0 degrees for better drivability.
  3. Dec 29, 2021 at 4:13 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    That’s what I thought as well.
    I’m strongly considering a trip to see the shop foreman at the local Toyota dealer to have this ho aligned. I’ll send him a text today.
    That being said, it doesn’t do anything weird on the freeway in the rain. So it’s damn close to right.
    Darkness likes this.
  4. Dec 29, 2021 at 4:59 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Is there a message in that plate number I'm missing?
  5. Dec 29, 2021 at 5:07 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Nope. Just a stupid IN truck plate.
    FrenchToasty likes this.
  6. Dec 29, 2021 at 5:50 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Hey @Tundra2, sounds like you should visit my build thread.
  7. Dec 29, 2021 at 5:50 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Well it’s cheaper, and I’d assume if it was damaged during shipping then they wouldn’t try and sell it to me.
    NUDRAT likes this.
  8. Dec 29, 2021 at 5:59 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    I ran a Autozone Denso (Taiwan made) for one year after my OE seaped some coolant out but still worked fine after 13 years. Then I upgraded to a Champion full Aluminum. Rockauto Denso should work fine too.
    jerryallday likes this.
  9. Dec 29, 2021 at 6:01 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The dealer is cheaper? You didn't mention that. If that's the case then absolutley. It's a Denso radiator either way right?
    KingSequioa007 and CodyP[QUOTED] like this.
  10. Dec 29, 2021 at 6:37 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Reading up on it now. I'm like 87% sure the 5VZ is mucho different from the 2UZ as far as electrics are concerned for 4WD. I did check flea-bay for the wiring harness, amd ECU. Found plenty of T4R, and Toy Taco ECUs for 4WD, but unsure if the fitment would be right.
    TRDGen and FrenchToasty like this.
  11. Dec 29, 2021 at 6:55 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Maybe just swap in a 2uz while you're doing the 4wd?
    Voss, bmf4069, oscardog86 and 6 others like this.
  12. Dec 29, 2021 at 7:17 AM
    Casper421
    In the woods
    06 DC
    Someone’s thinking this morning!!
    Voss and Darkness like this.
  13. Dec 29, 2021 at 7:21 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It honestly sounds easier to do that than try to make it work with the V6. :monocle:
  14. Dec 29, 2021 at 7:24 AM
    It’s a manual T case. What you need is locking front hubs and keep your current computer and harness as no electronics would be needed then? The trans may be an issue though….
    Darkness and chrisb like this.
  15. Dec 29, 2021 at 7:25 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    anything but an iron block with 2 bolt mains.
    Darkness and chrisb[QUOTED] like this.
  16. Dec 29, 2021 at 7:25 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Don't encourage me.
    I'll have Noah out in the boneyards looking for a genIII LS with 4l60 and TC (maybe an Atlas?) from a early 2000s GM product.
  17. Dec 29, 2021 at 7:27 AM
    Casper421
    In the woods
    06 DC
    @Tundra2 should be looking for some tons and sas that bitch!
    bmf4069, TRDGen, alb1k and 4 others like this.
  18. Dec 29, 2021 at 7:28 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Dual twin-traction-beams for 4 wheel steering.
    Darkness and NWPirate like this.
  19. Dec 29, 2021 at 7:28 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Finally someone sees reason.
    Darkness and Casper421[QUOTED] like this.
  20. Dec 29, 2021 at 7:31 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Fuckin christ fellers. Maybe I owrter just leave er alone
    NWPirate and daveeasa like this.
  21. Dec 29, 2021 at 7:46 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
  22. Dec 29, 2021 at 7:51 AM
    Casper421
    In the woods
    06 DC
    Voss, bmf4069, TRDGen and 7 others like this.
  23. Dec 29, 2021 at 7:58 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Its code that says "Sprewells in the bed, its going down today"
  24. Dec 29, 2021 at 8:04 AM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Trans and I think the ADD still needs to be told to lock.
  25. Dec 29, 2021 at 8:10 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Don't get me wrong. I'd love to do it, but I'm not sure when I'd for sure know I have "everything" needed. I'd like to go with @KNABORES ideas. Be awesome to have locking hubs and what not, but damn!
    I'm still gonna go back IF THEY ARE open Friday and pluck the trans, and T-case out. Not sure about storage...
    If @empty_lord agrees to help me swap everything I can deliver them to him for storage in his barn if that'd be okay with him....
  26. Dec 29, 2021 at 8:38 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Dude has 35 cars and a new project every week. He might be able to start on it by 2030. :D
    Voss, bmf4069, oscardog86 and 7 others like this.
  27. Dec 29, 2021 at 8:46 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    And much more storage space than I. Again, totally up to him
  28. Dec 29, 2021 at 9:03 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Just put it in his barn, he won't even notice. He will probably even do the project without realizing it isn't his truck. Then when you go back to retrieve it just bring some ammo for him as a trade.
  29. Dec 29, 2021 at 9:05 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I'm sure I can find an ECU and harness locally for you. Interior is hard to find, but electronics and other stuff are plentiful around here.
  30. Dec 29, 2021 at 9:26 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    yeah, like $20 cheaper since I don't have to pay shipping. Sorry, thought I said it was cheaper but I guess I didn't and I'm assuming it's a Denso as well. I guess if I'm unhappy with it I can just return it at the parts desk when I go to buy and look at it.
    Went with Gates hoses...probably will replace clamps too I think.
