  1. Dec 19, 2021 at 8:42 AM
    daveeasa
    David
    Needs to be grey.
    NUDRAT likes this.
  2. Dec 19, 2021 at 10:45 AM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    Still not 100% on where these are at. Passenger side follows the angle of the lower housing of the headlight, driver side is still rotated despite looking pretty good on the aiming front. It's pouring here so got a chance to see how the defenders LTX m/s tires do in the rain (pretty solid!) while I got the M/T tires sold this morning. The entire gasket of the shell seems like it needs to be redone because my bed is soaked. That's a job for another day. Nice to have a bit of my garage back since there are not 5x 285/70R17 M/Ts in there now.
  3. Dec 19, 2021 at 11:41 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    How they shine is important, not how they look in the bowl.
    You’d basically need to rotate the shroud, which the lenses would need to be opened to get everything straight
    artsr2002 likes this.
  4. Dec 19, 2021 at 11:47 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Err on the low side, cause i dont care if the brights are on or not. Too bright is too bright.
    People have 5-1000 after i shut my brights off.
    NUDRAT likes this.
  5. Dec 19, 2021 at 11:49 AM
    FrenchToasty
    Mo
    Bone stock
    Snacks?
    Jack McCarthy likes this.
  6. Dec 19, 2021 at 11:50 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Everlasting gobstoppers as a donation.
    i write the word ‘LIKE’ on each one.
    bmf4069 and daveeasa like this.
  7. Dec 19, 2021 at 2:46 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    Changed out the two cracked door handle bezels with these: https://www.ebay.com/itm/143256610981 . Be sure to not over tighten the screws on these, looks like the reason my old ones broke. Swapped out my reverse bulbs with these: https://www.amazon.com/gp/product/B0728DYR9H?ie=UTF8
    Added a dab of dielectric grease on each. Looks like my tail light housings have a broken bolt tab on each side, not sure if I will repair, run, or eventually replace them. Last thing I did was pull my number one plug to check the condition and brand. I was worried they might be something generic because the new coils are unmarked. Turned out to be Denso iridium plugs and they looked good!
  8. Dec 19, 2021 at 3:19 PM
    lowell66dart
    lowell66dart New Member
    lowell
    South Louisiana
    2001 Tundra 4WD
    Rough Country level, RAS rear springs, Magnaflow, custom front bumper
    I had scored a fog light switch back when I had a stock bumper with no fogs. With the new bumper I have all this empty space that needs something there. Decided I will get some 4 inch amber led fogs ( I like the look) and mount them to the frame where the original bumper bolted up. So I installed the dash switch and relay and had no power to the fog harness and when I pushed the switch on my brights would go on? LED headlight issue maybe? Did the anytime fog light mod and now have power to the switch when any light is on. Just have to decide on some lights now. Not wanting to spend over $100.
    TRDGen, chrisb, Tundra2 and 3 others like this.
  9. Dec 19, 2021 at 4:47 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    How'd you do your anytime fog mod? Pics? There are a few varieties that I've seen, and not sure what to go with... as far as your lights... there are plenty of suggestions in this thread.
    https://www.tundras.com/threads/ultimate-lightbar-pod-thread.88038/
    TRDGen likes this.
  10. Dec 19, 2021 at 4:58 PM
    Openbaffle
    This is a bit outside the $100, but would look cool, I think: https://www.diodedynamics.com/stage-series-2-sae-dot-yellow-sport-standard-led-pod-pair.html
    Darkness likes this.
  11. Dec 19, 2021 at 5:08 PM
    Openbaffle
    Yea, I think this is a leave good enough alone situation. I think this is good enough.
    Voss, RUSTYNUTS, chrisb and 6 others like this.
  12. Dec 19, 2021 at 5:10 PM
    FrenchToasty
    Mo
    Bone stock
    Bright AF!!! But it looks like your below their side mirrors, good job, they look super crisp!!
    RUSTYNUTS, chrisb and Darkness like this.
  13. Dec 19, 2021 at 5:14 PM
    lowell66dart
    lowell
    South Louisiana
    2001 Tundra 4WD
    I have a 2001 AC with LED headlight bulbs. Unplug the harness from the switch. Cut the red with yellow tracer about three inches from the plug. Tape off the harness end. Cut the green wire. Strip the ends of both cut green wires and the red cut wire and tie them together. Turn your park lights on and you should have power to the harness.
    TRDGen likes this.
  14. Dec 19, 2021 at 9:05 PM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    Here are some more photos that some other event attendees sent. I should've waited to get them and make one post but oh well ;).
    Voss, TRDGen, NUDRAT and 5 others like this.
  15. Dec 19, 2021 at 10:04 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    trying to install the katzkin heater element. The instructions suck as to where you can cut. I assume I can cut some small spots for the hog rings on the bottom pad?
  16. Dec 19, 2021 at 10:16 PM
    daveeasa
    David
    My installers cut a giant slot. Not that I'm happy about it, nor have I tested to see if they even work, but they seem to be doing a bunch of these so?
  17. Dec 19, 2021 at 10:22 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    the issue I ran into is that I need the cut close to the edge but it says you can't cut within 1 5/8" of the edge but I think I made it work. My old cloth also had a u shaped hammock piece that the metal bars slid into, the new seats have a plastic piece on the fabric so I guess I just push the hog ring through the fabric above the plastic piece where I need to and throw away the old metal bars...
  18. Dec 19, 2021 at 10:30 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Installed some lights on my roof
    Voss, dinosaur, des2mtn and 2 others like this.
  19. Dec 19, 2021 at 10:38 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Honestly, imperfection of the beam pattern is not visible on the road. On mine the driver side is slightly clocked wrong but I can only tell when parked totally flat and aiming at a wall(which is never). When I'm driving it isn't visible. Don't sweat it, you're close enough.
    Voss, dinosaur, dbittle and 2 others like this.
  20. Dec 20, 2021 at 4:58 AM
    Openbaffle
    Thanks, I think I needed to hear that. I still am undecided on the all white vs. amber setup up front. The nice thing is that I have both pairs of bulbs and its a 5 mins swap out if I change my mind. But I think I'll keep it as-is. I have to attack the waterproofing of the camper shell this week before I start building out the storage in the bed. I need to do a bit more research on the best practices here and I want to order a fresh set of clamps from snugtop so I can have 6. If anyone has recommendations or what product has worked well for them, it would be much appreciated. I plan on removing the shell, turning it upside down on my driveway with some help and applying a gasket to the underside with some RTV silicone as well. I know I also have to do the tailgate gap as well. The front of the bed is leaking a lot, but yesterday with all the rain it seemed like it was leaking from everywhere.
  21. Dec 20, 2021 at 5:01 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    En route to the new yob. Frost on ze pumpkin zis moanin
    shifty`, NickB_01TRD, bmf4069 and 5 others like this.
  22. Dec 20, 2021 at 5:07 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    txagg and des2mtn like this.
  23. Dec 20, 2021 at 5:10 AM
    Slow jammin’ Waylon. Good luck today sir!
  24. Dec 20, 2021 at 5:25 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes sir, Clyde was next in the line up! Thank you much!
  25. Dec 20, 2021 at 5:30 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Feeling like a Fleur De Lis heading due north with the waxing sun due East, and the waning moon due West.
    bmf4069, chrisb and daveeasa like this.
  26. Dec 20, 2021 at 7:51 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Had some fun getting a 67 beetle running and onto a trailer yesterday. Towed it about 5 miles to winter storage.
    B04AED9F-3DB2-4628-BC9B-25295F12D65F.jpg 8C2A7D35-20D4-43D6-B8E5-876AF53CC30B.jpg
    shifty`, bmf4069, dinosaur and 7 others like this.
  27. Dec 20, 2021 at 7:55 AM
    Tailgate graphics on point btw.
    lsaami[QUOTED] and chrisb like this.
  28. Dec 20, 2021 at 7:55 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    That's a keeper! I wish I still had them but I drew one just like that in high school. My chemistry teacher grabbed it off my desk and told me "that's very cool, but keep dreaming, you'll never own one that cool".
  29. Dec 20, 2021 at 8:01 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Thanks! My wife painted it by hand.
    yep, it’s the mother-in-law’s. Doesn’t get much use, but it was an anniversary gift from my late father in law, so it sticks around for sentimental reasons.
    My brother is a VW mechanic and I’m going to have him give it a freshen-up this spring. Needs brake work badly, and it starts like crap.
    Voss, TRDGen, Openbaffle and 9 others like this.
  30. Dec 20, 2021 at 8:20 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Brakes are cheap at least on those cars. The amazing thing about them is seeing them sit forever and with just a little bit of work they will fire up. They might not run right but they will run.
