  1. Nov 29, 2021 at 1:21 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    And be aware. These seem to line up as more of an AT/MT hybrid. They’re definitely more aggressive than your KO2s, Falken wild peaks, etc. they’re definitely a little louder than wild peaks too. Not much, but noticeable.
    dinosaur and chrisb[QUOTED] like this.
  2. Nov 29, 2021 at 1:27 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    How do you like them in winter?
    Most of the tires I've been looking at are 3peaks rated. I'll be driving whatever I get on wintry freeways and surface streets. Around here, that's basically offroad, but with some ice. (Indy roads are straight out of warzones)
  3. Nov 29, 2021 at 4:06 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    can’t say much yet. As we haven’t had any lasting snow. I drove it off road in about 4 inches once, and they did fine. No hard pack or ice yet.
    chrisb[QUOTED] likes this.
  4. Nov 29, 2021 at 6:00 PM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    Some random stuff this evening. Momentary switch replacement for the dome light of the shell. Upgraded 31mm LED for the dome light (huge difference). Cleaned up wiring for shell power (still need to wrap in loom). Got a pack of door panel clips. Fixed the broken one behind the rear seat. 24 more for the future. New gas prop struts make all the difference. I had thought those switches looked pretty deep, but they are cut-to-length.
    Kimosabe, NUDRAT, danmurphymn and 4 others like this.
  5. Nov 29, 2021 at 6:18 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    where did you source your constant 12v from? asking for a friend.
    NUDRAT, alb1k and FrenchToasty like this.
  6. Nov 29, 2021 at 6:23 PM
    Openbaffle
    Ran a wire from the battery with an inline fuse. Followed the wiring harness under the frame next to my backup camera cable. Came up through the rear driver's taillight and through the bed. Ground is behind the taillight as well. And then t-tap off the brake light. I only have a 16 ga wire right now. Will likely re-run an 8 or 10 with a fuse block back there for more options in the future.
    NUDRAT, TundraTed, dinosaur and 2 others like this.
  7. Nov 29, 2021 at 6:25 PM
    empty_lord
    05 rollover special
    ok. im planing something similar but i'll probably throw a small fuse block back there for stuff
  8. Nov 29, 2021 at 6:28 PM
    Openbaffle
    Exactly. That's what I'm going to do too. This works for now until I figure out what I am going to do for my camper build-out. Some of the battery packs are getting so reasonably priced and small, that I may just run something like this for electronics, although I'd have to figure out a way to charge it. Not sure. Haven't really gone there yet, still just clicking through my to-do list on the truck itself.
    Darkness and FrenchToasty like this.
  9. Nov 29, 2021 at 6:31 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    I have 2 10ga constant 12v running to the back. 1 for my trailer plug, and 1 for my reverse lights and bed power.
    both come straight from the battery
    alb1k and Openbaffle like this.
  10. Nov 29, 2021 at 9:23 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Ive got some ancient 18ah Duracell jump starter that has a 120v outlet, (2) 12v, a compressor and a few usbs that I keep in the camper at all times. I’ve been able to run a little usb fan for 3 nights without it dying. If I’m in between camp sites or will be on the road for a bit, I plug it in to a female cig plug in the shell that I wired to ignition at the trailer harness. That way it’s recharging during down time and if I ever accidentally leave it plugged in it won’t kill my starting battery.
    These new lithium power packs seem to have waaay more aH and are built for more charge cycles.
    I’ve thought about solar and doing a few lithium cells but it just seems like it would be one of those projects that was more fun to build than it is to use.
  11. Nov 30, 2021 at 6:31 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    I have a 100 watt solar panel on my shell charging a little lithium battery. For me its the bees knees. I can run my fridge, multiple lights I have placed all over the camper, a couple fans in the summer and charge any phones or camera batteries I need and its always there ready to go at all times. Zero worry about running down my main battery and its just so convenient. For camping, I seriously wouldnt do it any other way. Used this on my last truck for 5 years and now 3 years on my Tundra. All works perfectly still, but I did upgrade my battery to Lithium last year. They are so much smaller and lighter!
    dinosaur, KNABORES, Punk1974 and 2 others like this.
  12. Nov 30, 2021 at 11:14 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    I really like my Cooper AT3xlt. I've had em about 3 years and use em on and off road. They're quiet too
  13. Nov 30, 2021 at 2:14 PM
    Openbaffle
    That's fantastic. Do you have a picture of the setup?
    Got my alignment done today. Was able to get caster pushed forward a bit and everything looks great, I think:
    Made a quick video showing the camper shell repair work:
    There is a pair of SCS Stealth 6s available locally -- 17 x 8.5 -10s. Seriously tempted to grab them and get rid of the spacers.
    NUDRAT, bmf4069, alb1k and 5 others like this.
  14. Nov 30, 2021 at 2:45 PM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    Definitely pick those up. Those things are never in stock!!
  15. Nov 30, 2021 at 2:47 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Do it. Those are great looking wheels.
  16. Nov 30, 2021 at 3:40 PM
    Casper421
    In the woods
    06 DC
    Like others have said, do it!
  17. Nov 30, 2021 at 3:45 PM
    sn_85
    sn_85 New Member
    Boise
    What offsets are those?
  18. Nov 30, 2021 at 4:10 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I wouldn't recommend them. They're pretty bad quality, especially if they're bronze. Post a link to the add and I'll do some qc on them.
    #friendsdontletfriendsbuyjunkwheels
    chrisb, bmf4069, alb1k and 2 others like this.
  19. Nov 30, 2021 at 5:18 PM
    EvilMilkshake
    EvilMilkshake New Member
    05 AC Limited 4x4
    Yeah, any of the SCS wheels are perfect for these trucks. Also went with 17x8.5 -10s. Although I say go with the copper!
  20. Nov 30, 2021 at 6:06 PM
    Openbaffle
    Love everything about this. Tires look perfect with the 285/75R17.
    Not sure I have that much space with my current suspension setup. Love your build.
  21. Dec 1, 2021 at 6:34 AM
    oscardog86
    Southern California
    Heres a couple shots of the wiring for my battery and solar panel. I have the lights on a dimmer but can also turn the 2 side ones off individually so they dont all have to be on.
    IMG_20211130_164850361.jpg IMG_20211130_164850361.jpg IMG_20211130_164801725.jpg
  22. Dec 1, 2021 at 6:38 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    That's a nice setup!
  23. Dec 1, 2021 at 6:43 AM
    oscardog86
    Southern California
    Thanks buddy!
  24. Dec 1, 2021 at 6:56 AM
    Openbaffle
    +1. Fantastic.
    FrenchToasty and oscardog86 like this.
  25. Dec 1, 2021 at 8:35 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Very cool! I recently put together a Renogy controller for my setup and it works great. I need to figure out a good place to hard mount it though.
  26. Dec 1, 2021 at 9:52 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    FINALLY got my front windows tinted. They were just factory tint before someone broke into my truck this summer. Replacement window was a bit tinted so I had 3 different tints on the 4 windows. Got that tint removed and closely matched the rears so it’s more uniform and people can’t easily see me picking my nose in traffic haha.
    Front driver was factory tint
    Front pass was nothing
    Rears were and still are the same 30% I think?
    Fronts are now 20%.
    Befores:
    D112AC24-47B4-452E-8CC3-AF2F88ECAF14.jpg E2449A48-53D2-48C2-B16B-3B0BD1AD12B1.jpg
    Afters:
    55FE9753-F379-4889-B28F-BAF476CA4585.jpg 70B84837-F8D0-42ED-9B27-D4F61DB939F0.jpg
    Sorry there aren’t more pictures @bmf4069
  27. Dec 1, 2021 at 9:57 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Im in need of tint, but i guess it keeps my inside window track clean. I really like the metallic tint on grandma’s ‘02 rx300 (blue, not gold) so i kinda want to do that with the sides, but since this is texas, im also thinking hard about that clear ceramic windshield tint. And dark mirror on the back glass.
  28. Dec 1, 2021 at 10:14 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Has anybody had to work on the HVAC blend door? My actuator works just fine, but the door itself either doesn't fully seal. I can feel cold air coming from it when the heat is on.
    How do I remove the tubing that's in the way to access it?
  29. Dec 1, 2021 at 10:15 AM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    Still sick, so I'm tinkering with some photoshop today.
    I've ordered powder coat for my wheels that supposedly matches the Toyota 1G3 Magnetic Grey color. In the below photo, I attempted to render something of a representation of the color onto my wheels.
    Do you guys think it would be a sin to also powder coat the bumper the same color? I've never seen a white and grey combo on these trucks.
    TRDGen, jImmegart, Darkness and 4 others like this.
  30. Dec 1, 2021 at 10:21 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Do it.
