  1. Nov 28, 2021 at 12:41 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Didn’t die.
    Put the old suspension in the bed to help settle everything. Going to drive it a week or two before I get it lined up and order tires.
    Still need to install the diff drop and buy/build front sway links.
    I may yet have to swap the front struts L for R. I haven’t decided if I put those MFers in backwards or not. Need to get that ish done before alignment also.
    88B4E029-EB5E-49F1-8532-BC34224C02A1.jpg 5EBD703A-BF94-4BC0-B995-C067F70917C0.jpg
    TRDGen, oscardog86, alb1k and 11 others like this.
  2. Nov 28, 2021 at 1:18 PM
    MHulsebos
    MHulsebos New Member
    Arizona
    2000 Tundra AC 4x4
    Installed my front Durobumps with spacers today. Spaced the other factory bumpstops as well.
    Before
    After
    Both sides
    RUSTYNUTS, bmf4069, dinosaur and 2 others like this.
  3. Nov 28, 2021 at 2:51 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Pull off the oem so you get full effect of the duros
    oscardog86 and Tundra2 like this.
  4. Nov 28, 2021 at 3:08 PM
    MHulsebos
    Arizona
    2000 Tundra AC 4x4
    Hmm. I haven't really seen this done before. My understanding is that they're designed to be used with the oem's, and they're really intended to damper bumps up to the oem bumpstop point, which provides a hard stop if it makes it that far. Unfortunately, Duro doesn't really provide any info with these either, so I'm just going on info I've found scattered about elsewhere.
  5. Nov 28, 2021 at 4:27 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I'd really like to see chocks in front of your front wheels - since you are 'testing' concrete strength & all....
  6. Nov 28, 2021 at 5:11 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I did the same thing with an 8awg lead to the battery but I put this behind my driver taillight. Tucks in there super nice like and makes it easy to add anything else you’ll ever need in the shell.
    Electop 6 Way Blade Fuse Block Fuse Box Holder, 6 Circuit Car Ato/Atc Fuse Block with LED Indicator Damp-Proof Protection Cover Sticker for Automotive Car Truck Boat Marine RV Van https://www.amazon.com/dp/B07PLC53MQ?_encoding=UTF8
  7. Nov 28, 2021 at 5:15 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    If this works out, I'll do the same on crackie. Hate to use my baby as the test subject, but it needs it more than crackie does.
    @Thrussn, still no whine or hiss from your setup? Still no issues?
    NUDRAT likes this.
  8. Nov 28, 2021 at 5:54 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    Like from that leaky brake booster? The company sent me a replacement and it's been mint ever since :fingerscrossed:
  9. Nov 28, 2021 at 6:42 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Guess I missed that in the thread, or forgot about it. Will need to re-read. You contacted the company through ebette, or directly via emails?
    Thrussn[QUOTED] likes this.
  10. Nov 28, 2021 at 7:02 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I’m not sure if you’re attempting humor or succeeding at condescension.
  11. Nov 28, 2021 at 7:06 PM
    dinosaur
    dinosaur New Member
    Dave
    2004 DC Tundra 4x4
    After further testing, the antenna kind of sucks. I lose 2 stations in certain parts of town. Someone was right all along...:oops: But it looks cool.
    Darkness likes this.
  12. Nov 28, 2021 at 7:15 PM
    shifty` Goons of Hazzard
    Wait - did you use the 'Original 6-3/4" antenna', or another version? Just curious. One of the decks I need to park in for work 2x-3x per week, I smack my factory antenna everytime I cross between atriums of the deck (2x per day, so 4x-6x week, going on 3 years now). I've already got a flat spot on my antenna ball.
    I'd been mulling over replacing t with a shorty, but I keep hearing your experience over and over again: Shitty reception, loss of key fob range.
  13. Nov 28, 2021 at 7:18 PM
    dinosaur
    dinosaur New Member
    Dave
    2004 DC Tundra 4x4
    Key Fob?!?! Oh great. Yes, I used the "Original". Since my lift, my antenna would slap my raised garage door on the way in and out. I was also looking at a Rydonair. Hopefully the algorithm will put it below for us.
    Punk1974 and Hi06silver like this.
  14. Nov 28, 2021 at 8:16 PM
    daveeasa
    David
    The one reason I'd consider a switch is the car wash requires removal. But I think I can just stash the correct box wrench in the glove box and be ok on that.
  15. Nov 28, 2021 at 8:47 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I think there are 15, 16 or 18" antennas that will bring it down just below the roof line. That won't sacrifice much reception.
    dinosaur likes this.
  16. Nov 28, 2021 at 9:22 PM
    Thrussn
    Gabe
    NM
    Yeah. They sent a new one and gave me a return label for the old one. Took me about 15 mins to swap out and I haven't thought about it since lol
  17. Nov 29, 2021 at 2:54 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    After looking at this the last few days, I kind of miss the OEM green, but then I don't when I'm in thr V6.
    V6
    bmf4069 and Openbaffle like this.
  18. Nov 29, 2021 at 3:22 AM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    Headlights installed. Realized that the wire loom I had ordered was not split loop...so it's going back. Ordered some split loop now. Rewired the quick connect for the shell. Going to order that fuse block/fuse back and run an 8 ga line to the battery as was suggested instead of the 16 ga I have now. Installed the new gas prop struts, which work so much better. Was cold in the shell last night! Need a heater.IMG_7428.jpgIMG_7432.jpg
    NUDRAT, RUSTYNUTS, shifty` and 6 others like this.
  19. Nov 29, 2021 at 6:42 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I noticed that my reception in my truck is good in some areas but worse in other areas with my stubby.
    My GTI on the other hand, which uses a roof mount, seems unaffected by the stubby. It has good reception everywhere.
  20. Nov 29, 2021 at 7:07 AM
    06yotamike
    06yotamike New Member
    NC
    2006 Tundra DC XSP 4x4 4.7 Bluesteel Metallic
    How long have you had those yoko's? And would you still buy them. Im seriously considering them in 285/70/17
    jImmegart[QUOTED] likes this.
  21. Nov 29, 2021 at 8:36 AM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    I've had them for a year. I actually run SL rated tires, which is why I chose them originally to save weight. @Darkness has run them alot longer and runs E rated I think.
  22. Nov 29, 2021 at 9:22 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've been running roughly the same size in E rating for almost 3 years. Great tires for street in all weather (I've had them in mild snow and they did okay, rain is excellent by AT standards).
    Off road they do well if you're within limits. Sticky mud will pack fast and make traction impossible, but on dirt roads or sand they do very well.
    I had a set of the previous version for just over 70k miles, and back then I would drive off road often and abuse them. I think these newer ones are wearing about as well.
    06yotamike[QUOTED] and chrisb like this.
  23. Nov 29, 2021 at 9:23 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    We are talking about Yoko Geolandars, right?
    jImmegart likes this.
  24. Nov 29, 2021 at 9:26 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yeah the AT version. Next time I need tires I'm considering the MT version since my truck isn't daily driven anymore.
    Dirt lot to highlight the tread pattern
    TRDGen, MS22, oscardog86 and 5 others like this.
  25. Nov 29, 2021 at 9:32 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I am also in the market for tires (like next week or three) so any info I can get on good ATs is good info.
    jImmegart and shifty` like this.
  26. Nov 29, 2021 at 9:44 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    FWIW I'm very happy with my Dick Cepek Trail Country EXPs. Got em for $176/tire.
    chrisb, Darkness and Cummins3500 like this.
  27. Nov 29, 2021 at 9:50 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    i use my stubby for disappointing women and strafing antbeds. (A-10 machine gun noises when appropriate)
    Sorry ive giggled about the wording of that post a couple times. And ill show myself out.
    but today i took the truck around the neighborhood and out onto the highway. Cycled the 4wd, a/c & heater. Havent moved or started it but twice this month. I think all my electrics are sound, and that takes a big weight off my shoulders. The sequoia would drain within 5 days.
    fyi, a-10 machine gun noises are never inappropriate. Let your flak fly.
    CodyP, dinosaur, Henry1stGen and 3 others like this.
  28. Nov 29, 2021 at 10:34 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've always liked their tread patterns and heard great things about them. I can't buy them because my friends are 40 year old high school kids and the "riding on dicks" jokes would never end.
    dpast88, Cummins3500, CodyP and 6 others like this.
  29. Nov 29, 2021 at 10:35 AM
    Eh, automated car washes are the devil.
    Dang, that gas gauge like SCHWIIIIIIIING!
    Hi06silver likes this.
  30. Nov 29, 2021 at 11:22 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    How heavy are those hos? Since I'm planning on running ATs and do a lot of freeway miles, weight is a consideration. Some of these tires (not even E rated) get super heavy and I know that will be a real-life concern when panic-braking on the freeway with stock Tundra brakes.
    Edit: 57lbs ea in 285/70r17
    Not too bad.
    Not too bad at all.
    lsaami[QUOTED] likes this.
