  1. Nov 21, 2021 at 11:01 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    But did you do the soak it in a warm bucket of water and laundry detergent on the seat all day thing?
  2. Nov 21, 2021 at 11:06 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Awesome analogy. Mighta slipped thru if it weren’t for the pics of the 2nd gen dash, I mean, just paint a target on your back already bud.
    #THISIS1STGEN #BOOM
    TRDGen, CodyP[QUOTED], chrisb and 2 others like this.
  3. Nov 21, 2021 at 11:12 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Negative. I sprayed simple green, heavily and let it set for a half hour, keeping it wet, then scrub-brushed it, and pressure washed it a second time. Then let it fully dry out. When I pressure washed it, it did change the color of it, like I could see the dirty changing to clean. So I thought it was good to go. You think the laundry detergent bowl soak would do better?
  4. Nov 21, 2021 at 11:16 PM
    alb1k
    Left Coast
    It's good
    Actually, no idea. I was hoping you would just test it for me, lol. You were super thorough. I'll try it on the 4R tomorrow while I work on the Tundra.
    Darkness and RUSTYNUTS[QUOTED] like this.
  5. Nov 21, 2021 at 11:34 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    soooo. im doing it then, lol
    alb1k likes this.
  6. Nov 21, 2021 at 11:34 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Cool. So you haven’t tried anything yet? I’m kinda hoping the detergent, or silicone spray is the secret. Otherwise fukt.
  7. Nov 21, 2021 at 11:45 PM
    alb1k
    Left Coast
    It's good
    No, it's been on the list - but tomorrow is a new day.
  8. Nov 22, 2021 at 3:49 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Here you go new guy!
    https://www.tundras.com/threads/what-have-you-done-to-your-2nd-gen-tundra-today.68/page-373
    TRDGen, RUSTYNUTS, shifty` and 3 others like this.
  9. Nov 22, 2021 at 4:36 AM
    Lupe
    Lupe New Member
    Lupe
    2006 Tundra
  10. Nov 22, 2021 at 4:38 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    If I'm in the market for 4.56 gears, do I need the whole install kit or can I just buy the front and rear rings and pinions? I plan on having a professional install.
  11. Nov 22, 2021 at 4:46 AM
    Localsnap88
    Localsnap88 New Member
    NJ
    2005 SR5 Doublecab
    SPC UCAs/bushings, Bilstein 6112 Coilovers @ 1.8”, 265/75 Cooper AT3 LT on Method Grid 16x8/ 0 offset, EBC Rotors/Perf Brake Pads, Energy Poly sway bushings, Moog greasable Endlinks, Airaid Synthamax Dry filter, Magnaflow 18” SI/SO muffler , Toyota SS rolled exhaust tip, Spider black housing headlights, Phillips Racing Vision halogens, Eagle Eyes LED smoked tails, Eagle Eyes LED Third Brake, Aftermarket OEM style fogs, full interior LEDs, reverse LEDs, Tinted sides and rear, bug deflector, window visors, AMI Stub Antenna 5” Aluminum/SS/rubber steps, TPMS delete, SAIP blockoff/delete, M1 Synthetic Engine and Diff oils,
    Hey bud, This popped in my head a couple months back and I decided to confirm if there was indeed one on our trucks . (Me: 05’ Dc) indeed there was one and I removed it like you said , just in case there was slight gain to be had. Obviously no real observable gains from it , no problems either .
    empty_lord[QUOTED] likes this.
  12. Nov 22, 2021 at 4:56 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Get the kit or maybe talk to the installer, sometimes it’s easier if they buy it all. Zuk does that here, it’s a hair more expensive but way less hassle of “do I have the right shims” or “that was the wrong spacer kit”
  13. Nov 22, 2021 at 6:25 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Better to have the whole install kit to do it night. The new ring and pinion will not space out the same as the old one.
  14. Nov 22, 2021 at 8:40 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    Thanks guys.
  15. Nov 22, 2021 at 11:08 AM
    Casper421
    In the woods
    06 DC
    If you find a good deal on gears, please share with the class.
    RUSTYNUTS, alb1k, Tundra2 and 2 others like this.
  16. Nov 22, 2021 at 1:49 PM
    alb1k
    Left Coast
    It's good
    Testing now. Top photo may be an indication it’s working…
    RUSTYNUTS[QUOTED] likes this.
  17. Nov 22, 2021 at 2:01 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    So far the best deal I've found was $833 plus shipping front and rear 4.56 nitro gears complete install kit from a vendor using Google shopping last night. I don't recall the website. I was on a work computer
    oscardog86 and Punk1974 like this.
  18. Nov 22, 2021 at 2:03 PM
    lowell66dart
    lowell66dart New Member
    lowell
    South Louisiana
    2001 Tundra 4WD
    Rough Country level, RAS rear springs, Magnaflow, custom front bumper
    New Toyota lower balljoints and new NAPA cv front axle's today. Glad that's over with.
    Voss, hammeron, chrisb and 8 others like this.
  19. Nov 22, 2021 at 2:28 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Soaking worked for me when power washing did not. YMMV
  20. Nov 22, 2021 at 2:51 PM
    empty_lord
    05 rollover special
    Finally have a working 3rd brake light and have the wires for a reverse light to be added too taped up for now. Thanks to @Puppypunter t harness I’ve been putting off installing. I used a 4 pin o2 sensor plug to make it easier to remove something if the need arises too.
    Voss, RUSTYNUTS, shifty` and 6 others like this.
  21. Nov 22, 2021 at 3:20 PM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    I actually took it off yesterday and didn't notice no difference.
  22. Nov 22, 2021 at 3:20 PM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    How long do you soak it and how much of the seatbelt do you soak?
  23. Nov 22, 2021 at 3:21 PM
    empty_lord
    05 rollover special
    i yeeted mine... uh totally think this truck had no air filter at one point by mistake.. it was uh... filthy.
  24. Nov 22, 2021 at 3:23 PM
    Localsnap88
    NJ
    2005 SR5 Doublecab
    What’s your headlight plan, projector retrofit?Also, which clear corner markers you using/they holding up so far ? eBay I assume? Thanks!
  25. Nov 22, 2021 at 3:28 PM
    Localsnap88
    NJ
    2005 SR5 Doublecab
    Corners came with the headlights as a set or no? If you don’t mind pointing me to a link for them I’d appreciate it. My aftermarket Spyder headlights with black inside have started lense coating peeling badly so probably gonna splurge on a new set of OEM headlights but the corners are no longer available. Gonna have to go aftermarket amber-oem style or clear. Yours look great in this shot, thanks!
    FrenchToasty likes this.
  26. Nov 22, 2021 at 4:00 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Yes it was a set with corners and fronts. Below is the eBay link.
    i did have to buy amber bulbs for the comers because I had clear before.
    https://www.ebay.com/itm/For-2005-2...-Clear-Headlights-Signal-Corner-/124734215196
  27. Nov 22, 2021 at 4:11 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Pretty sure the silicone spray is the main thing that did it for me.
    What.The.Hell?
    ‘tis NOT the season to shy away from our way of life. GIVE EM THE MEME!!!!!!!!!!!!!!!!!
  28. Nov 22, 2021 at 4:32 PM
    FrenchToasty
    Mo
    Bone stock
    Kill em with kindness! This union better not be turning him soft!
    Also, I believe only HE has been warned about certain memes……….
    Door is wide open……
  29. Nov 22, 2021 at 4:48 PM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    Yea -- projector retrofit. Hope to have them done this week when I get some time. Clear corners were from eBay. They have been holding up pretty good, I think. I've had them for a year or so. The seller I bought them from doesn't sell them anymore, it doesn't look like.
    Finished the video of installing the Torch add a leaf and axle shim kit.
    Took some pictures in the rain. It's coming together.
  30. Nov 22, 2021 at 5:20 PM
    empty_lord
    05 rollover special
    now we just need to fill out those wheel wells!
