  1. Nov 11, 2021 at 11:00 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Just for brake, for cargo lights I installed led strips with 3m. For power it’s tapped into the hot 12v on the 7pin tow hook up. Downside is it only works with the key in. I need to wire it to the battery, just been lazy
  2. Nov 11, 2021 at 11:15 AM
    daveeasa
    David
    Cool, yeah, my shell 3rd brake has been off taillight T tap for 20 years now. I’m going to redo to integrated T harness for DIR and shell with the new taillights.
    The chmsl ground is going to loop to the shell connector so that when the shell is off I can plug a loop back to restore cab chmsl. Doesn’t serve any purpose when the shell is on
    jerryallday[QUOTED] likes this.
  3. Nov 11, 2021 at 1:46 PM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    I’ve been locked at home these past few days after having surgery to correct severe long term hemorrhoids. Been reading this entire thread which is amazing through the first thousand pages. Entertaining, as well as informative! You guys rock!
  4. Nov 11, 2021 at 3:39 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I took in some material in to have a new set of 'Drapes' sewn (yes you read that correctly) for the shell on my DC.
    The gal doing them is backed up, and it's been over 3-weeks . . . so any day now.
    I'll post pics. after I get them installed so you hounds can have a field-day heckling me ! LOL
    NUDRAT, oscardog86, RUSTYNUTS and 3 others like this.
  5. Nov 11, 2021 at 3:46 PM
    ThatYeti
    ThatYeti New Member
    2000 Tundra SR5
    These are for the HVAC controls right? Realized all three of mine are out and hoping it's just new bulbs, any chance that's the case?
  6. Nov 11, 2021 at 5:34 PM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    Pulled the fogs and got some aluminum bar stock to clamp them better. Zipped tied the wire as well and put some thread locker on the bolt. This should be good to go now.IMG_7040.jpgIMG_7041.jpg
    bmf4069, 912, Desert Dog and 2 others like this.
  7. Nov 11, 2021 at 5:48 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Got my DD lights mounted on my ditch light brackets. All wire is ran, I just need to connect the +\- and the ignition hot to the auxbeam controller and we’re good to go! 293D3971-3A4A-41AF-B649-26A905194436.jpg1FC8C586-10A8-4B66-A49B-5F9BC9AB9119.jpg
  8. Nov 11, 2021 at 7:09 PM
    Henry1stGen
    Henry1stGen New Member
    Henry
    2002 Tundra AC TRD
    Headlights, audio, interior, suspension, bed lights, and more
    Installed fog light switchbacks from deAuto LED. Lifetime warranty. Very satisfied with the quality and brightness.
    In the pictures the headlights look blue but they're more white. The yellow lights in person look like a deeper yellow. I wasn't able to get a true representation picture of the fog lights.
    For the side markers I used Amber LasFit. They are bright and never flicker or fail early. Matched it with a 8-pin flasher relay that supports LED.
    https://www.ebay.com/itm/3156-3157-...-Dodge-Ram-1500-1994-2010-Amber-/124131561381
    iJDMTOY 8-Pin LM449 81980-50030 066500-4650 Electronic LED Flasher Assy Relay Fix Compatible With Lexus Scion or Toyota LED Turn Signal Light Bulbs https://www.amazon.com/dp/B008C9YS0Y?_encoding=UTF8
    https://deautokey.com/product/dual-...anytime?mc_cid=924dade8cc&mc_eid=[ba8e6ebcb9]
  9. Nov 11, 2021 at 7:12 PM
    Openbaffle
    Those look great! Switchback fogs are a solid idea!
    RUSTYNUTS likes this.
  10. Nov 11, 2021 at 7:15 PM
    Openbaffle
    Yes -- there are 7 bulbs total.
    bmf4069 likes this.
  11. Nov 11, 2021 at 7:48 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I need to find someone who can paint the inside white plastic a chrome color. My white bulbs are off white in mine cause the whites yellowed with age and heat from the old bulbs
  12. Nov 11, 2021 at 8:14 PM
    Henry1stGen
    Henry
    2002 Tundra AC TRD
    These are the white LED bulbs with the original green balloon from the existing bulb I used for the HVAC cluster, ashtray, glove box, ignition, and cigarette lighter. The secret to remove the glove box bulb is to get a rubber tube that fits over the existing bulb tightly to remove it.
    WLJH 6Pack White Dash Lights PC74 Twist Locket Socket Wedge T5 LED Bulb 37 74 2721 3030SMD Dashboard Instrument Cluster Bulbs,Plug and Play https://www.amazon.com/dp/B0799MQ12...abc_GKVDJM8E42WZVMZS4858?_encoding=UTF8
    SYLVANIA 168 T10 W5W White LED Bulb, (Contains 2 Bulbs) (168SL.BP2) https://www.amazon.com/dp/B01BDWLZH...abc_MB4A2Q2RTBYQWHQX6Z06?_encoding=UTF8
    ThatYeti and RUSTYNUTS like this.
  13. Nov 11, 2021 at 8:30 PM
    Henry1stGen
    Henry
    2002 Tundra AC TRD
    For my 2002 Tundra SR5 AC TRD with factory JBL double DIN radio. I Installed ATOTO S8 Pro with front and reverse cameras. Bluetooth OBD2 scanner for Torque. A Kicker 10” subwoofer under driver seat. Using factory JBL amp and speakers. The DSP on this radio made these factory speakers sound high end at normal listening volume. So many options to adjust crossover, field of sound, subwoofer frequency, etc. Distortion starts when you crank it loud enough to allow others not in the vehicle to hear. I don't listen to music that loud anymore. So this is a perfect setup for me.
    Links:
    Radio: [DAH10D/QLED] ATOTO S8 Pro S8G2104PR-N Double-DIN Android Car Stereo Receiver,Dual Bluetooth w/aptX HD,USB Tethering, Split Screen Display,Android Auto & CarPlay,VSV&LRV,Built-in 4G Cellular Modem https://www.amazon.com/dp/B085C6KLFX?_encoding=UTF8
    ATOTO AC-44P2 1080P USB DVR On-Dash Camera - Sony Sensor for Image- Recording Video On Camera End - Operation & Preview from ATOTO A6/S8 Car Stereo Side https://www.amazon.com/dp/B0822KMK48?_encoding=UTF8
    Universal Car DVD GPS Player Steering Wheel Remote Control (2018) with Audio Volume/Phone Answering and Hanging Up/DVD Bluetooth Radio Switch for Car Audio Video Navigation System https://www.amazon.com/dp/B0797T7H5K?_encoding=UTF8
    KICKER 46HS10 Compact Powered 10-inch Subwoofer https://www.amazon.com/dp/B083M9HR4D?_encoding=UTF8
    HD 720P eRapta ERT02 Backup Camera Front Rear View License Plate Reverse Universal for Pickup Truck Car SUV 149° Perfect Angle Night Vision Mirror Function Waterproof https://www.amazon.com/dp/B076P8QFYD?_encoding=UTF8
    Metra 70-8113 Amplifier Integration Harness for Select 2000-2004 Toyota Vehicles https://www.amazon.com/dp/B0007WRQQ2?_encoding=UTF8
    Bafx Products - For Android Only - Wireless Bluetooth Obd2 Scanner Diagnostic Code Reader & Scan Tool - Scan, Reset & Clear Car Check Engine Light https://www.amazon.com/dp/B005NLQAHS?_encoding=UTF8
    Voss, bmf4069, Lil Steve and 5 others like this.
  14. Nov 11, 2021 at 9:56 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I got about a year out of one of these cheap flashers on my 08 Lexus before it stopped flashing and just stayed on solid. Just a heads up. The diode dynamics one has tap for lane change and that made it all worth the $50 or $60 that it costs.
  15. Nov 12, 2021 at 1:20 AM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Let's see those wheels on there.
    Darkness and Grumpy74[QUOTED] like this.
  16. Nov 12, 2021 at 2:26 AM
    Openbaffle
    I’ll second the diode dynamics tap for lane change. That’s a fantastic upgrade over the stock behavior.
    shifty` likes this.
  17. Nov 12, 2021 at 4:57 AM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    I wish there was a way to connect a obd reader to my kenwood radio. How does it connect to yours? Is it via Bluetooth or cable?
  18. Nov 12, 2021 at 5:07 AM
    Henry1stGen
    Henry
    2002 Tundra AC TRD
    Are these it? If so, that will be my next upgrade.
    Not only that it has a single tap (4 flashes) for Lane change but it has a strobe option for emergency lights. Thanks for the recommendation. :thumbsup:
    Diode Dynamics SmartTap CF18 LED Flasher Module https://www.amazon.com/dp/B085B9PLHF
  19. Nov 12, 2021 at 5:14 AM
    Henry1stGen
    Henry
    2002 Tundra AC TRD
    It connects to my HU via a second built in Bluetooth receiver. My first Bluetooth receiver is being used for my phone to answer calls.
    It is very responsive. My rpms and GPS displayed on the screen has no delay compared to the actual gauges.
  20. Nov 12, 2021 at 10:19 AM
    EvilMilkshake
    EvilMilkshake New Member
    05 AC Limited 4x4
    Nice! I also installed an ATOTO S8 and it's been great. Let me know how your OBD2 works after the first couple of weeks. Mine doesn't always turn on (ELM327 clone like yours) and it requires a disconnect/reconnect to work. The Torque app is amazing for what it can grab. May go with a Bluedriver next though, as at least that's real.
    oscardog86 likes this.
  21. Nov 12, 2021 at 1:07 PM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    Nice. If you're open to making another set I'd love to buy them!!!
    mcharfauros likes this.
  22. Nov 12, 2021 at 1:32 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Did truck stuff. Been helping my little brother with the house he just bought and stopped by a buddy's house to do leaves for him while his soccer team is competing in a first round NCAA D3 game.
    Voss, 06yotamike, bmf4069 and 7 others like this.
  23. Nov 12, 2021 at 3:03 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Reinstalled the ‘new webbing’ seat belts today. They are definitely a different pattern and the color isn’t exact but it sure beats a $850 price tag for OE belts. Overall I’m happy and thrilled that my clothes won’t get torn up anymore from the shoulder belt.
    they look thinner in the pictures but are the same width.
    Voss, oscardog86, NUDRAT and 9 others like this.
  24. Nov 12, 2021 at 4:15 PM
    mcharfauros
    mcharfauros Hafa Adai
    MO
    06 AC SR5 4X4
    Dumb Truck Thangs
    Bout 900 bucks later, my boy’s front brakes are done. Toyota handled the labor and gladly took my money for OEM parts:rofl:
    I know we all about that DIY life, but the house and 2 acres got the better of my time, and I completely neglected the 05 since my boy has been away. He was always the one who let me know when things needed to get worked on, and keep me up to speed on the Tundra. About 245K on the old girl, 900 bucks towards keeping her on the road, I can deal with.
  25. Nov 12, 2021 at 5:13 PM
    FrenchToasty
    Mo
    Bone stock
    Finished wiring my Auxbeam switch panel I won at T2S. So far the compressor and the two ditch lights are wired in and it works great! @des2mtn send me your address and I’ll send that seat bracket switch mount if you want it. D50F4ED2-0CA7-4130-A8D3-3D6D70B4C470.jpg 61029C45-0DFE-41A3-8251-D157BF9AD6F6.jpg
    Voss, oscardog86, Desert Dog and 7 others like this.
  26. Nov 12, 2021 at 6:24 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    sweet
  27. Nov 12, 2021 at 8:42 PM
    Henry1stGen
    Henry
    2002 Tundra AC TRD
    I have had my ODB2 connector for a year and no issues so far.
    So many gauge themes and options you can select from Torque.
    EvilMilkshake[QUOTED] likes this.
  28. Nov 13, 2021 at 5:31 AM
    FrenchToasty
    Mo
    Bone stock
    Had to go on a call last night, first impressions of the diode dynamics pro with flood optics; they suck! The light it scattered way too much, the headlights seem to be brighter than the floods.
    So I’ll look at getting a spot or driving combo lens to swap out
    alb1k and Punk1974 like this.
  29. Nov 13, 2021 at 7:56 AM
    0h6SR5
    0h6SR5 New Member
    2006 Phantom Grey Tundra
    3 inch OME with AAL wheels and tires. 285 70 17
    A few days ago I decided to pull the alarm that was on my truck when I purchased it. A 2 way scytek. Replaced it with a compustar 7900AS with remote start. I regret it after I started it lol but saved me a lot of money. They are expensive where I live.
    oscardog86, NUDRAT, bmf4069 and 2 others like this.
  30. Nov 13, 2021 at 8:26 AM
    JustJake
    JustJake New Member
    2006 AC
    Did you have the “lazy” retractor issue with those? We’re they able to fix them?
    oscardog86 and Punk1974 like this.
