  1. Oct 28, 2021 at 10:35 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    toyotas peak numbers typically are only OK. but their implementation of VVTI leads to VERY broad power bands which makes them pretty damn good while not taxing the engine too much.. thats why they'll last so damn long
    but hey if you do the swap i'll totally buy your intake manifold and throttle body... uncles truck needs some pep added to her step and 05-06 ACIS manifolds help
    Darkness likes this.
  2. Oct 29, 2021 at 5:06 AM
    06yotamike
    06yotamike New Member
    NC
    2006 Tundra DC XSP 4x4 4.7 Bluesteel Metallic
    ...Posted about it.
    Hey guys, relatively new to the forum, been getting caught up on this thread for the past two months( yes, . Tons of stuff learned from you guys, there really is a wealth of knowledge and entertainment here.
    I have had my 2006 double cab XSP for about three years, got it from original owner with 163k and now have 209k, but here's what I have done to the truck the past two months:
    Timing belt, waterpump, thermostat, coolant hoses, serp belt
    Spark plugs
    Throttle body and MAF sensor cleaning
    Tire rotation
    Greased the driveshafts
    Goals in the next 6 months
    Tires
    chrome delete
    Replace radiator
    tacoguybill, Voss, oscardog86 and 9 others like this.
  3. Oct 29, 2021 at 5:10 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Welcome to the party, nice looking truck!
    Voss and 06yotamike[QUOTED] like this.
  4. Oct 29, 2021 at 5:36 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I looked this morning. Ethanol Free gas is $4.12/gallon or 26% more than regular gas. In TN it's not even remotely close to being worth buying for 1mpg gain.Going from 15 to 16 mpg is a 6.6% increase.
    bmf4069, Darkness and FrenchToasty like this.
  5. Oct 29, 2021 at 6:03 AM
    06yotamike
    NC
    Truth. Same price differences here in NC typically. Ethanol free is only worth it in the yard equipment.
  6. Oct 29, 2021 at 8:41 AM
    NMR@ider76
    NMR@ider76 New Member
    Jesse
    2006 DC Tundra
    5 inch tuff country 35” coopers on mayhem wheels TRD CAM exhaust K&N JET flash
  7. Oct 29, 2021 at 8:44 AM
    Outbound
    Aaron
    Northern Alberta
    Got my truck back. Mechanic says driveline angles are good, I made a mistake in the measuring the length of my driveshaft. When he put it on the hoist and ran it, the vibration was gone so it's not in the driveline. He did notice that my tires are cupped. Not sure how two tire shops missed that. It seems as though that's the most likely culprit at this point.
    My Cooper ST Maxx are 5 years old now. I put on my winter tires in a couple weeks so we'll see if anything changes then..
    Voss, NUDRAT, bmf4069 and 2 others like this.
  8. Oct 29, 2021 at 9:44 AM
    NMR@ider76
    Jesse
    2006 DC Tundra
    I had the same cup issue with the exact same tire, as mine are just as old. What I did was lower the air pressure, and problem was solved.
    Also, have you checked your driveshaft center support bearing?
  9. Oct 29, 2021 at 9:51 AM
    NMR@ider76
    Jesse
    2006 DC Tundra
    Tire shops (some not all) over inflate the tires to cause people to panic and purchase tires.
  10. Oct 29, 2021 at 10:04 AM
    Outbound
    Aaron
    Northern Alberta
    I'll try lowering the air pressure. My center support bearing is brand new, just replaced last month.
    I checked that after I got it back. The pressure is right at the 40psi I normall run.
    FrenchToasty likes this.
  11. Oct 29, 2021 at 10:28 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    That's so sexy!!!!!
    I know it's brand new, but what are your initial thoughts on the swap? Is it worth it? What did you have on it before?
  12. Oct 29, 2021 at 10:35 AM
    rock climber
    It didn't, everything worked fine, just wanted to see if there is a better fix.
  13. Oct 29, 2021 at 10:44 AM
    Casper421
    In the woods
    06 DC
    What are you running your coopers at?
  14. Oct 29, 2021 at 10:47 AM
    40 is high. Door tag on mine recommends 26psi for fronts. I run about 32psi front and rear. Unless carrying a load, then I air up.
    NMR@ider76 likes this.
  15. Oct 29, 2021 at 10:50 AM
    Outbound
    Aaron
    Northern Alberta
    Well, I'm not running OEM size. 26psi seems really low. When I get down below 30psi, it feels slushy and unresponsive. I burn noticeably more fuel then too.
  16. Oct 29, 2021 at 10:52 AM
    0h6SR5
    0h6SR5 New Member
    2006 Phantom Grey Tundra
    3 inch OME with AAL wheels and tires. 285 70 17
    It’s a little early to say. I’ve read a lot of people get a mushy pedal after this swap. Mine doesn’t seem like that. I don’t think atleast. Going to The sand dunes tomorrow and it’s a 6 hour round trip so I should have some more feedback one that’s over. So for now it’s just for cool points lol.
  17. Oct 29, 2021 at 11:01 AM
    06yotamike
    NC
    35psi seems just right to me on 285/70/17's
  18. Oct 29, 2021 at 11:20 AM
    NMR@ider76
    Jesse
    2006 DC Tundra
    I’m running CooperDiscoverer/T MAXX LT295/70r18, and will keep buying them even though the price has gone up substantially.
    oscardog86 likes this.
  19. Oct 29, 2021 at 12:29 PM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Yes sir thst is what I've been reading also, it's almost like a 50-50 good and bad.I wonder what is creating the mushy brakes.
  20. Oct 29, 2021 at 12:44 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    What is premium? Do you run the lowest octane or mid grade?
  21. Oct 29, 2021 at 2:57 PM
    Casper421
    In the woods
    06 DC
    I also have st maxx’s and will buy again very soon, great tire. What psi are you running them at on the road?
  22. Oct 29, 2021 at 3:00 PM
    daveeasa
    David
    You guys are leaving me no room to go with anything else it seems. I guess I just need to trip upon some sort of deal and decide on my exact size. Then $1500 later I should be good for 10 years.
    NUDRAT and FrenchToasty like this.
  23. Oct 29, 2021 at 4:12 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I run 87. Premium is around $1 more than 87 last I looked.
  24. Oct 29, 2021 at 4:45 PM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    Started de-wood-graining the interior today. Was half and half on wrapping it, but the plastic is in pretty good shape. Def. took some time to clean off the adhesive, and it's a good excuse to deep clean under the trim too. As you can see those non-OEM door handles I replaced last week, while functionally 100% better than the broken ones I had, do not really match that well. They are cooler/bluer in hue vs. the dark grey trim above it. And darker than the OEM lighter great trim. They look worse in the picture than the do IRL regarding the color matching. But it's annoying.
    The black center console cleaned up really nice. Being protected since 2006 likely had something to do with it...
    I started with the door that had the broken ash tray in case I didn't like the outcome. But I do. So I just hot glued the door shut. Rattle solved (at least that one, only like 6 more to track down...).
  25. Oct 29, 2021 at 5:23 PM
    KarmaKannon
    Utah
    Some junk
    Wow that's nuts. Around here mid grade is maybe .15 more than regular and premium is another .15 more. Abouts.
  26. Oct 29, 2021 at 5:34 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    91 on one page and 87 on the other, right around 20 cents difference here
  27. Oct 29, 2021 at 5:40 PM
    FrenchToasty
    Mo
    Bone stock
    Yeah around here 87-91 is usually close to a dollar more, then that station that does carry non ethanol is like 30 cents or so more than 91 and it’s only 89oct
  28. Oct 29, 2021 at 5:54 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I run ethanol-free in my lawn mowers and minibike. I’ll get about 4 gallons at a time. Keeps the carbs happier for longer. My ‘88 blazer was noticeably more powerful on e-free but i also doctor my gas with stabil and lucas fuel conditioner.
  29. Oct 29, 2021 at 5:58 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I remember growing up the different levels were always .10 increments. $1.50, $1.60, $1.70 for example. I wonder what changed? I haven't purchased premium in years.
  30. Oct 29, 2021 at 8:25 PM
    KarmaKannon
    Utah
    Some junk
    That's a great question. I remember it being .10 increments too but gas was also no more than maybe $1.75/ gal. I guess it depends what the extra cost of pulling the gas out at a higher level in the stack or condensing deal or whatever it is. I vaguely remember from my crash course when trying for a sweet refinery gig.
