  1. Oct 25, 2021 at 1:37 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Understood. Keep us posted.
    Outbound[QUOTED] likes this.
  2. Oct 25, 2021 at 1:58 PM
    I think the answer is that these two things are related. The hot brakes and vibrations are likely both front brake related. Maybe a frozen caliper piston. I would fix the brakes first and see what happens with the vibes.
  3. Oct 25, 2021 at 1:59 PM
    Pretty much. That's $160 for cloth or leatherette, full seat or just one section?
    $160 is a really damn good price if a full leatherette with vinyl sides. It's actually a good price for just about anything shy of a slip-on cover these days. I'd be lucky to get out for less than $350/seat at my local reputable shop.
    TRDGen likes this.
  4. Oct 25, 2021 at 2:49 PM
    Desert Dog
    I may be incorrect but I believe the issue existed prior to brake work iirc. You are correct that the brakes could be a contributing factor now though. If, however, the driveline angles are 5-6° out of proper alignment, it is imperative to correct this to eliminate vibes since 5-6° is a large difference geometrically and is surely playing a part. I'd be very surprised if it wasn't. Even 2° difference can produce unwanted vibes and premature wear and tear on a vehicle.
  5. Oct 25, 2021 at 3:03 PM
    Outbound
    Aaron
    Northern Alberta
    This was also happening before I replaced the pads and rotors last month. There's no shimmy when I apply the brakes now, there was before I replaced the rotors.
    I just got the truck back. The tires were out of balance, but not by a whole lot. The vibration is still there. My brakes are still hot and smelling. I'll be bringing the truck into my guy on Thursday morning and we'll verify the driveline angles, check the brakes and go from there.
  6. Oct 25, 2021 at 3:34 PM
    0h6SR5
    0h6SR5 New Member
    2006 Phantom Grey Tundra
    3 inch OME with AAL wheels and tires. 285 70 17
    image.jpg Oh I started installing a Derale trans cooler with electric fan. Last time I went to the dunes trans temp got a little hot. Bothered me so decided to go this route. Will have in line temp switch to kick ok and off and will have override switch running off Auxbeam 8 gang switch system. I work a lot and don’t have much time but after work I put in the time.
    Voss, TRDGen, NMR@ider76 and 5 others like this.
  7. Oct 25, 2021 at 3:39 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Looking forward to the Auxbeam report.
    Tundra2, 0h6SR5[QUOTED] and Casper421 like this.
  8. Oct 25, 2021 at 3:41 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I won the same kit at the Sedona event, I will try and wire it up this weekend and I’ll let you know!
    Voss, RUSTYNUTS, Darkness and 6 others like this.
  9. Oct 25, 2021 at 3:41 PM
    Owenski
    Owenski New Member
    Owen
    2005 4.7L v8 standard cab long bed tundra
    @Outbound about that rattling noise. on my 05 tundra the bolts for the heat shield rusted off completely and the heat shields were just dangling there. the way you describe it is exactly the way I saw it on my truck. to fix this I just put some stainless steel bolts on and it fixed it. I don't know about the warm brakes, but as long as they aren't grinding I would drive them a little longer to where them in more.
    Tundra2 and Outbound like this.
  10. Oct 25, 2021 at 4:56 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    That $160 was for:
    pulling out the seat
    Stripping it down to the foam
    replacing some foam
    building up some parts of foam
    replacing the metal brackets that run horizontal in the back
    replacing the outside fabric thigh bolster
    Should have gotten a before picture but I didn’t. Here’s an after and the padding is SO MUCH BETTER!
    Voss, bmf4069, mcharfauros and 3 others like this.
  11. Oct 25, 2021 at 4:59 PM
    You got a good deal!
    Voss and FrenchToasty like this.
  12. Oct 25, 2021 at 5:01 PM
    alb1k
    Left Coast
    It's good
    Great!
  13. Oct 25, 2021 at 6:21 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Last picture of my new headlights maybe until I put the halos on a switch so you can actually see the demon eyes. The halos need to be on a switch anyway because they are so bright they will light up the snow above my hood and I can't stand that.
    tacoguybill, Voss, RUSTYNUTS and 9 others like this.
  14. Oct 25, 2021 at 9:24 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    2020 toyota 86 radio ordered. and solid offroad poly engine mounts ordered. later this month i'll be talking to @dirtydeeds for the JBA longs tubes and i can finally make use of the new miller welder i got a few months ago and do a custom exhaust i've had planned for 2 years now... then its just interior and this trucks pretty much "complete" for now
    NUDRAT, RUSTYNUTS, shifty` and 5 others like this.
  15. Oct 25, 2021 at 10:06 PM
    daveeasa
    David
    I love how you love OEM radios, Dan. I love tossing them in the trash myself :)
    OK, I'm making the bold bold prediction that with a 2.5" ballpark lift I'll be able to stuff 265/75R16's in. I know, I know, I should think bigger, but I also wanted the option if I'm dumping real money on E rated tires to use them on the Tacoma if I really wanted to for some reason.
    Short list of LT265/75R16 E load with snowflake
    BFG K02 - $231/ea
    General Grabber A/TX - $210/ea
    Yokohama Geolandar MT - $221/ea
    Yokohama Geolander AT G015 - $180/ea
    Toyo Open Country A/TIII - $235/ea
    Cooper Discoverer AT3 LT - $221/ea
    Cooper Discoverer S/T Maxx - $250/ea
    Falken WildPeak A/TW3 - $226/ea
    Nitto Ridge Grappler - $264/ea
    TLDR, they all clock in about the same it seems with a few exceptions which I'm probably not seriously considering.
    Kind of interesting to know, I suppose the takeaway is that it doesn't really matter which ones you pick, they are all good?
  16. Oct 25, 2021 at 11:03 PM
    empty_lord
    05 rollover special
    i run ST MAXX and cant say anything bad about them other than yes, they make some noise.. but its not horribly loud.
    the wildpeaks i hear great things from and i can say the set i put on the 02 tacoma balanced like a dream, i have not driven the truck on the road due to the rust issue though.
    yokos i've had dry rot issues on their truck tires in the past, BFG is just.. well outdated design. cannot comment on the others.
    i just like the OEM radios because of the neat shit i can do with them and confuse the fuck out of everyone. LOL
  17. Oct 26, 2021 at 3:06 AM
    mcharfauros
    mcharfauros Hafa Adai
    MO
    06 AC SR5 4X4
    Dumb Truck Thangs
    Big on the Falken Wildpeak AT3Ws.
    We have had the KO2s in that 265/75/16 size before they look great, however the snow, rain, and wet trails we deal with here left us wanting more considering they cost so much. We went to the Wrangle Duratracs which was a huge improvement off road, but wore out allot faster than the K02s. Decided to go with the Cooper ST Maxx next, no complaints they're a great tire, on the heavy side, not the sexy pick, but will do the job great and at the higher priced side too.
    When we got the 05 Tundra I decided to give the Falken Wildpeak AT3Ws a shot. Same 5 tire rotation and maintenance routine on the heavier Tundra. E-load worked out great, got about 35K on em with a full winter under them, and stoked to say they are still going strong. Front end maintenance and routine rotations go a long way with getting the full life out of these tires.
    Hopefully that was some help
  18. Oct 26, 2021 at 5:18 AM
    Truckin' Girl 1117
    Truckin' Girl 1117 Custom
    Christine
    Grafton
    2003 Black Tundra Xtracab
    Thank you so much!
    robabeatle[QUOTED] likes this.
  19. Oct 26, 2021 at 5:26 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Scheduled drop off day for crackie at the dealership, and worked out details with Momma as pick up person. TG2 will be at work that day, and mom is happy to take off from her job for a three day weekend.
    Staged the truck, and final added Aisin Timing belt replacement sticker to the engine bay.
    NUDRAT, bmf4069, shifty` and 4 others like this.
  20. Oct 26, 2021 at 7:55 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Nice set up, but why the extra trans cooler?
  21. Oct 26, 2021 at 9:25 AM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    I run Goodyear Wrangler Duratracs on all 3 Yota's all in different sizes and I have zero complaints in any type of terrain or weather. Just to throw one more amazing option at this already long list
    mcharfauros and daveeasa[QUOTED] like this.
  22. Oct 26, 2021 at 9:30 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Whatchu talkin’ ‘bout? New toyota radios have fancy hidden features?
  23. Oct 26, 2021 at 10:19 AM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    @daveeasa can’t go wrong with the st Maxx’s. I’ve personally had 2 sets one on xterra, and one on a Tacoma that got totaled. Both sets were north of 45k and we’re gonna easily go another 10-15k. My parents are currently have a set on 04 power stroke also. My wife’s sequoia has the falkens on it, they’re pretty heavy also. I definitely buy them over bfg all-terrains. I’ve hated both sets of BFG’s I’ve had
    I ended with general grabber x3’s this go round. Weights about the same. Gotta a good deal on the generals that swayed me that way. The st Maxx’s we’re pushing $300 a tire. My local Offroad shop moves a lot of generals and came in at $238 a tire
    oscardog86 and daveeasa like this.
  24. Oct 26, 2021 at 10:30 AM
    daveeasa
    David
    I am just super stuck in analysis paralysis on tires, grr. And similarly on if I'm going to get any 17's or not, double-grrr.
    Cooper ST Maxx vs AT3 is a significant difference? There's a $70 rebate on the AT3's, probably older tech?
    F me, who knew tires were so hard.
    oscardog86 and mcharfauros like this.
  25. Oct 26, 2021 at 10:34 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
  26. Oct 26, 2021 at 11:47 AM
    empty_lord
    05 rollover special
    I have added front and rear cameras. If I want I can add blind spot that come on with the turn signals. I can add video inputs… I know a lot of aftermarket can do it to. But now your talking 1000 dollar units
  27. Oct 26, 2021 at 11:54 AM
    daveeasa
    David
    My Pioneer 4660 with wireless carplay and camera inputs was $627. Granted I'll be well over $1k after I replace the 20 year old door speakers and get some amp and sub love in.
    oscardog86 likes this.
  28. Oct 26, 2021 at 11:55 AM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    A blind spot monitor would be pretty neat actually.
  29. Oct 26, 2021 at 11:56 AM
    KarmaKannon
    Utah
    Some junk
    That is so cool. I wish I could find a decent blond spot alert with decent reviews that isn't spendy. There are a few no name units, but the reviews seem so so.
    jImmegart likes this.
  30. Oct 26, 2021 at 12:00 PM
    daveeasa
    David
    @Puppypunter has side cameras which come on with his turn signals. It sounds pretty sweet. His cameras are on his roof rack I believe. That's the hard part, finding a mounting location.
    I would love to have germes style automation in the Tundra for D and R selection with 15s timeout but that's for down the road. First step will be getting the head unit in, then start hunting for cameras for front and rear, and I probably need to sort out the grille before I have the front dialed.
    And then there's the whole matter of no steering wheel buttons on my Tundra.
    I could see going with a physical rocker switch for camera input but so few switch spots too...
