  1. Oct 21, 2021 at 8:54 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    @Hamster14
    Don’t forget lower ball joints. They seem to compromise more first gens than anything else.
  2. Oct 21, 2021 at 9:08 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Dude! Those look badass! Nice work
  3. Oct 22, 2021 at 6:06 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    When you said, "If it snaps its, its new engine time." Did you mean if the timing belt snaps its new engine time? I thought these were non interference engines? I have the V6 so maybe the V8 isnt non interference?
  4. Oct 22, 2021 at 6:58 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The v8 will die. A v6 will survive a broken belt
    TRDGen, RUSTYNUTS, NWPirate and 3 others like this.
  5. Oct 22, 2021 at 9:28 AM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    Hopefully the last time I will take the bumper off and mount it. 3/4" grade 8 washer looks like the winner here. Feel good about how this is sitting. Torqued everything down and should be good to go now.
    Also here is a better look at my harness for the pod lights on the bumper:
    Voss, RUSTYNUTS and KarmaKannon like this.
  6. Oct 22, 2021 at 10:40 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Very few memes speak such truth.
    Voss, Hamster14, NUDRAT and 8 others like this.
  7. Oct 22, 2021 at 10:40 AM
    empty_lord
    05 rollover special
    I’m about to go to the DMV to register the 98 and the 02 Tacoma…. Plus the 66 Mercedes… first time I’ve been able too since my days off line up with the dmv not being open…
    Voss, jImmegart, TRDGen and 6 others like this.
  8. Oct 22, 2021 at 2:01 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Before I create a thread, my front driver window rattles when it’s not all the way up, anyone got a solution?
  9. Oct 22, 2021 at 2:50 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Passed myself
    Voss, oscardog86, NUDRAT and 7 others like this.
  10. Oct 22, 2021 at 3:08 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    PHM found a fix, I think it was tightening the bolts on the side of the door that hold the window channel.
    jImmegart, Darkness and Tundra2 like this.
  11. Oct 22, 2021 at 3:21 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Voss, FrenchToasty and Darkness like this.
  12. Oct 22, 2021 at 3:37 PM
    daveeasa
    David
    oscardog86 likes this.
  13. Oct 22, 2021 at 4:26 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Getting closer. The rgb demon eyes may end up being worthless with the insanely bright halos. I might have to do a 3 to 2 wire adapter and make the amber halo my running light and blinker.
    Voss, FrenchToasty, alee891 and 7 others like this.
  14. Oct 22, 2021 at 4:27 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Somehow my Garmin Rep hasnt showed me these yet however I stock Bluetooth switching systems from Southern Audio and was going to do a steering wheel mount for that in my Tacoma. Now i feel like i gotta get the rep to let me play with one of these first.
    daveeasa[QUOTED] likes this.
  15. Oct 22, 2021 at 4:42 PM
    Zippy0n
    Zippy0n New Member
    2006 Tundra DC
    Where did you get the TRD projector? Ive got my projectors done by a member here.
  16. Oct 22, 2021 at 7:28 PM
    Openbaffle
    Got all my wiring done tonight and re-wired everything down the a-pillar. The microphone cable and Scan Gauge cable were already there but I cleaned them up a bit. I added in a dash cam hardwire kit and also the harness for my Gentex 177 mirror. Ended up coming out really nice. I went with an add-a-fuse approach and ran both runs on the same ignition-switched circuit. I ran the temp sensor out of the firewall and zip-tied in next to the front driver's side headlight. Wiring looks very clean and I like being able to delete the cable in the cab for the dash cam that I had prior to the hardwire kit. Everything worked on the first try and I can't tell I did any work in there.
    Voss, Darkness, abcinv and 3 others like this.
  17. Oct 22, 2021 at 7:53 PM
    KarmaKannon
    Utah
    Some junk
    I had the sign shop at work make me some stencils and I hit the letters with some aluminum oxide blasting media.
  18. Oct 23, 2021 at 3:17 AM
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    (X-posted from my build thread but I just wanted to encourage anyone who might be on the fence about doing similar. It’s cheap and pretty easy after watching a few YouTube videos)
    Vinyl wrapped my rear bumper yesterday to complete the chrome delete. It's excellent from 5 feet, pretty darn good up close, save for a few wrinkles underneath. For the cost of material and an hour's time, I'm pretty pleased with the result. Used two 5'x1' tools for a total of $32. The Satin Dark Grey is a good match for Phantom Grey Metallic. I now have my grill, mirror caps, and rear bumper wrapped in this stuff and it's been holding up perfectly, car washes and all.
    3M 2080 S261 Satin Dark Gray 5ft x 1ft W/Application Card Vinyl Vehicle Car Wrap Film Sheet Roll
    Also did new LCAs/bushings and oil/ filter. Going for alignment and wheel swap today.
  19. Oct 23, 2021 at 6:19 AM
    Openbaffle
    I ran the temp prob sensor wire under the firewall rubber boot for the wiring harness but I don’t love that is there a better way? What have you guys done? I don’t want leaks or to trash the sensor wire.
    912 likes this.
  20. Oct 23, 2021 at 6:54 AM
    912
    2005 DC 4x4
    There are grommets through the floor under the front seats as well.
  21. Oct 23, 2021 at 7:03 AM
    KarmaKannon
    Utah
    Some junk
    That looks great!
    912[QUOTED] likes this.
  22. Oct 23, 2021 at 7:04 AM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    this looks killer, I think I’m gonna try my hand at doin my a-pillars with some matte black.
    912[QUOTED] and KarmaKannon like this.
  23. Oct 23, 2021 at 8:55 PM
    Openbaffle
    This is how I ran the temp probe for my Gentex 177 mirror.
    I don't love how the wire goes into the rubber grommet on the firewall but it works for now.
    The small things in life that you miss...IMG_6641.jpg Also the de-chroming continues. No more nerf bars. Next is that same 3M Satin Gray vinyl wrap on my mirror caps and front grill chrome to give it the color matched look. I think the brush guard is going to go too. I like the cleaner look.IMG_6643.jpg
    Voss, Filthyphil, HBTundra and 6 others like this.
  24. Oct 23, 2021 at 8:57 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Did some pretty cool shit all week! 28C01202-C5C4-4002-B916-F65061972388.jpgDE30577C-B593-47BE-9FA4-B56E2915E288.jpg6A8CC230-B8E7-4D14-80A5-E11BD3FC0B87.jpg86724A9E-6ADF-4A83-BB40-9B9C04333653.jpg13531CD2-A593-44D9-932C-71DCA263AEA5.jpg4C5991EA-AD24-4492-AC12-394092F40564.jpg2AFDA505-237A-4C97-BDF4-F2CE4A4E4A37.jpgB66E7BD8-2F15-4D58-BE67-B7C4AC6E183C.jpg11826CDF-3855-4D79-AC6D-49FA600F4B33.jpgA0D02FDF-4DE8-4D12-BCD2-5A4C2FC7DCF3.jpgC4B3BA6B-0EA6-4C05-8A1C-23F9B695AA6F.jpg7DAEBAF6-A9E2-42CA-B0A0-2148F511697E.jpg98C89B28-CADA-44D0-9F3D-D86C8A812C22.jpgF0EDB861-C8C8-4AED-B389-B935567A162F.jpg56BAA7BD-B737-4C17-9D3E-F776017B4987.jpg6035FE43-6B1A-4DA1-922D-431B606FD8DD.jpg
    Voss, Filthyphil, oscardog86 and 17 others like this.
  25. Oct 23, 2021 at 10:27 PM
    KarmaKannon
    Utah
    Some junk
    Just sealed these puppies up. Will they seal? Will they function? Will they be flat? We'll all find out on tomorrow's episode of adventures in retroland.
    And the pit vipers too! Not sure I could be more jealous of one post that didn't include a car that goes 0-60 under 4 sec or something with a skirt. The
    Voss, Darkness, shifty` and 8 others like this.
  26. Oct 24, 2021 at 12:34 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    I have some red boots I need to install one of these days
  27. Oct 24, 2021 at 2:41 AM
    daveeasa
    David
    I think you can just cut off the nipple and use that for your wire, no? The part where the arrow is? Looks unused.
    Also, part number or link for the sensor? I might do one for mine.
  28. Oct 24, 2021 at 3:55 AM
    Openbaffle
    Oh. Thanks. I guess I could do that. Will try that today. The sensor came in a kit I got. The seller was "hon_dacura". I suspect I could have sourced the parts for less, but it was nice to get a single kit with all the wiring already done.
  29. Oct 24, 2021 at 4:24 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    I been wanting a Gentex mirror. Any pics?
  30. Oct 24, 2021 at 7:39 AM
    b-pillars, you mean?
    Looks like a killer time. RE: This last pic, hoping to pick up a full set of these rims, near-new take offs from recent model 4R for $25/ea.
    Waiting for dude to email or text now. Fingers crossed. It'll fit into my ultimate plan for suspension later.
