  1. Oct 20, 2021 at 10:56 AM
    alee891
    alee891 Rather Be Dead
    Now/here
    Shitbox
    Any improvement in droop? I'm curious if ATS would be a cost friendly alternative to Archive, mainly, since I seem to hit limit on the stockers pretty easily.
  2. Oct 20, 2021 at 11:03 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I'd probably wait until I see a problem with firing (most likely on a warm muggy day), but that's just me.
    912[QUOTED] likes this.
  3. Oct 20, 2021 at 11:09 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Buddy finally had time to test those 1zz injectors. Came back good. All around 258cc output, perfect patter. 12hole upgrade here I come (in a week or 2) I may have him test the old ones to see their flow rate too
    RUSTYNUTS, TRDGen, des2mtn and 4 others like this.
  4. Oct 20, 2021 at 11:18 AM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    1.5" would be perfect for my needs. I know you need to install new U-bolts. Did you all get new shackles as well? I guess it depends on the condition of mine. I'll take some pics.
  5. Oct 20, 2021 at 11:20 AM
    Openbaffle
    I went through the same exercise when I changed my plugs earlier this year. 6/8 had hairline cracks. One was missing a rubber boot, so I replaced that one. I did not go as far as replacing the others because I haven't had any misfires either. But I do have one extra now, that I keep in my truck JIK I run into an issue (along with a 10mm wrench).
    912 likes this.
  6. Oct 20, 2021 at 11:43 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    I need to do mine too.
    jImmegart and empty_lord[QUOTED] like this.
  7. Oct 20, 2021 at 11:47 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Changed my oil last night and took a look around. This is something that caught my eye. The sub frame looks to be getting, or has gotten, greased. The pass side boot looks a little wet all the way around at a certain point, the drivers side looks better. Both sides got greased. What do you all think? I'd appreciate perspective from others. Let me know how far up the priority/worry list I should be putting this.
    Diver side:
    After scraping some grease off
    Pass side:
  8. Oct 20, 2021 at 12:09 PM
    empty_lord
    05 rollover special
    I can’t make it to Indy any time soon so he’s going to ship them to me soon. Maybe ina. Couple weeks I’ll do install
  9. Oct 20, 2021 at 12:40 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Cool. Let us know how it is.
  10. Oct 20, 2021 at 1:54 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I never checked droop, but I'd say it's about the same, meaning when I installed them I lowered the rear axle and the space was about the same installing the new ones.
    oscardog86 likes this.
  11. Oct 20, 2021 at 1:55 PM
    rock climber
    My 20 year old shackles were fine so I reused them. No issues before or after.
    The worst part is getting the front side of the leafs off the truck
  12. Oct 20, 2021 at 3:12 PM
    Openbaffle
    Simple. But now I'm all LED in the cab. These little 74 LED bulbs are bright!
    Also checked the two wires up in my overhead console and neither are ignition controlled for my Gentex mirror. So I'll likely have to run a wire down the a-pillar and find an ignition circuit to tap off of. I'm sure there is a good pictorial tutorial somewhere on this forum. I'll try and find it to dig it up.IMG_6598.jpg
  13. Oct 20, 2021 at 3:14 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Thank you. I only recently found out there was a bulb down there and I have plenty of LEDs
  14. Oct 20, 2021 at 3:14 PM
    daveeasa
    David
    Where did those LED bulbs find a home?
    Yeah, I still have to do my mirror harness. I got some of it started but need to do an extension harness to get down the a pillar.
  15. Oct 20, 2021 at 3:17 PM
    alb1k
    Left Coast
    It's good
    Get the glove box?
  16. Oct 20, 2021 at 3:21 PM
    Openbaffle
    It's here.
    I don't know if I have a light in my glove box. Or maybe it's blown out. Checking...
    daveeasa[QUOTED] likes this.
  17. Oct 20, 2021 at 3:23 PM
    alb1k
    Left Coast
    It's good
    Voss, Openbaffle and daveeasa like this.
  18. Oct 20, 2021 at 4:39 PM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    I changed mine in the glove box with the same led blub you have, you just have to sand lighty the sides so if can fit. Also when your testing the light make sure you have the key on accessory. Ask me how long it took me to find out.
    oscardog86 and shifty` like this.
  19. Oct 20, 2021 at 4:40 PM
    Openbaffle
    Yea. Got mine working. Found that thread thankfully so only wasted 30 mins wondering why it wasn’t working, checking the fuse, flipping the polarity of the light etc.
    Dave8699[QUOTED] and alb1k like this.
  20. Oct 20, 2021 at 4:42 PM
    More like the plastic molding seam. Wouldn't chase a problem that ain't a problem.
  21. Oct 20, 2021 at 4:43 PM
    Openbaffle
    100%. There are plenty of problems that are problems lol.
    912 likes this.
  22. Oct 20, 2021 at 5:32 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Looks like mine after I leveled it and I just needed to do new boot clamps.
  23. Oct 20, 2021 at 6:23 PM
    alb1k
    Left Coast
    It's good
    I just measured the Archive MD pack lift. Prior to installing them, I was 9" from the top of the axle tube to the frame. It's now 11.5" - a 2.5" increase. I'm told stock is 9.5" there on my truck. So give or take 2" over stock. These springs hold weight, I don't need quite that much rake. So, TC drop shackles will take off about 3/4". And I have some more weight coming, so shackles first and some further evaluation.
    Darkness and Openbaffle like this.
  24. Oct 20, 2021 at 7:27 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    I was given some left over energy suspension sway bar end link bushings (probably 2+ years ago lol). Decided to toss them on the truck today.
    Darkness, oscardog86 and shifty` like this.
  25. Oct 20, 2021 at 7:28 PM
    alb1k
    Left Coast
    It's good
    Nice job not over .tightening the crap out of them :)
  26. Oct 20, 2021 at 7:31 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    @Tundra2
  27. Oct 20, 2021 at 7:33 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    I tried for 2.weeks and eventually just handed mine over to a shop. Took em like an hour.
  28. Oct 20, 2021 at 7:33 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    I was going to say change now cause inflation will not stop lol
    Jack McCarthy[QUOTED] and 912 like this.
  29. Oct 20, 2021 at 7:37 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    Is TFT the transmission temp? I always called mine ATF, but I can't get it to work on my 06. I think I need to update my firmware on my scangauge. Might do that this week.
  30. Oct 20, 2021 at 7:38 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Yeah tft, it was definitely the hardest one to program in for some reason
