  1. Sep 15, 2021 at 9:12 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Without long travel you are gonna look real stupid with narrow suspension and wide glass. Also Glass is a lot of work to fit and make look nice so know that going in. Its definitly more aimed at those of us hanging it off Tube work than factory body mounts. Not impossible but lot of work, Something like that 1 piece would require custom fab though.
  2. Sep 15, 2021 at 9:12 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    What condition are the motor mounts in, do you know? Specifically the trans mount.
    FrenchToasty likes this.
  3. Sep 16, 2021 at 6:24 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It seems I have stumped even the parts guys at McGeorge. I called them yesterday and explained neither hose they sent me have matched the original. He did say that a vacuum hose is a vacuum hose meaning if it fits, it should be fine. Maybe he's right. They have no other part numbers to try.
  4. Sep 16, 2021 at 7:07 AM
    Outbound
    Aaron
    Northern Alberta
    I'm not sure. I'm going to check them out when I pull the truck in the garage for the rotor job.
  5. Sep 16, 2021 at 8:36 AM
    Desert Dog
    Understood. They/it may very well be the problem.
    Outbound[QUOTED] likes this.
  6. Sep 16, 2021 at 9:21 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    How did you take the mirror caps off or did you just spray it on the truck?
  7. Sep 16, 2021 at 9:29 AM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    mirror caps are held in by 5 or 6 little clips behind the mirror glass. without taking the glass off, they’re almost impossible to get out without breaking
    Darkness and 2006Tundra[QUOTED] like this.
  8. Sep 16, 2021 at 9:30 AM
    2006Tundra
    Lou
    Long Beach, CA
    Alrighty, so how do you take the glass out? Pull on it?
  9. Sep 16, 2021 at 9:32 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm really happy with how my mirrors turned out after spray painting them. Plasti-Dip looked good for a year or so but I went with a more permanent approach this time. Technically I sprayed right over the old Plasti-Dip so I could possibly return to chrome if I wanted to.
    abcinv, Darkness, Casper421 and 3 others like this.
  10. Sep 16, 2021 at 9:35 AM
    2006Tundra
    Lou
    Long Beach, CA
    @FirstGenVol
    That looks great! I was thinking of line-Xing the caps but this might be a better option.
  11. Sep 16, 2021 at 9:49 AM
  12. Sep 16, 2021 at 9:59 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Does it need to be shaped in a peculiar way? Any sharp turns or angles a straight piece can't do? If not I'd say fuck it and get a piece longer than what you think you'll need at the zone.
  13. Sep 16, 2021 at 10:17 AM
    jImmegart
    Jonah
    California
    Ya, ive always broken the glass though. How I did it is moving the mirror and getting all clips besides the bottom and sacrificing those by breaking them. Ive never put the same caps back in though, Ive always replaced them so it didnt matter for me
    Darkness likes this.
  14. Sep 16, 2021 at 10:58 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I should have mentioned that I used Rust-Oleum truck bed coating.
  15. Sep 16, 2021 at 10:59 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    No weird bends. It just has to flare at the end which it seems to. Maybe I'll just roll with it!
    bmf4069[QUOTED] and dbittle like this.
  16. Sep 16, 2021 at 11:58 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Exactly how I've done it twice.
    First time I did reuse them after painting. @2006Tundra get a few nickels handy when you pop your caps off. I found it helpful to move the mirror around, get a tool in there to push the tab, put a nickel between the cap and the housing to prevent it from snapping back in when you move to the next. Bottom ones I gave up on, one on each side busted. They still held in fine.
  17. Sep 16, 2021 at 2:50 PM
    Outbound
    Aaron
    Northern Alberta
    Doing rotors and pads today. Running into a problem though. When I get the pads in, the rotor rubs on the pads. Normal?
    Rotors and pads are OEM from the dealership.
  18. Sep 16, 2021 at 3:08 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Rubbing is normal, is it hanging up or just rubbing?
    oscardog86 likes this.
  19. Sep 16, 2021 at 3:10 PM
    Outbound
    Aaron
    Northern Alberta
    Just rubbing. I can rotate the rotor without much resistance.
  20. Sep 16, 2021 at 3:11 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Your fine
    oscardog86 and Outbound[QUOTED] like this.
  21. Sep 16, 2021 at 4:00 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Don’t take the glass out. I use a pick tool and can access 5/6 of the clips just from moving the glass around. You need to keep constant pressure on the caps while releasing the clips.
    This is the backside of the driver side. You can see the clip locations around the perimeter.
  22. Sep 16, 2021 at 4:01 PM
    FrenchToasty
    Mo
    Bone stock
    Some goodies showed up for the truck, a mount for the scan gauge, and some wheel well splash guards from ARK, they are localish
  23. Sep 16, 2021 at 5:20 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Link and some photos of the scan gauge mount. I have mine wedged in the ashtray hahaha
  24. Sep 16, 2021 at 5:26 PM
    FrenchToasty
    Mo
    Bone stock
    KingSequioa007 likes this.
  25. Sep 16, 2021 at 5:30 PM
    daveeasa
    David
  26. Sep 16, 2021 at 5:32 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    It’s perfect for me… doesn’t hinder much sight from the window, but I can see my temps without taking my eyes off the road
  27. Sep 16, 2021 at 5:38 PM
    FrenchToasty
    Mo
    Bone stock
    That’s what she said?
    I asked the same think, and Dan said it wasn’t in the way at all, for the price, I can’t make that in my spare time and make it look that nice. I’ll probably get it installed this weekend.
  28. Sep 16, 2021 at 5:40 PM
    daveeasa
    David
    Since I'm buying it seems, are their hood struts for 3rd gen Taco OK? I am tired of prying my hood open.
  29. Sep 16, 2021 at 5:43 PM
    empty_lord
    05 rollover special
    Spikers good shit. Just do it and enjoy
  30. Sep 16, 2021 at 5:45 PM
    Outbound
    Aaron
    Northern Alberta
    Rotors and pads are done. Still chasing that vibration. I put the winter tires on and went for a drive. Vibration seemed a little less. Next step is to get my tires balanced I guess. Of course while I was putting the summer tires back on I stripped a lug nut and buggered the first couple threads on the stud. So fuck me. Calling tire shop tomorrow to hopefully get the truck in for that and the balancing.
